Anyone build your own power supply?
Frequently asked questions regarding powering your pedal.
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
Hi all.
I'm reaching the point where it would be good to have my own nice, regulated, multi-unit power supply. I know the Voodoo Labs box is kinda the gold standard supply box, but it can't be THAT difficult to make one. Anyone got suggestions or schematics for such a thing? What do you use?
jonfoote
Post by jonfoote »
theres a couple of schematics on tonepad.com
but ive never built one
elrengofa
Been thanked: 33 times
Post by elrengofa »
http://audiocosas.es/Intermedios/fuente.html
you can use this pcb and replace the 7809 by a 7812 if you want 12V
Jarno
my favorite amplifier: Something nice
Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 81 times
Post by Jarno »
There's a bipolar power supply on general guitar gadgets, but that's a single +9 and -9. I hacked off the +9 part and copied it a number of times putting all the sections on one board. I now have one board with 1x -9 (for positive ground pedals) 2x +9, 1x +12 and 1x +24. I have yet to connect it to AC though, I have the board etched and soldered, but that how these things go......
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
that looks good!
Could you please post the layout and pnp?
KindaFuzzy
Has thanked: 79 times
Been thanked: 257 times
Post by KindaFuzzy »
Check out this post: [url]https://www.freestompboxes.org/viewtopic ... t=4512[url] , it's got all the info on the one I built.
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
what volts ac adapter you are using?
ur using 12v?
KindaFuzzy
Yes, 12v @ 1.25A switching power supply meant for a laptop that I got at Value Village for 3 bucks or something. Any wall wort with 12-18 volts should work fine.
quaternotetriplet
does the higher the voltage of the adapter the more quiet will it be?
the resistor is 100r right? or is it 100k
KindaFuzzy
I have no idea if a higher voltage will make it quieter, but the closer to 12v, the less voltage the regulators have to drop, making for cooler operation. Any less than 12v, and you may not get the voltage regulators to work properly. The resistors are 100 ohms not 100k.
quaternotetriplet
thanks. :applause: :hmmm:
