I was using my Danelectro Honey Tone amp with an audio signal probe I built to troubleshoot audio circuits. It worked great until I used it to probe a tube preamp circuit. Now there is no output. I think I blew the op amp (TL072) because the signal is too high in a tube preamp. I will replace the op amp as soon as I can get one.
What would be the best way to limit the input signal to this little amp? Would zeners on the input be a good way to limit the input signal?
Mike
Danelectro Honey Tone Amp Doesn't Work
- my favorite amplifier: Modded Marshall
- Completed builds: Pedals:
BSIAB2, Tube Screamer Clone, Timmy Clone, Plexi-Drive Clone, Dr Boogie, Rangemaster, GTFO, MicroAmp, Silicon Fuzz Face, Germanium Fuzz Face, Big Muff Pi, Rat
Amps:
Single-Ended Marshall Voiced using 6V6,6L6,EL34,5881,6550, or KT88 - Location: Winnsboro, Texas
- Has thanked: 2 times
- Been thanked: 1 time
Amps:
This is what I was talking about. Would the zeners on the input provide protection for the op amp? If so, what values would you recommend?
- ht.png (5 KiB) Viewed 733 times
