Octavia PCBs for sale
Brink
Been thanked: 18 times
Post by Brink »
I have extra Octavia PCBs.
They fit in a 1590B as seen in the photo.
It can be built several ways as seen in the layout image.
My version, built with negative ground (so it doesn't need a separate power supply) and most of Soulsonic's mods from viewtopic.php?f=10&t=4579&p=68561 is absolutely killer.
$8 each by Paypal includes free shipping to North American, Europe, Australia, Japan, and most places.
PM me or use http://boardshop.weebly.com/
azrael
Has thanked: 35 times
Been thanked: 88 times
Post by azrael »
I've built on using the negative ground schematic...
What does your and soulsonic's version's mods do to the tone?
Brink
Post by Brink »
azrael wrote:I've built on using the negative ground schematic...
The mods take away all of the muddy low end and let the pedal produce a clear octave up on all strings. it gives a lot more definition to runs and chords/doublestops, changing the sound from a boomy mush to a full bodied singing tone.
I'll try to post a comparison MP3 tomorrow.
azrael
Post by azrael »
were you able to record an MP3?
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 51 times
Post by Hides-His-Eyes »
Is the transformer a standard part I could get hold of in the UK?
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
I'd did a search previously for replacement transformers here in the UK, and I'm pretty sure the LT44 could be used like Electron sell. I'd probably want to check the specs first. Also I'm not sure if the dimensions are the same which could obviously be a problem with a PCB.
Brink
Post by Brink »
azrael wrote:were you able to record an MP3?
Nah, my computer got buggered up and won't recognize my recording unit.
azrael
Post by azrael »
Thats cool. I just modified my Octavia to Soulsonic's more apparent octave setting, I'll see how I like it. I didn't change the other cap, I like mine fat sounding, haha.
I'm looking forward to the two PCBs I'll be getting from you, though! :cheers:
ilcaccillo
Post by ilcaccillo »
Hello Does the LT44 works in this circuit?
It seems the ratio is 20 to 1 and not the 3 to 1 that is recommended.
