Roger Mayer - Axis Fuzz
Re: Roger Mayer - Axis Fuzz
Postby Fanum » 23 Jan 2010, 01:53
Well, the funny thing is that he initially thought the fuzz with these components .... Perhaps the original Axis Fuzz them had ... Octavia have ... and the axis fuzz is its close relative ...
Of course, now no longer used (do not see the components and even the slopes, as can be seen from the new AF).
Ah !.... confirm .... the sound changes enough .... with or without. (ie audible)
Excuse my poor English
Fanum
P.S for you which is the right hfe of the transistors?
Fanum
Postby swt » 23 Jan 2010, 11:55
i have a bunch of the motorolas, so let me check for hfe of the ones that bias ok....
swt
Have thanks: 10 times
Postby Fanum » 05 Feb 2010, 19:02
swt wrote:i have a bunch of the motorolas, so let me check for hfe of the ones that bias ok....
UP :P
Fanum
Postby swt » 09 Feb 2010, 12:26
ups sorry for the delay...i'm on holidays. Give me a couple of days and will check them...
swt
Postby Fanum » 20 Feb 2010, 23:59
swt wrote:ups sorry for the delay...i'm on holidays. Give me a couple of days and will check them...
Don't worry.. :popcorn:
Fanum
Postby andres_a884 » 10 Jun 2010, 17:27
Does anyone Know if this layout can be build with AC127 and Ac128 I have a couple of them and want to use it.
download/file.php?id=6119&mode=view
Thanks,
Ariel.
andres_a884
Postby andres_a884 » 13 Jun 2010, 16:45
Built the PTP board and works perfectly, now I´m testing AC128, AC127 and B324 germanium transistors searching for the goods ones, with silicon transistors works fine.
Some photos,
http://www.flickr.com/photos/38980696@N04/sets/72157624140962499/
Which is the best way to test germanium transistors ?.
Thanks.
andres_a884
Postby DougH » 14 Jun 2010, 21:28
Fanum wrote:Well, the funny thing is that he initially thought the fuzz with these components .... Perhaps the original Axis Fuzz them had ... Octavia have ... and the axis fuzz is its close relative ...
The story from 'somewhere' (RM?) was that this filter was needed in Europe but not in the U.S. (?!?!?!?) Smells like BS to me... I suspect it was part of whatever circuit he used to develop the Axis Fuzz from, and the Octavia, and whatever else he also based on it. Then at some later date he realized it wasn't needed. Just a guess... YMMV.
"You have just tubescreamered or fuzzfaced yourself " -polarbearfx
DougH
Have thanks: 23 times
Postby analogguru » 15 Jun 2010, 07:34
analogguru wrote:The use of this RC-Network is described here on page 3:
http://www.tcaas.btinternet.co.uk/jlh1970.pdf
These components reduce the (inaudible) High-Frequency-response and are used to avoid High-Frequency-oscillation. Therefore not really needed in this application and omitted.
Have thanks: 116 times
Postby DougH » 15 Jun 2010, 13:39
Thanks AG for clearing that up. I thought this circuit came from somewhere else (i.e. not RM).
DougH
Postby GBlekas » 05 Mar 2011, 15:15
IvIark wrote:I may as well add this to the thread for anyone interested in turrets or ptp wiring:
On Fuzz Central there is a recommendation to omit the 220R + 1nF in column 5 so it may be worth experimenting.
I was looking at the layout and just wanted to point out a duplication of a cap.
I believe only one of these are needed, if I am following the schematic correctly.
Looks cool though so thanks for your time!
George
GBlekas
Have thanks: 2 times
Postby IvIark » 05 Mar 2011, 15:27
Yes you're right, it's been duplicated so you could make it 1 column narrower. It looks as though I've shown the volume pot backwards as well, you should swap 1 and 3. That'll teach me to interpret pots on schematic literally, although in my defence that was one of my early layouts! :D
IvIark
Has thanked: 668 times
Have thanks: 682 times
Postby andregarcia57 » 13 Sep 2019, 17:26
Hello ... Does anyone know Hfe values of Q1 and Q2 from the original RM?
andregarcia57
Have thanks: 87 times
Postby Cigano23 » 07 Oct 2019, 19:44
andregarcia57 wrote:Hello ... Does anyone know Hfe values of Q1 and Q2 from the original RM?
They're around 150-200hfe.
Cigano23
Users browsing this forum: Cloud10 and 9 guests
