Snarling Dogs - Erogenous Moan [schematic]
Here are the guts to a cool volume pedal that can simulate a backwards guitar. Sorry about the picture quality my camera refuses to focuswhen i use the zoom.
the IC chips say: U5: too small to read.
U3 and U4: HCF4016BE
W990A9735
Malaysia
U2: 4558D
JRC
7398B
U1: MC14013BCP
FOL9806
W990A9735
Malaysia
U2: 4558D
JRC
7398B
U1: MC14013BCP
FOL9806
- RnFR
do you have a macro setting on your camera? that usually helps a lot for gutshots.
- Stevenrb718
I have a Snarling Dog Erogenous Moan Pedal where only the volume pedal side of the unit works. Clicking the switch to use the reverse side does nothing, no change in sound or LED lighting up. The wiring seems to be stock but I have nothing to compare it to, so I'm not sure. Any help on this would be greatly appreciated!
- dv8r601
Take good pics of the front and back of the pcb. The guys here are experts at pointing out dodgy solder joints and other faults.
- Stevenrb718
Here are some pics. Is there a way to test the switch firstly?
- D.gif (79.35 KiB) Viewed 5455 times
- C.gif (80.25 KiB) Viewed 5455 times
- B.gif (66.44 KiB) Viewed 5455 times
- A.gif (74.61 KiB) Viewed 5455 times
I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
- scoop
thanks everyone for investigating this thing, I've always wanted to try it but never shell out for.
I might be wrong I have never used this pedal but based on the description, I thought the "click" was an intended feature on the pedalAharonimacaroni wrote:I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
The Erogenous Moan is a volume/reverse volume pedal, and can be used as a straight volume pedal. Pushing the footpad causes the volume to swell. At the end of the sweep, the volume cuts off completely. Reversing the process, the volume kicks in, and swells again. At the top of the sweep, the volume cuts off with a simulated click of a guitar pick.[/b] The effect is haunting.
More than 23000 guitar effects pedals from 4000 brands:
http://www.effectsdatabase.com/model/sn ... genousmoan
- digi2t
- Degoop Doctor
Yeah. Here's what I have. Didn't have time to validate it to the board trace tho, so you might want to check it yourself.
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
I create this approximate PCB-Clone:
Ready to print PDF-files: SprintLayout6-file:
- Stevenrb718
Thanks for the schematic. It definitely helped for wiring up the switch. However I still have the same issue of the volume side working but the reverse doesn't work. Which IC controls the reverse of the pedal?
