Effectrode - Tube Vibe
- guiddruid
This is the suspected microcontroller:
http://www.microchip.com/wwwproducts/De ... e=en010277
Once we have figured out which pins of this chip go where, it shouldn't be too hard to write some code which will work in a _similar_ fashion.
To get it _very_ close to the original will probably require some measurements of a working device, and will depend on exactly how the device is connected...
- Greg
Good start..
I'll try to do the resistors this week.
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
- borislavgajic
- Opamp Operator
so if we compare this two drawings....
.....I am very intrigued about power supply of this baby......so small,going on 12volt DC ..draws 3 tubes... ..great for all tube projects.....tiny amplifiers...........
somebody with greater knowledge (then mine) could help ........?
boris
and if there is someone with PHASEoMATIC....it would be great to see guts of that......just to see how RESONANCE pot is conected.......[/b]
boris
- first drawing.jpg (49.22 KiB) Viewed 2596 times
- MWichni
- Degoop Doctor
- my favorite amplifier: HI-WATT DR103
- Completed builds: Neo-Vibe, EH Big Muff Ram's Head, MXR Dynacomp, Demeter Compulator, Bk Butler Tube Driver, MXR Distortion +, Maxon OD880, MXR Phase 45, ProCo Rat, Colorsound Power Boost, BOSS CE-2, Rebote Delay 2.5, EH Electric Mistress, Fuzz Face, Tycobrahe Octavia, EH Pulsar. Custom made cabinet with 2x12" Celestion Vintage 30's.
- Has thanked: 7 times
- Been thanked: 57 times
Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
Regards,
Mariusz.
- borislavgajic
- Opamp Operator
MWichni wrote:Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
no I did not forget it,just wanted to show schem as soon as possible........AUDIO part is what was primary for me.......better layout....soon ...with tracks.......
you are right......when you have 12v DC ..it is not hard to get 5V regulated......
....What I would like to know how he gets 300V so elegantly
this is first time for me to trace twosidedboard so be patient please
boris
- MWichni
- Degoop Doctor
Well I think that he gets 300V using DC/DC converter 12/300V for example. This inductor is the part of that converter, because there is no need to get big current for the anodes of the tubes so the inductor is quite small. Hope you get my point.borislavgajic wrote:MWichni wrote:Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
boris
Regards,
Mariusz.
- borislavgajic
- Opamp Operator
Mariusz I get your point ,....and what I really hope to get is a drawing from you ....schematic as close as possible to Vibes power section....it is not much to ask?Well I think that he gets 300V using DC/DC converter 12/300V for example. This inductor is the part of that converter, because there is no need to get big current for the anodes of the tubes so the inductor is quite small. Hope you get my point.
Regards,
Mariusz.
boris
- MWichni
- Degoop Doctor
I'll try to draw the schematic for this one.
- borislavgajic
- Opamp Operator
MWichni wrote:I'll try to draw the schematic for this one.
great!!!!
- borislavgajic
- Opamp Operator
this is all I've done........ Greg...can you please check PCB traces that are not visible on photos......did I get them right
next is .....
1.......resistor values,cap(near volumepot)...... Greg_G
2.......Power section schematic..................... MWichni
3.......PIC programming................................ somebody craisy
that is all for now
boris
next is .....
that is all for now
boris
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
- chicago_mike
Boris, you are a sick, sick man!
Skyline FX 2013
- himister
Exactly. I totally agree. Sick man. If you finish this one it will be kick ass for sure.chicago_mike wrote:Boris, you are a sick, sick man!
Usually I wouldn't bother with SMD but.... Go for it.
- borislavgajic
- Opamp Operator
thanks......we all can do everything.....with little help from eachother
...so please feel free to contribute......LFO and POWER part is missing
...tube heaters are connected pin4...GND pin 5....12.6V
boris
hard part......for me is that PIC - LFO.....but somebody here is an expert for PIC-ing,and can do that in 45 minutes....problem are traces below parts,and you have to use imagination(if you don't have knowledge)I want to trace all those pedals...
http://www.effectrode.com/website/effec ... pedals.htm
...so...
....please if somebody have theese pedals,post some gut pictures
Tube-Vibe.................this one is in progress
Tube Drive
Delta-Trem
Phaseomatic Deluxe............would like to see this one very much
Vibra Chorus
thanks
boris
- MWichni
- Degoop Doctor
Hi guys, I see that the DC/DC converter is made using a microcontroller too. It's based on PIC12F675 if I read that correctly from the Greg's picture. Here is a part of the schematic which I can see without any problems. But there are traces under IC's and other parts that I can't see but I try to figure out as much as I can.
If Greg could make better pics of the lfo and power section it would be great.
Regards,
Mariusz.
Regards,
Mariusz.
- Greg
R1 = 82K
R2 = 22K
R3 = 1.8K
R4 = 1M
R5 = 22k
R6 = 1M
R7 = 1.5K
R8 = 22K
R9 = 22K
R10 = 10K
R11 = 10K
R12 = 390R ?
R13 = 22K
R16 = 1K
R18 = 10K
R19 = 10K
R20 = 1.5K
R21 = 1M
R22 = 22K
R23 = 22K
R24 = 22K
R25 = 22K
R26 = 22K
R27 = 22K
R28 = 22K
R29 = 22K
R30 = 22K
R31 = 22K
R32 = 22K
R33 = 22K
R34 = 100R
R35 = 100R
R36 = 100R
R37 = 10K
R38 = 10K
R39 = 10K
D2 = 15DN
D3 = B2G 03C 270
TR3 = 6CW
TR4 = 6CW
R2 = 22K
R3 = 1.8K
R4 = 1M
R5 = 22k
R6 = 1M
R7 = 1.5K
R8 = 22K
R9 = 22K
R10 = 10K
R11 = 10K
R12 = 390R ?
R13 = 22K
R16 = 1K
R18 = 10K
R19 = 10K
R20 = 1.5K
R21 = 1M
R22 = 22K
R23 = 22K
R24 = 22K
R25 = 22K
R26 = 22K
R27 = 22K
R28 = 22K
R29 = 22K
R30 = 22K
R31 = 22K
R32 = 22K
R33 = 22K
R34 = 100R
R35 = 100R
R36 = 100R
R37 = 10K
R38 = 10K
R39 = 10K
D2 = 15DN
D3 = B2G 03C 270
TR3 = 6CW
TR4 = 6CW
- borislavgajic
- Opamp Operator
great!!!! thanks Greg............please...I could not read value of output condenser......one conected to volume pot......?
boris
this is almost doneIf Greg could make better pics of the lfo and power section it would be great.
Regards,
Mariusz.
boris
- borislavgajic
- Opamp Operator
R1 and R19 on anode (pin1) tube1......looks little strange to me.......I would say that signal should go from pin1 through C to the rest of the circuit.........
what is the reason of this topology? (smaller signall for blending?).... did I make correct schem?
are those resistors 1W?
boris
p.s.
any progres with power section?.......sharper pictures of that part?
boris
p.s.
- toneman
- my favorite amplifier: anything that works
- Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
- Has thanked: 183 times
- Been thanked: 45 times
Has it been determined if this is, 4 sure, just a 2-layer pcb?
or is it a 4-layer?? (with "poured gnds" on the top and bottom.)
Yes, traces under the ICs are difficult to figure out if U can't lift the IC.
If the HVPS uses part of a PIC, that's gonna be a sticky also
Determine if there is (analog)feedback to the PIC for the switcher.
If not, it's just free-running and can substitute a 555 for the pulsing.
a 12V to 200V DC-2-DC PIC converter would be trick
but, 555 boost converters aren't that hard to build
As Boris said, go for the signal path first
U can build power supplies several ways....the tubes won't mind
Great work so far
afn
T
Great work so far
afn
T
Tone-to-the-Bone
