tschrama wrote:Hi,
I made a few versions, all with BC550C transistors.. (selected Hfe = 580/620)...I haven't found any 2N5088, but I would love to try those.. I finally build one version with transistor sockets, so I can experiment a bit more, but I haven't done that yet...
anyways, the circuit sound great, lot's of sustain, I love the 'flat EQ' switch, that I use alot.. the 220nF caps might be a key ingredient for the circuit..
goodluck,
Thijs
PS
I would love to build a Pink Flesh... is that OK with Skreddy? Someone has a circuit?
tschrama wrote:Waooww, awnsered by the man him self! Thanks for the hints! You're a great guy and I am very impressed things you have made. You remind me of Nelson Pass, a HiFi guy roaming around at http://www.diyaudio.com.. take it as a compliment, you have similar traits as him.. good ears and a clear vision that reflects in his designs..
I wil surely make a 'pinkish muff' version this week..!
Many greetings from The Netherlands,
Thijs
tschrama wrote:thanks! I was wondering about tthe LowPass filter.. I think we could also add a cap around the collector resistor of the output stage.. as a fixed fizzz-filter....
Can I post a schematic... could I send it to you?
Chrzz,
Thijs
mattpas wrote:If I have some 2N5133s should I use four closely matched or are there spcific places to put lower gain and higher gains?
Skreddy wrote:mattpas wrote:If I have some 2N5133s should I use four closely matched or are there spcific places to put lower gain and higher gains?
Lowest noise go first, use ears for gains locations (try socketing the transistors).
mattpas wrote:Skreddy wrote:mattpas wrote:If I have some 2N5133s should I use four closely matched or are there spcific places to put lower gain and higher gains?
What efh do you recommend for the Q1?
Skreddy wrote:mattpas wrote:Skreddy wrote:mattpas wrote:If I have some 2N5133s should I use four closely matched or are there spcific places to put lower gain and higher gains?
Hfe? Depends on the transistor. I think about 500-600 is a good range for some types. Just depends, though.
Users browsing this forum: nooneknows and 20 guests
