SMALL Drill Presses, anyone?
- Dr Tony Balls
Anyone have ideas for small drill presses?
I live in Brooklyn, NY, and dont have a shop/garage in which to keep a full sized drill press. Im thinking that there has to be something available in more like a bench-top size that I could put out of the way in a closet when I dont need it. Ive got a dremel, and I know they have the drill press stand, but all that would get me is a press for pilot holes, and i'd still have to use the hand drill for unibit stuff.
Try Harbor Freight.
Stability is an issue when using a hand drill in one of the old press stands from back in the 70's and 80's. But Harbor Freight might have a small model that would suit your needs and budget.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
I'm interested too !
Something just big enough to drill enclosures, and small/precise enough to drill PCBs without breaking bits
There was a previous thread somewhat related here : https://www.freestompboxes.org/viewtopic.php?f=10&t=4548
I've also seen some of these http://www.wolfcraft.de/jcatalog_genera ... ducts.html in stores, but it didn't look like a great deal to me, has anyone some feedback ?
(the product line is different for the USA, that one looks better with a guided chuck : http://www.wolfcraft.com/product_detail.cfm?id=58)
For completely different needs, the MultiMachine is a great low-tech device : http://opensourcemachine.org/
- kierc
- my favorite amplifier: Vox Cambridge 30 R Twin
- Completed builds: Clyde McCoy Wah with Whipple+Red Fasel inductor switch, Fuzz Face with own layout
- Contact:
I don't know how big this "Hobby Drill" is, but looks interesting for ~£50 - (UK supplier: Rapid, but may find something similar over by you?)
http://www.rapidonline.com/productinfo. ... leno=78422
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
I have a 'cheap' similar one of these.. great for drilling enclosures, but I tried one of those 0.8mm chuck (hand drill/screwdriver adapter) in it and it's far too imprecise. I can see the drill bit rotating around the centre(as in nearly 1mm diameter of play )kierc wrote:I don't know how big this "Hobby Drill" is, but looks interesting for ~£50 - (UK supplier: Rapid, but may find something similar over by you?)
do not want
- RnFR
home depot has a stand for a normal drill so that you can mount it vertically. it costs about 30 bucks. i've never tried it or anything like it, but it might work.
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
I use that. You could use a Dremel by hand, but my experience is that you are going to break a lot more bits. Bits used for pcb drilling are thin and cannot take horizontal pressure. PCB drilling without a drill press is not much fun, because its hard to keep the drill steady when doing such detail work.salocin wrote:Anyone ever used the Dremel workstation that turns it into a drill press? Could work well for drilling boards, not so sure about enclosures.
http://www.toolspotting.net/images/drem ... tation.jpg
I also use that the drill guide holes in enclosures, but I finish of using a Unibit for drilling all holes in enclosures. This is not the one, but gives an idea of what a Unibit, Multibit, whatever is.
- my favorite amplifier: JMP50
- Completed builds: Not in any particular order: Tweed delux, JMP50, 1987
Blue box, King of clones, Neovibe, P90, Cupcake, little green wonder, Honey bee, Fulldrive, lovetone brown sauce, Mayo type bigmuff, fuzz factory, box of rock, super hard on corel chorus.
PT80 x2 - Location: At the back of beyond and halfway to my elbow
- Has thanked: 27 times
- Been thanked: 1 time
I use a Dremel workstation with dremel attached to drill boards, no problems. The base is suffiecently heavy to use without fixing to a bench, not had any stability problems. Works well, just set the depth stop so you don't have to pull down much and gives good accurate results. Just use highest speed with the dremel.
Regards
Kevin
Regards
Kevin
