Behringer - BDI-21 (TB+Mids Control+ Blend Control)
Postby goaltoday » 27 Aug 2007, 21:44
This is my modded Behringer BDI21. It's a clone of the sansamp bassdriver.
Outside
Ugly Inside :oops:
Besides the true bypass I've added a mids control ( the one STM published on diystompboxes) and a new blend control. I didn't like the old blend control because the clean signal was mixed before the EQ and I want my signal unaffected.
I'll add this mods to my DIY sansamp too. So I'm going to have the behringer clone and my own clone. :lol:
goaltoday
Postby soulsonic » 27 Aug 2007, 22:05
Cool.
You should post up those mods here.
Has thanked: 56 times
Have thanks: 275 times
Re: BDI21+TB+Mids Control+ Blend Control
Postby Harold » 09 Nov 2008, 19:14
goaltoday,
I can't seem to find the mid control mod you're talking about! Could you explain what to do and/or point us to the post on diystompboxes?
-tnx!-
DIY-Layout.com: Online stripboard layouts
Harold
Have thanks: 21 times
Postby goaltoday » 09 Nov 2008, 23:38
I used this schematic
Just changed some cap values to taste.
goaltoday
Postby Harold » 10 Nov 2008, 10:47
goaltoday wrote:I used this schematic
The Bass and treble control on my Sansamp Bass Driver are quite all right as is, but I'm really interested in the mid control.
Could you post a picture of how you've implemented this schema? I'm not quite a schematics expert (yet), so I'm not quite sure what X5 is, and where to put the mid section in the sound path...
Would it also be possible to add a second potentiometer to change the freq of the mids? (semi-parametric)
-H-
Harold
Re: Behringer - BDI-21 (TB+Mids Control+ Blend Control)
Postby samurai1993 » 10 May 2011, 03:21
Sorry for bothering you buds, but I'm in a hurry. Last week I lend my BDI21 to a friend, and he connected it to a 9v source, but with inversed polarity. The thing heated and after a while he said it smelled like something was burnt. I checked the circuitry and all that I could found was a blowed up resistor. All in all, the pedal itself it's ok, if you use the battery input, it works ok. The problem is, I couldn't find the value of the resistor, nothing indicated on the pcb and the resistor itself was lacking any colored band coding. Could you help me? In the pcb is indicated as the R37, just at the side of the 9v input.
Thanks for your time!
samurai1993
Postby Harold » 10 May 2011, 09:02
samurai1993 wrote:The problem is, I couldn't find the value of the resistor, nothing indicated on the pcb and the resistor itself was lacking any colored band coding.
If it's used as polarity protection (in series with +9v), my uneducated guess is that it's only 47R or 100R.
Check this topic for more info: viewtopic.php?p=109979#p109979
Harold
Postby yiye777 » 13 Aug 2014, 03:01
R37=330 ohm
yiye777
Postby alanamps » 11 Dec 2014, 11:25
I had the same problem - burnt out R37. The markings on the pcb said 330R but that didn't work - too much voltage drop across it (6.5V). I read elsewhere it should be 12R which seems a bit low. My guess it's supposed to be 33R and the pcb is marked wrongly. I put in a 22R (didn't have a 33..) and it works fine. :D
alanamps
Postby gerodoth » 13 Mar 2018, 10:03
in my rev.1 pcb r37 is black and i can't see colors, but it works and tester shows 50 Ohms straight.
gerodoth
Postby bdp32 » 24 Mar 2018, 22:54
Ancient thread I know, but R37 in my unit is a 5% 12R 1/2W easy to read the bands on that resistor even with my eyes.
Just making a note for when someone fries mine for me :) :slap:
bdp32
Postby reddesert » 26 Mar 2018, 18:53
I also had a BDI21 (bought used) that worked on battery but not wall-wart, found that burnt component, and jumpered it with a parallel replacement. I can't remember if I used a low-value resistor or a series diode, but anything that works out to a relatively low voltage drop across it should work.
reddesert
Have thanks: 12 times
Return to Pimp-My-Cheap-Pedal
Users browsing this forum: reyonirico and 8 guests
