Dr.Z For All
- SPeter
- ansil
- my favorite amplifier: my hughes and kettner blue 30r
- Completed builds: 3 jcm 800 builds
4 vintage plexi builds
2 bogner ecstasy preamps [both for personal use]
10 marshall guvnor mods and builds
100 jungle kat boosts
too many penguin love's to count.
5 blues pearl purplexed
dozen tube screamer fulldrive whatever you call them variants
hell i can't type this long it will piss off people what can i say i have been doing mods on toyz appliances gear sex toyz computers and such for 27 years. i started when i was 6 taking stuff apart. - Location: cleveland tn
- Has thanked: 15 times
- Been thanked: 13 times
- Contact:
tried to download this it says file is private could someone email it to me or provide a link that isn't private???
- invalidcd
Try now i must of made it private by accident, should be good to go.ansil wrote:tried to download this it says file is private could someone email it to me or provide a link that isn't private???
- cortezthekiller
I had built an amp based on the Phoenix design a while back and it's awesome.
I used an old piece of staircase for the cabinet of it (used as a head).
- ansil
- Contact:
thanks for unlocking it for me i appreciate it. soon as i get my harddrives back online i will dig through to see what i can contribute
- SPeter
Hi all, does anyone have the schematic/more information about Prescription ES Model?
Sounds AMAZING!
Listen the 4-th clip!
http://www.drzamps.com/rxes.html
Thanks in advance!
Peter
Sounds AMAZING!
Thanks in advance!
Peter
- plexilover
anything bout the attenuator at the mini z?
thanks for pictures and schemos!
regards
regards
the scheme you posted, maz18jr reverb, is not properly correct, there are some mods to do.
this is the maz 18 NR scheme that i draw from some photos.
transformers specs and power section i think are pretty close to the original, for the rest is totally correct.
if anyone have some photos or more detailed schemes for power section or transformers specs, post it!!!
Has anyone seen the inside of the new Dr.Z jaz 20/40 amps?
The preamp supposed to be very similar to the maz preamp, but with a few slightly different values here and there.
One thing I'm sure of is that it has a 100k slope resistor and a 120pf treble cap in the tone stack.
There are a few pics of the jaz guts on the website of http://www.proguitar.de , check out the amps section.
Also the orange drop coupling caps seem to me like 715p series instead of the usual 418 dr.z branded caps, can anyone confirm this?
Anyways, thanks a lot and Merry Christmas.
Frank
Frank
- my favorite amplifier: Dr. Z's
- Completed builds: Marshall Plexi
Dr. Z mini
Dr. Z Carmin Ghia
several in works. - Location: Sumter, SC USA
Hi folks. Just finished building a Mini Z. Attached picture for you guys. Almost finished my Carmin Ghia. Since the Carmin Ghia and a Mazerati have the same circuit, I am collecting parts for the later to build as well. The differences I see is the GT has the main filter caps on board (no big deal), a choke (curious if anyone knows what value it is or a close idea), what the 10w resister hanging to the left of the circuit board is & what it is attached to, there is a small mica cap between two legs of the two .022 sprague 715p caps (cant tell what value it is). Any help here and anything I am not seeing?
Dan
Sumter, SC
Dan
Sumter, SC
