Earthquaker Devices - Arrows  [traced]
bc108
my favorite amplifier: BE100
Has thanked: 34 times
Been thanked: 5 times
Post by bc108 »
Anyone?
Another modified Electra?
palomaeki
Post by palomaeki »
Here's some shots kindly provided by PGS. I'm also interested in this since I was asked to if I could build something like it for a friend. Surprisingly nobody seems to have traced this?
Nothing too complicated - haven't compared it to the Black Eye etc. yet but it must be a revision of something familiar? AMZ Booster maybe?
Bononoob
Been thanked: 68 times
Post by Bononoob »
So a buddy lent me a EQD Arrows so I traced it
Here's the Eagle Schematic and some gutshots
EQD Arrows Schem.png (8.79 KiB) Viewed 7936 times
storyboardist
Has thanked: 85 times
Been thanked: 225 times
Post by storyboardist »
You're really close. I traced this about a year ago, and the value off the resistor off the emitter in your schem is way too high. Should be 1.3k. And the 100k at the output goes to ground. If anyone needs a PCB I still have a few. Schem attached.
storyboardist
Aw heck, here's vero, perf, and etch layouts too.
Bononoob
Post by Bononoob »
Damn how did I mess this up
Anyway thank you for the corrections and boards that's awesome
Science is art. Art is science.
https://electric-canary.com
FeVeR2112
Has thanked: 47 times
Been thanked: 60 times
Post by FeVeR2112 »
What does the R2 100R resistor do here? Seems unnecessary.
guiddruid
Has thanked: 22 times
Been thanked: 12 times
Post by guiddruid »
FeVeR2112 wrote:What does the R2 100R resistor do
Limit current through D1 to ~90mA when the power is connected backwards.
FeVeR2112
Post by FeVeR2112 »
Would you not just use the diode for polarity protection? A 4001 diode (1A) can handle pedal supply which are mostly 500mA at best.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
I always understood that a ~100 ohm resistor + large electro capacitor together form a filter for the power that reduces hum.
guiddruid
Post by guiddruid »
FeVeR2112 wrote:Would you not just use the diode for polarity protection? A 4001 diode (1A) can handle pedal supply which are mostly 500mA at best.
Without the resistor, you're relying on the power supply to gracefully limit itself - not pop a fuse, burn out a voltage regulator, or blow D1. Best practice is to assume worst case conditions, which for this protection circuit would be a very low output impedance for the PSU.
Nocentelli wrote:I always understood that a ~100 ohm resistor + large electro capacitor together form a filter for the power that reduces hum.
C4 would need to be moved to be in parallel with D1 for R2 to help with filtering noise. That would also protect C4 - the only polarised component in the design (other than the diode) - from reverse voltage.
warsavius
Been thanked: 13 times
Post by warsavius »
I recently did on the perfboard this nice pedal, it's for a friend, who asked for a mod on frequency boost. So I put a switch on c2 to choose from 4.7n 47n and 100n, a common mod in rangemaster.
But with this layout nothing happen, no sound change. Just the original (very nice indeed) sound.
How can I explain this? :scratch:
Has thanked: 183 times
Been thanked: 468 times
warsavius wrote: 12 Dec 2020, 17:30 I recently did on the perfboard this nice pedal, it's for a friend, who asked for a mod on frequency boost. So I put a switch on c2 to choose from 4.7n 47n and 100n, a common mod in rangemaster.
Input impedance is too high to give treble booster sounds with those C2 values. You'd have to go considerably smaller than 4,7n to get a significant bass cut. And there's already so much low end from 47n, that 100n wouldn't make any difference you'd hear.
Try: 500pf, 1nF, 2.2nF... small values like this for a treble booster sound. 10nF or 22nF would probably be more than enough for full range sound.
CheapPedalCollector
Has thanked: 452 times
Been thanked: 147 times
Post by CheapPedalCollector »
Pretty lame they charge so much for a pedal with $5 worth of parts in it.
Intripped
Has thanked: 991 times
Been thanked: 305 times
Post by Intripped »
Yes, it's true , but it's also true that in terms of factory costs of the finished pedal it doesn't make a big difference if the PCB has 10 or 30 components
warsavius
Post by warsavius »
soulsonic wrote: 13 Dec 2020, 01:01
Ok, it's fine with switchable 4,7n and 1n input cap. Not too harsh like a Rangemaster, fully useful and reliable for single coils or humbucker with smaller cap. Thanks for the suggestion. :cheers [smilie=rlp_smilie_242.gif]
-X-
Post by -X- »
Looks like a Zvex SHO derivative :hmmm:
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
-X- wrote: 02 Jul 2022, 19:49 Looks like a Zvex SHO derivative :hmmm:
Or a “derivate“ of one million other simple gain stages. SHO uses a mosfet...
Ben N
my favorite amplifier: Ampeg J12D Jet
Has thanked: 198 times
Been thanked: 54 times
Post by Ben N »
Ummmm, no, not at all. It's a simple BJT NPN single stage boost - kind of similar to an LPB-1 or Gus Smalley's NPN Boost, with a tiny, subtle bit of tone shaping. There's nothing terribly clever about it, but it's a useful gadget for a variety of purposes. I build one and like it, but I'm not using it for the moment because my home amp has a solid state preamp, and I like this much better in front of a tube preamp. But I'm sure it will come in handy at some point.
I apologize for the off-topic post, but: Maybe we shouldn't be categorizing EQD as "boutique" anymore? Mass produced things you can find at any big chain store doesn't seem "boutique" to me. Same can be said for several other brands that were considered boutique in the past. Wampler comes to mind...
