Castledine Electronics - The Wizard  [traced]
Re: Castledine Electronics - The Wizard
Postby Manfred » 07 Apr 2018, 15:22
Schematic and layouts, the capacitor values should be correct now.
WizSprintLayoutFile.zip
I cerated a Vero-layout, but it is not applied yet and not verfied until now.
The lot of wire jumper results from the trial to keep the layout small.
WizLochMasterFile.zip
WizVeroComponetSide.pdf
WizVeroBothSides.pdf
The solder side is folded downwards shown.
WizVeroSolderSide.pdf
WizVeroSolderSideOriginalSize.pdf
dv8r601 (09 Apr 2018, 22:34), Intripped (07 Apr 2018, 18:16), matching_mole (08 Apr 2018, 12:50)
Has thanked: 1038 times
Have thanks: 624 times
Re: Castledine Electronics - The Wizard  [traced]
Postby Manfred » 09 Apr 2018, 00:13
A re-examination gave some other resistor values as follows:
R4 old 22k -> new 10k
R5 old 4k7 -> new 3k9
R18 old 22k -> new 10k
R19 old 22k -> new 10k
R20 = 22R added.
WizSprintLayout6_FileCorrected.zip
WizPCBSolderSide.pdf
WizPCBSolderSideMirrored.pdf
WizVeroBothSidesCorrected.pdf
WizVeroSolderSideCorrected.pdf
WizVeroSolderSideCorrectedOriginalSize.pdf
For this message the author Manfred has received thanks: 5
blackbunny (09 Apr 2018, 05:13), Blues1911 (07 Mar 2019, 08:38), Cub (09 Apr 2018, 07:08), dv8r601 (09 Apr 2018, 22:37), Intripped (09 Apr 2018, 22:43)
Postby Intripped » 09 Apr 2018, 22:42
hey! :D
..may i ask where did you take these new values from?
have you got the real pedal on your bench?
i can see that the old values of the resistors are coherent with the pics in the previous page, so ...are there 2 versions of this circuit?
would be interesting to determine which is the most recent
thanks again for your work!
Intripped
Has thanked: 620 times
Have thanks: 218 times
Postby Manfred » 09 Apr 2018, 23:03
Intripped wrote:hey! :D
No, I have not got the pedal on the bench, I got the information form another source.
I do not know which is the most recent, I guess the second one.
But anyway-the second one is verified.
Postby Blues1911 » 07 Mar 2019, 08:49
Manfred wrote:No, I have not got the pedal on the bench, I got the information form another source.
Manfred, please notice that C2 value is reported right on the PCB (47uf) but not on the schematic, where is still wrongly noted as 100uf.
For this message the author Blues1911 has received thanks:
Manfred (07 Mar 2019, 09:08)
Blues1911
Have thanks: 11 times
Postby Manfred » 07 Mar 2019, 09:08
Hi Blues 1911,
thanks for the hint.
Here the corrected Schematic:
blackbunny (14 Mar 2019, 02:20), Blues1911 (07 Mar 2019, 09:35)
Users browsing this forum: foxey and 11 guests
