Zvex - Box of Metal [traced]
I'll double check my build, too. I was in a rush to complete so maybe I'm wrong.
- andregarcia57
I am thinking about using this noisegate in a GT2, will work?
members/bajaman/Baja/Vzex/MoxofBetalGatesketch.jpg
- DimebuGG
OT: IMO, the GT-2 is not a noisy pedal if you're only using TLC2262 chips..andregarcia57 wrote:I am thinking about using this noisegate in a GT2, will work?
- bajaman
- Has thanked: 595 times
- Been thanked: 2056 times
UPDATE - the preset pot is set between 1k ohms and 1.5k ohms NOT 4K ohms as originally suggested.
- DimebuGG
what are those "72" diodes in the gate circuit?
culturejam,
is there any chance we can hear your build?
culturejam,
- culturejam
I don't have it anymore. Traded it to another guy.DimebuGG wrote:culturejam,
But it sounds dead-on to the commercial version. I tried them side by side.
- culturejam
So change the values in the tone stack.audioguy wrote:The EQ isnt that great. The mid control is too subtle.
- audioguy
I might tweak it a little bit. The overall sound of the distortion is nice, I would just like to hear a little more differentiation as I twist the knobs.
Madbeans layout is really nice... I thought it would be a little tight to work with , but it was perfect, well done!
Hi Guys,
Although I'm more of a low-gain type-a-guy, this could be fun to spend some hours on, especially since the nice, perfect layout of Madbean. Speaking of which, I've tried to download rev 1.0 of the project files and ended up with an error. Is the document still online or is that just me???
Rock on!!!
BSTGW
Rock on!!!
BSTGW
Oops, I may have relocated it. Here is the final rev1. All docs are 300 DPI.
- DimebuGG
Just want to share this. PCB can be mounted vertically like those in zVex's. Pots are equally spaced.
- bom.bmp (497.61 KiB) Viewed 3652 times
- audioguy
Nice layout Dime!
I just plugged the values into the Tone Stack Calc, and its no wonder I didnt like the EQ, its all pretty flat. When I go home tonight I'm going to tweak it to some more Marshall-y values. Those look like I'll get the sweep that I want. Im primarily looking at changing the 2n for a 470pf and the 47k I'll probably drop to 33k.
- DimebuGG
A previous post claimed it was a 180pF cap instead of 2nF on his original unit(not vexter series though).
- audioguy
OH MY GOD... I just dropped a 180pf in place of the 2n and this pedal now fucking KILLS!
I normally think ZV is a bit over rated, but he did a nice job on this design. Kudos to the guys that worked on R.E.ing it and to Madbean for the layout.
