Yack YF-2 Fuzz Box  [schematic]
Postby george giblet » 29 Mar 2019, 05:41
Old and Rare.
Some parts are not known but I have worked out good estimates.
The filters (C6 and C8) were matched by using the sound samples.
Yack YF-2 Fuzz
Japan
1967 to 1969
http://www.effectsdatabase.com/model/yack/yf2
good pics:
http://electricpartslibrary.hatenadiary ... 0160803/p1
Sound sample from electricpartslibrary page: (if this link doesn't work go via previous page)
https://ec-media.sndcdn.com/ouZUywJZSjZ ... 4592d02735
v good pics:
https://reverb.com/item/3944443-yack-yf ... anese-fuzz
Comments, additions, fixes welcomed.
For this message the author george giblet has received thanks: 7
dai h. (30 Mar 2019, 05:02), Dan N (13 May 2019, 10:17), Intripped (29 Mar 2019, 23:28), jrod (08 Apr 2019, 03:01), Manfred (29 Mar 2019, 09:18), modman (01 Apr 2019, 15:36), Zokk (01 Apr 2019, 20:08)
george giblet
Has thanked: 69 times
Have thanks: 89 times
Re: Yack YF-2 Fuzz Box (schematic)
Postby george giblet » 29 Mar 2019, 22:47
I cleaned up a couple of minor things and added a part numbering pic.
If someone find another board pic they can used the part numbering pic to check the part values against the schematic.
For this message the author george giblet has received thanks: 6
d312a (30 Mar 2019, 15:47), dv8r601 (29 Mar 2019, 23:06), jrod (08 Apr 2019, 03:02), Manfred (30 Mar 2019, 04:59), modman (01 Apr 2019, 15:38), toneman (01 Apr 2019, 20:50)
george giblet
Postby dv8r601 » 29 Mar 2019, 23:09
uber close up shot
For this message the author dv8r601 has received thanks: 3
george giblet (04 Apr 2019, 23:30), modman (01 Apr 2019, 15:38), toneman (01 Apr 2019, 20:50)
dv8r601
Has thanked: 406 times
Have thanks: 21 times
Postby modman » 01 Apr 2019, 15:46
Has thanked: 3258 times
Have thanks: 608 times
Postby Dirk_Hendrik » 03 Apr 2019, 10:36
What is the 1967-1969 reference based upon?
modman (05 Apr 2019, 10:13)
Has thanked: 255 times
Have thanks: 1035 times
Postby george giblet » 04 Apr 2019, 23:30
It's a valid question. I did put some thought into it even though it may be wrong.
The 1967 was based on the electrolytic caps (early 1967). The range was something I found on the internet so it's an unofficial range.
There is another Yack product, the DA-1 Fuzz Box, which is very similar but not a 100% copy of the Ace Tone FM-1; the PCB looks identical but different parts are loaded. The FM-1 dates 1966/1967 through to 1968/1969; again unofficial figures.
So putting that loose info together I thought the 1967 to 1969 range from the internet was believable.
Given the rareness of the Yack pedals it's going to be had to get enough samples to improve the answer.
modman (05 Apr 2019, 10:02)
george giblet
Postby toneman » 05 Apr 2019, 16:27
the yf-2 box looks "flatter"(wider) and has a switch. the da-1 does not. Extra filter caps(?)
I luv old fuzzes.. :applause:
not much info at
http://www.effectsdatabase.com/model/yack/da1#pictures
8)
Tone-to-the-Bone
toneman
Has thanked: 100 times
Have thanks: 20 times
Postby george giblet » 05 Apr 2019, 23:17
From the outside that's it. They follow the wedge style enclosure from that era. Inside they are quite different.
The Tack YF-2 is unique, other than the similarities to the Fuzz-Face type ckt.
The Yack DA-1 is very similar to the Ace-Tone FM-1 but it's not a direct copy even though the PCB looks identical.
The DA-1 and FM-1 both use a similar ckt to the Maestro FZ-1. This group are all 3V units.
Analog guru did a partial schematic in 2007 for the Ace-Tone FM-1. The schematic has a few bugs, not because of tracing issues but because he had limited pics to work from - that's life tracing from pics. I've been able to gather a little more info but still not enough to create a complete schematic. I'll put up what I have when I have more time.
I luv old fuzzes.
Yes, until the internet I didn't realize there we so many from the 60's. Sometimes I don't like the sound 'out of the box' but they can be tweaked. LucifersTrip has done quite a bit of tweaking.
For some units there very little info.
I like the idea of documenting what these things actually were. It takes actually takes quite a bit of work. Without all the people on internet pitching in with snippets of info it would be an impossible task.
george giblet
Postby george giblet » 05 Apr 2019, 23:52
Very interesting, there's also a YF-1. It doesn't have a switch.
http://www.effectsdatabase.com/model/yack/yf1
It uses the YF-2 PCB. Clearly some parts for the switch are not loaded on the YF-1.
Another one!
george giblet
Postby toneman » 06 Apr 2019, 00:49
so......
maybe........
there's a da-2 :?: :scratch:
the one with a switch :hmmm:
yeh, the interweb allows folks from around the world to come together for a chance of fuzz :!: :wink:
8)
Tone-to-the-Bone
toneman
Postby george giblet » 07 Apr 2019, 03:36
there's a da-2
You never know! We know what to look for now.
There's no way I would have recognized the YF-1 without having looked at the YF-2.
george giblet
