Secretefx - Secret-1 STD overdrive  [traced]
Has thanked: 4410 times
Been thanked: 2139 times
Saw this a bit late -- still, YuGi got promoted to Degoop Doctor...
Has thanked: 1675 times
Been thanked: 1359 times
Post by Manfred »
Here the PCB-Layout clone, I plan to convert it to a single side version.
Secret1PCB_Components.pdf
(16.83 KiB) Downloaded 138 times
Secret1PCB_ComponentSide.pdf
(5.15 KiB) Downloaded 114 times
Secret1PCB_ComponentSideMirrored.pdf
(5.14 KiB) Downloaded 116 times
Secret1PCB_SolderSide.pdf
(6.52 KiB) Downloaded 117 times
Secret1PCB_SolderSideMirrored.pdf
(6.49 KiB) Downloaded 104 times
Frabbio
Been thanked: 97 times
Post by Frabbio »
Single sided layout with pcb mount pots, board dimensions are 5.5x4.5 cm.
My suggestion for the opamp is the OP275.
Good Diy
Post by Manfred »
Hi Frabbio,
ok, is already done.
Thanks for sharing.
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
@Manfred: Publishing a cloned version of the original pcb layout is a copyright infringement
Post by Manfred »
roseblood11 wrote:@Manfred: Publishing a cloned version of the original pcb layout is a copyright infringement
O.k, If it harms the forum, then the Admin should delete my post.
BTW, all drawn schematic found by tracing are copyright infringements too.
I just asked the Administrator to delete my post:
viewtopic.php?f=7&t=24020&start=20#p269820
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
Manfred wrote:BTW, all drawn schematic found by tracing are copyright infringements too.
No, they are not. It's your own artwork, you created it.
Roseblood: who are you and what are you doing on this forum?
And that's really all there is to it...
EDIT:
I cannot think of any copyright issues that would matter. At least really none apply. I moved the forum from US servers which cost us about $95/year to a Swedish server which costs about 4 times as much. Hosted in the USA, Lance Keltner and Klon clown Finnegan could just send a mail to the hosting company simply stating that we were infringing copyright, without having to prove anything. In order to defend the forum against this false claims, I would have had to hire a US attorney to fight the complaint.
Right now the situation is the inverse: anybody who feels their copyright is infringed upon can file a complaint with the
Stockholm District court:
Scheelegatan 7, 112 28 Stockholm, Sweden
AAntonio
Has thanked: 19 times
Been thanked: 16 times
Post by AAntonio »
what can I put in place of the Y5S filter?
plush
Has thanked: 36 times
Been thanked: 172 times
Post by plush »
AAntonio wrote:what can I put in place of the Y5S filter?
Y5S is a simple LCL (inductor - capacitor - inductor) filter, made to tame high frequency power line noise (e.g. if used with poor switch-mode power supply).
It can substituted with two 0.5uH inductors in series with DC supply and 100p cap to ground between them (ref. schematic).
Or you can omit them, if you have clean and trusty power supply.
I find it a bit of overkill here.
AAntonio
Post by AAntonio »
[ Image ]
Thanks a lot for the answer
Is this okay? or just the link?
look at the photo
Post by Manfred »
Is this okay? or just the link? Look at the photo.
No, that's wrong, the vertical link would short the +9V terminal to ground, because the inductor got very low DC-resistance.
The horizontal link is ok.
