Xotic - BB Preamp  [traced]
Orkspalter
Post by Orkspalter »
Heres a photo of the limited edition copper version of the xotic bb preamp. The website doesn´t say anything if its an improved version or only the same circuit in a different shiny box
elrengofa
Been thanked: 32 times
Post by elrengofa »
hi, i never post here, but i get this layout from a brazillian forum
bb_preamp_Guitarhero_final.rar
(299.8 KiB) Downloaded 1482 times
batteryacidtea
Has thanked: 57 times
Been thanked: 18 times
Post by batteryacidtea »
This layout by GuitarHero is verified, there's lots of working builds (i've made 3 using this layout). Pretty big, but sounds gorgeous.
Chris_mt
Post by Chris_mt »
The Schematics are not correct!, none of them!, the clipping diodes are across pins 6 and 7 with the cap, take a look at a degooped BB preamp pic i got of the net, I can not find the correct schematic anywhere on the net for this pedal......
Silent Fly
Has thanked: 27 times
Been thanked: 48 times
Post by Silent Fly »
Chris_mt wrote:The Schematics are not correct!, none of them!, the clipping diodes are across pins 6 and 7 with the cap, take a look at a degooped BB preamp pic i got of the net, I can not find the correct schematic anywhere on the net for this pedal......
:hmmm: I may be wrong but probably it just means that the the two sections of the op-amp are not in the same order. From the sound viewpoint, it shouldn't make any difference.
"Remember - all I am offering is the truth, nothing more". Morpheus
TheNixonWayne
Post by TheNixonWayne »
Yes I agree. Diodes are connected to pin 6 and 7... and this really not neccesary mean that these two stages are in different order. I believe clipping stage is stil the first but with second part of opamp. Sometimes is easier to make layout to use second gate in opamp instead of first gates (to avoid vias etc).
I attached a modified part of schematics (Douglas Castro's schematics) regarding screenshot and comments mentioned before. However as mentioned before this doesn't make any audiable differences (only layout purpose)
Nix
kram888
Post by kram888 »
batteryacidtea wrote:This layout by GuitarHero is verified, there's lots of working builds (i've made 3 using this layout). Pretty big, but sounds gorgeous.
I've just finished building this and it sure sounds close to the real thing but with more mids.
Danch
Has thanked: 43 times
Been thanked: 8 times
Post by Danch »
Hello,
yesterday I was looking at bb preamp guts, it has 4x1n4148 in the loop just added one in each direction on kusi schematic, C1815Y transistors, and IC was JRC for sure, but I could not see the numbers clearly, 4558BD maybe. This is just different version than before, probably less compressed because of two added diodes.
TheNixonWayne
Has anybody found out which circuit is in BB plus for second channel (B channel)? I have BB plus but it is hard to find out, it has something to do with green LED (for clipping) and transistors mentioned in earlier post. Channel A is BB preamp with only Tone knobe (withoud baxandall tonestack), but channel B has Mid, Bas, Tre.
TheNixonWayne
Oh I forgot there are two pushbuttons for hard/soft compression. I believe this switch only adds more clipping (sounds like that when pressing).
mrkaploca
Has thanked: 15 times
Been thanked: 12 times
Post by mrkaploca »
elrengofa wrote:hi, i never post here, but i get this layout from a brazillian forum
This is not completely correct and pins 2 and 3 of the first half of IC1 need to be swaped because the input signal meets first half of IC1 in an inverting input (pin 2)!
kram888
Post by kram888 »
Have you breadboarded this? I've already made a pcb version and it works tremendously close to the real thing.FYI, i have the real thing.
separanets
my favorite amplifier: peavey vtm-60
Post by separanets »
I designed a veroboard, but I'm so perplexed by loads of different schematics provided in this discussion that I can't be sure I've choosen a right one for veroboarding.
separanets
Here is my layout.
MRobi777
Post by MRobi777 »
Hi!
Just one question:
R23 resistance=? Ω
THX
Robert
MRobi777
Post by MRobi777 »
Hi!
Just one question:
R23 resistance=? Ω
http://darkfinn.googlepages.com/BBSchem.jpg
THX
Robert
SPeter
Been thanked: 80 times
Post by SPeter »
MRobi777 wrote:Hi!
Just one question:
R23 resistance=? Ω
THX
Robert
47K!
MRobi777
Post by MRobi777 »
THX :D
extremist
Post by extremist »
Hello guys! Does anybody knows what potentiometers used in xotic effects for tone controls (the ones with "middle point")? Brand/type?
stoske87
Completed builds: Phaser - it is in working condition :D
Completed Rat - NOT WORKING proper and i couldn't find bug :(
Completed Rat - NOT WORKING proper (i want this pedal but it is getting on my nerv!!!)
TS808 - i am insanely satisfied with this one!
eBow - work in progress, updates soon!!!
Post by stoske87 »
I used layout from a brazillian forum and it is working... I still need to find the way to get rid of hummmmmmm but it sound Andy Timmonish :mrgreen:
Pics tomorrow!
Thanks!!! (4 layout, support etc.......)
