MXR - Bass Octave
MXR - Bass Octave
Postby Stompmodder » 27 May 2008, 18:06
This is the pedal i want to RE. Currently i work on the suface mont pcb to extract the schematic. If somebody is interested about this project, let me know.
For this message the author Stompmodder has received thanks:
goaltoday (29 May 2011, 09:39)
Stompmodder
Have thanks: 5 times
Re: MXR Bass Octave Guts
Postby Alex Frias » 27 May 2008, 18:36
Always interested... But could you tell us what your impressions about its tracking?
Alex Frias
Have thanks: 14 times
Postby Stompmodder » 27 May 2008, 19:27
Alex Frias wrote:Always interested... But could you tell us what your impressions about its tracking?
This is my friend pedal, and when i try it, i've fond the best clean octave down effect for bass. Better than boss OC-3 in my opinion. When the Pedal will be RE. I need you to test and see if my schematic is functionnal. I know this project is not for beginner but many musicians are looking for a good clean octaver schematic. The PCB is surface mont. Ic's and resistors are labelled. Capacitors are not labelled BUT can be read with a capacitor meter.
5 IC's , 6 TRANSISTOR, 3 DUAL DIODE IC'S AND A BUNCH RESISTORS AND CAPS. I feel this project can be done with traditional parts.
Stompmodder
Postby puppiesonacid » 27 May 2008, 20:47
looks very cool man, I definetly would be intrested to see it when you reverse this one.
puppiesonacid
puppiesonacid
MXR Bass Octave SCHEM
Postby Stompmodder » 02 Jun 2008, 18:35
This is my contribution to this forum. If you test this schematic, please report. I put a lot of energy to extract the schematic on the SM PCB . This effect track very well any notes on the bass but have some miss with the low E and F. Sound better than Boss Octavers. Enjoy!
ggedamed (29 Jan 2011, 18:16)
Stompmodder
Postby puppiesonacid » 03 Jun 2008, 06:13
didnt the shin ei something or other have a really good lower octave tracking? is the mxr close to this or something else? just wondering...
puppiesonacid
Postby soulsonic » 03 Jun 2008, 07:26
Thank you, Stompmodder - excellent work!
I have been studying octave circuits recently, and this is a valuable addition to my notes.
Has thanked: 56 times
Have thanks: 280 times
Postby arctumeda » 03 Jul 2008, 18:09
hum I'm searching to make this pedal on a stripboard. Has anyone a layout for this pedal, or I must to made it myself ?
Regards
Guillaume
arctumeda
Re: MXR - Bass Octave
Postby modman » 04 Jul 2008, 14:25
Great work Stompmodder (welcome btw)
I added this schematic to the index page here.
Has thanked: 3283 times
Have thanks: 611 times
Postby s_scud » 29 Jul 2008, 07:35
Please! there is somebody whit a big heart who can make a vero for this???
:thumbsup
THANKS!!!
s_scud
Postby Alt-me » 16 Sep 2009, 12:36
Hey guys, can somebody please PM me the Schematic?
Much appreciated
Alt-me
Postby OC26 » 16 Sep 2009, 12:43
Excellent. I wasn't aware of this.
OC26
Have thanks: 4 times
Postby mictester » 16 Sep 2009, 19:20
s_scud wrote:Please! there is somebody whit a big heart who can make a vero for this???
:thumbsup
THANKS!!!
I'll get one done in the next few days. I'm a bit busy at the moment, but I'll get it done!
mictester
Has thanked: 33 times
Have thanks: 806 times
Postby mictester » 16 Sep 2009, 19:26
:thumbsup
THANKS!!!
However, a look at the circuit schematic suggests a few errors. The use of the 4013 and the 4016 aren't quite right. I'll have to work out how it's meant to work...
mictester
Postby lsantis » 08 Dec 2010, 22:57
nothing new about this??
lsantis
Postby Brainbender » 12 Dec 2010, 16:40
too bad, i'm also interested...
Brainbender
Has thanked: 21 times
Have thanks: 6 times
Postby pinio » 27 May 2011, 11:56
Me too....
pinio
Postby seedseed » 29 May 2011, 05:24
me three
seedseed
Postby retna » 29 May 2011, 10:01
i've got an original issue/version of that pedal, i just need to dig it out, and take some photos of it if you want? if i remember correctly, it really didnt sound that 'great', hence why it never made it on to my gigging board(s). oh well... :?
eric
retna
Postby Stompmodder » 31 May 2011, 02:33
mictester wrote:
:thumbsup
THANKS!!!
Hi guys,
This is a block schematic of the circuit. I'll try to explain how the circuit work. The schematic have maybe few errors but the use of 4013 and 4016 are correct.
The most important block in this octave pedal is the tracking circuit. (TRACKER CIRCUIT) in the file. This block convert the fundamental frequency of the input signal into
two digital signals. SET of 1 or 9V and RESET for 0 or 0V. These 2 signals put together generate exactly the same frequency of the fundamental frequency. Except this signal is a SQUARE SIGNAL.
Example: if you play an A note:
Fundamental frequency is 440Hz sine wave. The TRACKER circuit generate a 440HZ SQUARE FREQUENCY.
The Frequency Deviser block use the IC 4013 to devise the 440HZ to 220HZ. This square frequency is now a octave down for the fundamental frequency.
If you try to listen a audio square signal into a speaker, you will hear a electric razor type of sound. To Smooth this frequency, we use
The block SQUARE TO SINE WAVE. This block is designed to convert this frequency to a new sine wave of 220Hz frequency.
This frequency is now Mixed to the original frequency. Each signal can be adjusted individually by two potentiometers DRY and OCTAVE.
I hope that can help and sorry for my bad english!
Stompmodder
Stompmodder
Next
Users browsing this forum: dgc85, fretless, MSN [Bot] and 7 guests
