Zvex - Distortron [traced]
- John Lyons
(fixed thread heading name)
Has this been covered here?
I found a couple mentions and theories
in the Mastotron discussion but nothing
concrete.
The Videos sounded good, nice clean up and
string clarity.
John
concrete.
string clarity.
John
- soulsonic
It would be interesting to see how close it is to the Box of Rock, or it's actually something different.
- ~arph
Mr. ZVex himself allready told us it is the Box Of Rock minus the boost stage.
Only alteration I believe is a switch for the output cap..
I see no need in tracing. Unless it sounds totally different, I haven't listened to it. Might be a marketing trick to keep us from tracing it
- John Lyons
And then possibly the gain switch drops a stage?
I'd still be curious to see under the hoop just for
the sake of science.
John
John
- John Lyons
Yes but who knows really? Who's got one?
Based on that I'd say that the sub switch is probably the input cap, and the gain switch probably switches an sho stage in and out (static boost)dajm wrote:I saw a post from ZVex on another forum where he said that the Distortron is electrically identical to the Box of Rock's "distortron" or "rock" side when the Distortron's sub switch is on '3' and the gain switch is on 'low'
- culturejam
You can buy 'em used all day long for $120 on TGP right now.John Lyons wrote:Yes but who knows really? Who's got one?
- John Lyons
That would be assuming I had $120 to spend on one
- Mich P
Intersting option from ShortScaleMike :
"I think it's quite clear that the Distortron is just the Overdrive side of the Box Of Rock (3 cascaded SHOs and some filtering + tone control) with a three way subs switch which messes with probably the coupling caps between stage 1 and 2. I would guess the hi/low gain switch just shorts one of the SHO stage source resistors to ground."
Mich P.
Mich P.
- nooneknows
On Guitar Player it got an editor pick
- bumblebee
If you notice on the BOR it actually says "Distortron Engine" (not Distortion) so it seems like a no brainer to me that it is just the distortron side of the BOR plus switches of course.
Same concept as how the mastotron is identical to the woolly mammoth except for the impedance pot and subs switch and transistor change from 2N3904 to 2N2222.
I so dislike the modern digital world that I need to use semi-digital effects to emulate the analog world of cassette, VHS, and vinyl.
- John Lyons
Huh...seems like it....
- bumblebee
I'd still like confirmation myself too though...
- John Lyons
Someone here's got one surely.
(not that I'm calling you shirley )
- dune2k
*bump*
Any updates? I'm especially interested in the 2 switches that only the Distortron has (Gain Lo/Hi and Subs 1/2/3).
JOHNO wrote:P.S Great pedal for playing 70's porn music.
