Hi, what is the best device to test and listen to pedals with headphones? I was thinking about buying the Vox plug Amp with a good headset, but I did not try it and I do not know if the distortions sound bad?
Recommendations?
287m wrote:try Velleman K4102 < your prefered cabsim < pedal in test
black03 wrote:287m wrote:try Velleman K4102 < your prefered cabsim < pedal in test
It works well? You have bad score on Amazon, I saw many videos that on the Namm are with headphones testing pedals, as manufacturers do?
287m wrote:black03 wrote:287m wrote:try Velleman K4102 < your prefered cabsim < pedal in test
What you mean about me have bad score in amazonnever buy and sell in amazon. Just affiliate for some time ago. hahaha
its just a suggestion. you can try it on breadboard ( as schemo already on net ). If suit you, build itbtw, we talk about DIY, yes?
or you want try this?
sorry for lazy draw, all opamp is 5532. OL & OR is output for headphone jack.
for me, a (almost) flat response headphone/iem/earbud is must. best bang for buck is takstar HD2000 or ts671
apollomusicservice wrote:I use my DIY tube/mosfet headphone amp, very good linearity and sound very good.
[ Image ]
sixthfloor wrote:The vox amplug will distort what you hear. Not very good for listening to a pedal on its own IMO.
I'd recommend plugging the pedals and your headphones directly to a mixer, or using a multi-fx unit (e.g. zoom G1on) in bypass mode.
