Sola Sound - Tone Bender Mark I (1965) [schematic]
https://reverb.com/item/2547355-1965-so ... one-bender
I posted this a long time ago, not a lot of interest. To me it was a holy grail find. You can use the Zonk Machine PCB that's floating around with a little rework. Enjoy!
-Van
BTW: 9VDC
-Van
BTW: 9VDC
- call1800ksmyazz
Very cool Vanessa. Thanks!
- RLBJR65
Nice! Must have missed it the first time around.
- MoreCowbell
- Transistor Tuner
Gracias !
Elizabeth the 1st. I could not shrink down the Mona Lisa to avatar size and make it look good. Funny the original [Mona Lisa] was avatar size out of the gate.markm wrote: Wasn't the mona lisa there a moment ago?
The 2C382 are very hard to get, if you subs it with other Ge-trannies all values for emitter- and collector-Rs must be recalculated...
I reccomend to use trimpot, but you need the voltages of the original TB1 to adjust the trimpots to the correct values.
JHS
JHS
From an old post:
Q1 hfe = ?
Q2 hfe = 120
Q3 hfe = 92
I would guess based on others findings of the FZ-1 that Q1 is 50-70 hfe.
I'll add that this thing sounds great with those crap transistors you could never get yourself to throw away. It loves leakage, not off the charts but some leakage for all the Q's and a low value for Q1 really makes this one work.
Q1 hfe = ?
Q2 hfe = 120
Q3 hfe = 92
IMO it's an interesting circuit in some aspects...
That output, is using 2M2 in series with a 500K vol pot... But then lowering impedance before this there's a 47K to gnd.
I'd like to know why?
I know it could be achieved similar results with like a 47K in series with a 10K vol pot (instead of the values above) and pretty much similar impedance...?
I bet it may have an influence to the tone... a 2M2 resistor IN SERIES with a 500K vol pot...
Someone could try to make me (us) see what's the meaning of this?
Thanks in advance...
- bajaman
- Has thanked: 595 times
- Been thanked: 2058 times
Hello Kagaxdx
The 2M2 resistor would roll off a lot of the high frequency buzz or scratchyness in this circuit.
Cheers
ps: a well known high end HiFi stereo amplifier manufacturer used to connect a 75K ohm resistor in series with the CD input socket (one each channel of course) in his top end hybrid Stereo Amplifier. guess what - all the reviewers remarked on it's smooth sounding, less stident, less edgy top end response (more like a vinyl record) - (all the other inputs had NO series resistance).
Cheers
Thank you Baja,bajaman wrote:Hello Kagaxdx
Cheers
Then..... If you take a Fuzz Face a silicon one, you have usually more gain (hfe) and more frequency bandwidth (more treble/piercing highs), we could search for a low HFE silicon transistor (or piggback) and for the different high end response use this sort of "soothness"?
Take the output straight from Q2 colector and conect to a 470K resistor in series with a 100K vol pot...
- MoreCowbell
- Transistor Tuner
Ive done some similar experiments, and had mixed results. To be honest, the old "cap to ground" seemed to work better for me, as it retained more of the dynamic properties of the circuit.kagaxdx wrote:Thank you Baja,bajaman wrote:Hello Kagaxdx
Cheers
- MoreCowbell
- Transistor Tuner
No problem.kagaxdx wrote:Thank you Morecowbell, thats good to hear from someone that had previosly tried that.
That's the good thing: We always keep on searching ways to improve tone
Honestly, if I were building a MKI, I'd probably eliminate the 2M2 resistor and use a cap to ground, somewhere between 470pF and .001uF.
- analogguru
This maybe true for the Maestro Fuzztone. If it would be true for the Mk I, then somebody must have stolen it from this unit:There is a resistor missing on the schematic. It should have a 33K from the wiper of the Attack pot to ground.
http://82.110.105.12/stompboxes.co.uk/i ... oooiol.JPG
but what I can see is, that in reality R3 is not 470k - it is 180k, especially when I look at it from a different angle - like this:
Good catch AG.analogguru wrote: but what I can see is, that in realitiy R3 is not 470k - it is 180k, especially when I look at it from a different angle - like this:
What do you mean AG?analogguru wrote: This maybe true for the Maestro Fuzztone. If it would be true for the Mk I, then somebody must have stolen it from this unit:
- analogguru
As I said:Good catch AG
I only believe what I see with my own eyes
I mean, that the picture shows the original innards of a MkI and that I cannot see a resistor in parallel to the poti there.What do you mean AG?This maybe true for the Maestro Fuzztone. If it would be true for the Mk I, then somebody must have stolen it from this unit:
If you look at the near identical Maestro Fuzztone schematic (or guts) you will find this resistor. The MkI should be a clone of the fuzztone but wasn´t sold very often, maybe due to the patent of the Fuzztone.
IMHO for this reason the Fuzz Face circuit was used instead to avoid patent lawsuits. Nobody cared this time about silizium/germanium and whatever. The only important thing was that it should distort/produce a squarewave in any way.
The circuit was the "european/british answer" to the patent of the Fuzztone. A funny question is only, what came first: the TB Mk 1,5 or the Fuzz Face ?
That would require 10 transistors, I'm only counting 9 in this photo. There are no resistors on jacks or switches.alnico wrote:There is a resistor missing on the schematic. It should have a 33K from the wiper of the Attack pot to ground.
