Mxr - Noise Gate / Line Driver
- .Mike
I have an 80s model block logo MXR Noise Gate / Line Driver.
I can take gutshots in about 1/2 hour if you want.
Mike
Mike
My website: America's Debate | My effects site: Just one more build...
- analogguru
This would be very nice.I have an 80s model block logo MXR Noise Gate / Line Driver.
- .Mike
Sorry about the crummy lighting. It's dark out on the east coast, and my camera takes terrible flash photos.
http://www.americasdebate.org/MXR-NGLD/
I hope that helps!
Mike
I hope that helps!
Mike
- analogguru
Very good pictures.....
One picture frontal from the back of the XLR-jack (from inside the case) would make it perfect.
It appears to me that the violet wire is connected to pin 3 (middle lug) and the other 2 pins are connected together - but I am not 100% sure.
- .Mike
- .Mike
Added #9 - 13. Hopefully that covers what you need. If not, let me know.
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
thanks .Mike
- analogguru
Perfect !!!
With this I can finish the schematic in the next couple of days.
BTW, your unit appears to be from summer 1980, but I couldn´t find any difference to the script-versions.
thanks again,
thanks again,
- andregarcia57
I put up this tonepad pedal mxr noise gate, and he is not working correctly, you could post schematic correct?analogguru wrote:All schematics on the web concerning the MXR Noisegate are wrong including the one from tonepad. Referring to version 2 from 2003 (which I have on my HD):
- Input cap is in reality 10n input resistor 10k.
- The 10µ electrolytic between the 22k and the FET is drawn in the wrong direction - plus should be on the Fet-side.
- Output cap is 10µ instead of 1µ.
- the capacitor before Q2 in parallel to the 100k is a 10n instead of a 1µ.
The source of the FET is connected to U/2 and the drain to the 10µ electrolytic
I thank you for your contribution.
André
- HEAD
Yeah, that would be great! Even more, if someone could make an updated/corrected layout for it (although there much better solutions out there - but all of them as far as I know are much more complicated) - which could be based up e.g. on the Tonepad layout. Since such simple noisegate projects are pretty rare out there.
Regards
HeAd
Regards
HeAd
- analogguru
Input resistor is still the wrong value (1k) - should be 10k.
Input cap the same: the drawn 47nF is in the original unit only 10nF.
Output coupling cap the same: 1µF after the opamp should be 10µF to match the original unit.
- Nikifena
^ hm, sorry.
I don't think, that 10k - 10nf and 1k - 47nf have a big difference. Also 47nf is better for bass responce (when bass guitar is using). Output cap can be between 1 and 10uF.
I make this noice gate, but I have one problem. When I play on low strings - A and E string I have some bad sound - like hrrrr or small overdrive.
I check everything with a scope. I have a clean signal after Q1, but after 22k between Q1 and next to fixed 10uf cap I have a scratched signal. I put 33pf between 1meg resistor in the feetback at IC1a, but this doesnt fix it. Also I change a few fets.
Any ideas how to get a clean signal at the output ?
- Güero 2.0
audioguy wrote:Beautiful build! What layout did you use?Güero 2.0 wrote:Hi, thanks to everyone that help me to build this unit.
I am use the actual layout and wiring for Line connector.
I used my own layout and the Tonepad schematic.
"Come squeeze and suck the day.Come Carpe Diem baby!"
layout pleaseGüero 2.0 wrote:audioguy wrote:Beautiful build! What layout did you use?Güero 2.0 wrote:Hi, thanks to everyone that help me to build this unit.
a built one from tonepad layout bud it doesnt work. i really want noise gate
- ebuprofen
- Completed builds: http://ebupro.blogspot.com/
- Has thanked: 12 times
- Been thanked: 12 times
- Brainbender
I've found this:
