Monoprice 15 watt tube amp problems
chuckusa
Post by chuckusa »
So I got this amp, its a Monoprice 15 watt tube amp thats suppose to be modeled just like the Laney Cub12R I think.
I got the schematic for it. I was just wondering if anyone could help me ID this resettable fuse. And where can I find a replacement?
Laney calls it Laney PN 007390
the schematic also calls it PTC6.0
I looked the part up on ebay and found one that calls it a pollyswitch resettable 30V 6A fuse.
Is that what this part is? It was just jumpered when I got it. I want to replace the jump wire with the correct part. What do you guys think?
jewel
jewel
Face
Face
This is the area where I need to part repalced
chuckusa
Post by chuckusa »
So the story went this amp was plugged in and running when a hair dryer was plugged into the same socket outlet and something in the amp popped.
From what I can tell after the amp popped,
these things were attempted to be replaced:
R2 and R12
F1 PTC6.0
250v glass fuse
What do you guys think? How bad is she? Will she live? Lol...
What I want to know is where can I find the two replacement fusible resistors and are they just plain ole 1/2 watt fusible 1k resistors?
what is that part thats been replaced with the jump wire, is it called a PTC6.0 resettable fuse? Where can I find one?
Where can I get these 3 items from? and whats their exact name and values ect, so I know im getting the right stuff....
Please refer to the pictures underlining info for details on each component.
This is the 250v fuse that kept blowing
This F1 PTC6.0 was replaced with a jump wire
R2 and R12 looked all cooked and deformed and were replaced with a pair of 1k 1/4 watt metal film resistors.
chuckusa
Post by chuckusa »
I found the what I believe is a resettable fuse.
It came from where that jump wire is located.
So with the right mentioned parts replaced, do you guys think this amp will come back to life?
Im wondering if R2 and R12 are 1k half watt fusible resistors
and if F1 is a 30v 6A resettable fuse.
I want to replace these parts then pop a new glass fuse in her and see if she boots up lol
This is suppose to go where that jump wire is.
chuckusa
Post by chuckusa »
Oh yea also it wasnt a hair dryer that was plugged in, it was an old electric heater.
chuckusa
Post by chuckusa »
Sys mods please delete this entire thread, thanks. Sorry.
Has thanked: 4411 times
Been thanked: 2139 times
chuckusa wrote:Sys mods please delete this entire thread, thanks. Sorry.
Why? This thread could help out others in the future...
Would be nice to share the schemtic too
http://www.epiphonetalk.com/threads/nad ... 1815.1562/
deltafred
Has thanked: 814 times
Been thanked: 306 times
Post by deltafred »
The PCB on this amp looks identical to the Laney LC15.
I had one in to fix recently with an intermittent resettable fuse in the heater supply (same position on the PCB as this one). Apparently there was a bad batch of resettable fuses that were made in Mexico.
Replacement with a generic 6A 30V Chinese one (or a wire link) is the recommended cure. As it was for a customer I fitted another.
