Analogman - King of Tone  [traced]
Re: Analogman - King of Tone
Postby Seiche » 07 Jul 2018, 14:39
- the input cap is 22n on both sides
- instead of 1s1588, this uses 1n914
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side.
- the feedback loop cap on the yellow side ist a weird value. 505? The red side has the usual 101=100pF.
I haven't verified all of the resistors.
For this message the author Seiche has received thanks:
dv8r601 (10 Jul 2018, 00:00)
Seiche
Has thanked: 241 times
Have thanks: 184 times
Postby Dirk_Hendrik » 07 Jul 2018, 16:53
Seiche wrote: after 7years on the list
Am I correct you are not joking? :shock: :shock: :shock:
Has thanked: 253 times
Have thanks: 1015 times
Postby Seiche » 07 Jul 2018, 21:17
Haha you are correct, however, I did not WAIT 7 years for the pedal. I just didnt decide for 5,5 years if i wanted the pedal. But when I did, they sent it the next day :)
Seiche
Postby Dirk_Hendrik » 08 Jul 2018, 09:52
Pfoooh :thumbsup
Postby Seiche » 08 Jul 2018, 10:24
Dirk,
what do you reckon is up with this 505 cap?
That should be 5uF, but that doesnt make sense?
Seiche
Postby Motter » 10 Jul 2018, 19:08
Maybe it's a 50 pf and the second 5 is a tolerance marking? Or maybe an S? Can you see any other markings on it?
Motter
Has thanked: 26 times
Have thanks: 93 times
Postby Seiche » 10 Jul 2018, 21:09
That's what I'm assuming, but it's not consistent with the other one (101).
Seiche
Postby plush » 11 Jul 2018, 12:36
Wow, same happened to my fallout character when i maxed his social marketing bullshit instead of soldering.
plush
Has thanked: 24 times
Have thanks: 39 times
Postby Seiche » 21 Jul 2018, 12:56
So I traced the circuit and it's pretty much what we already know. The only differences are thus:
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side. The IC also has and H painted on and the chip id sanded off.
- On the high-gain red side the gain resistor is 100k, on the yellow side it is 1k.
I think the last part is news, as this resistor was always assumed to be 10k and the gain pot changed for high-gain on DIY projects.
For this message the author Seiche has received thanks: 3
lars-musik (09 Sep 2018, 21:56), Manfred (21 Jul 2018, 18:30), nenecarrizo83 (26 Aug 2018, 05:21)
Seiche
Users browsing this forum: JBassTeleGuit and 10 guests
