ValveCaster Mods
Re: ValveCaster Mods
Postby snk » 31 Mar 2018, 23:17
Hello
I received new regulators, and i'm willing to investigate further my Valvecaster mods (but i don' want to fry another 7812).
Could you please tell me if the layout is correct ?
(I attached the DIYlayout creator project as well)
For this message the author snk has received thanks:
modman (02 Apr 2018, 11:58)
snk
Has thanked: 45 times
Have thanks: 7 times
Postby snk » 02 Apr 2018, 10:23
Little bump for the regulator layout :?:
snk
Postby JOHNO » 02 Apr 2018, 13:07
It all looks ok to me but you could lose the two jumpers by simply soldering the diode to the tracks of pin 1 and pin 3 of the regulator.
For this message the author JOHNO has received thanks:
snk (02 Apr 2018, 15:09)
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby snk » 02 Apr 2018, 13:30
Thank you.
So, like that ?
It's indeed faster to do this way :)
snk
Postby JOHNO » 02 Apr 2018, 13:37
Umm? sort of. I would put the diode parallel to the regulator, between C1 and the reg, but yes you have the right idea.
JOHNO
Postby snk » 02 Apr 2018, 13:42
Ah ah ! Sorry, i'm really a beginner at creating veroboard layouts :oops:
So, like this ?
snk
Postby JOHNO » 02 Apr 2018, 13:46
Yep, thats it. :thumbsup
JOHNO
Postby snk » 02 Apr 2018, 13:56
Thank you !
snk
Postby snk » 02 Apr 2018, 15:12
Hello
I'm happy to tell that my slightly modded Valvecaster works fine now :applause:
Fed with 15V, it desn't hum nor buzz, the signal is clean.
I'm using a 12AU7, which sounds great (better than the 12AT7 i also tried).
I'm much more happy with the modded tone than with the default one.
Overall, it sounds good !
Thank you all for the help :thumbsup
snk
Users browsing this forum: PEPPER! and 1 guest
