Bogner Shiva schematic?
ech0es
Post by ech0es »
JHS wrote:
JHS wrote:Is the Diezel tone stack you're talking about the one from this thread?
No.
To me this tone stack looks more like it was copied from an Engl amp. Same issue like the stack in a Marshall 2003/4. At high volume it will do nearly nothing to the tone, a bit mid scoop, not more.
this tonestack is from the diezel VH4, we found a schematic of the tonestack and the input
TragicTravisty
Post by TragicTravisty »
ech0es wrote:
No.
links/pics/details?
ech0es
Post by ech0es »
Informations about the diezel VH4, used for the conception of the DIEFET pedal from techniguitare.com
I tried to draw the tone stacks of the four channels.
Channel 1: typical Fender tone stack
Channel 2: 470pf treble cap, 22nf mid and bass caps, 39k slope resistor, 1nf cap from mid pot wiper to ground
Channel 3 and 4: 680pf treble cap, everything else like channel 2.
http://picasaweb.google.com/aliasbarrylyndon/Diezel#
http://www.megaupload.com/?d=9RZ8JEEK
chromaticdeth87
Post by chromaticdeth87 »
holy crap! that had to suck staking all those turrets
TragicTravisty
worked this out on a tonestack calculater, the result for channel two is lots of high filtering, slight cut at 1khz (less than a fender), and a big bass boost at around 80 hz. thats without factoring in the cap from mid control to ground, and channel three has slightly more mids, and treble.
paulrodga
Post by paulrodga »
More about the Shiva schematic? What is the correct one?
erigm
Post by erigm »
chromaticdeth87 wrote:holy crap! that had to suck staking all those turrets
What turrets? I didn't see any. Did I miss something?
erigm
luchomack
Post by luchomack »
here...
Bognor_shiva.pdf
(33.34 KiB) Downloaded 518 times
luchomack
Post by luchomack »
other. i need the shiva power supply schematic...
Bogner Shiva.pdf
(222.2 KiB) Downloaded 454 times
luchomack
Post by luchomack »
preamp
Heph333
Post by Heph333 »
Sorry to resurrect an ancient thread, but what is up with that orphaned V1A tube?
luchomack
Post by luchomack »
v1a dont to use, its for other versions with circuit reverbs and others...
