Looking for 2N408, 2N2613 and 2N270 have rare types to trade
Hi All,
I am looking for 2N270, 2N2613 and 2N408 to build a Fuzzrite and a Maestro. I have a few 2G381, Mullard OC44, OC71, OC81D, OC76, SFT337, SFT363, NKT213, AC125, AC128 etc. to trade if any one is interested.
Many thanks.
Many thanks.
- turbofeedus
https://www.ebay.com/itm/RCA-2N270-GERM ... Swidpde8oAJDG wrote:Just looking for 2n270 now.
Thanks.
- Lani
Not sure if your still looking but I I have about 30 2n408. Full length leads but they are a little tarnished... As to be expected cause they are almost 50 years old.
The ones I got are a bit gainy so I am definitely interested. Do you have one around 50 with low leakage? What are you after in a trade?Lani wrote:Not sure if your still looking but I I have about 30 2n408. Full length leads but they are a little tarnished... As to be expected cause they are almost 50 years old.
Thanks very much for the link. I think those are a bit butchered and a bit pricey considering they are unmeasured.turbofeedus wrote:https://www.ebay.com/itm/RCA-2N270-GERM ... Swidpde8oAJDG wrote:Just looking for 2n270 now.
Thanks.
- Lani
Just pulled them out and I could only find 15... Two with shorter leads. Not sure what the leakage is on them but if you recommend a circuit I will gladly test them to see if they are what you need. If you still want them after I test them we will figure something out I'm sure.JDG wrote:The ones I got are a bit gainy so I am definitely interested. Do you have one around 50 with low leakage? What are you after in a trade?Lani wrote:Not sure if your still looking but I I have about 30 2n408. Full length leads but they are a little tarnished... As to be expected cause they are almost 50 years old.
- Lani
The 66Hfe one(11) is labeled wrong it's .11mA not uA... Sorry bout thatLani wrote:This is what I can find right now
- Manfred
- Has thanked: 1675 times
- Been thanked: 1359 times
Look here you will find recommendations regarding hfe and leakage currents.
http://diy.smallbearelec.com/Projects/F ... rsRite.htm
- Lani
PM SentJDG wrote:Thanks Lani. A couple of those look good. What would you like to trade? If you let me know I will post some readings, I have a DCA55. Cheers.
- Lani
I'm going to go through them again tonight and sort them better. I'll PM you when I do.JDG wrote:Still looking for 2n408 and 2n270. Thanks.
