Tycobrahe - Octavia  [schematic]
Re: Tycobrahe - Octavia
Postby sinner » 08 Sep 2012, 14:13
125B is for sissy boys and gay people (no offense Tube Exorcist)
Do one for DEM size-E with big audio transformer and wall powered. Should have bigger headrom that way
Has thanked: 1240 times
Have thanks: 1099 times
Postby rosetta » 12 Sep 2012, 04:37
PLZ. 1590b and sounds awsome.
rosetta
Have thanks: 2 times
Postby beedotman » 12 Sep 2012, 07:44
:lol:
http://www.turretboard.org 4 life!
beedotman
Has thanked: 426 times
Have thanks: 403 times
Postby sinner » 12 Sep 2012, 08:48
Are you trying to tell me that the enlosure size doesn't matter?
Sounds heretic
Postby beedotman » 12 Sep 2012, 09:12
sounds like complex :lol:
beedotman
Postby warioblast » 17 Oct 2015, 00:16
Link
I have a Tyco on my breadboard. I've tried 3 variations of the circuit; Mr Huge's Tycobrahe schematic, the hand drawn one and the Dunlop Octavio. No matter how I combine the dozen different types of transistors I have I don't get such a nasty and thick sound. :cry:
I've had the GGG Tyco and the wedge Dunlop octavio. I've watched a bunch of YT videos of different clones and I'm starting to believe the guys who claim that there is nothing like an original Tycobrahe.
warioblast
Have thanks: 3 times
Postby 4ab3c1b » 30 Apr 2018, 00:24
Howdy folks, first post here. This thread is pretty old with a good bit of "link rot", but from the surviving gut shots it seems Q1 is reversed from some of the common schematics floating around the web (GGG and Fuzz Central), with emitter connected to the 220r and 220k etc. The Jeorge Tripps-drawn schematic I have backs that up.
Can anyone confirm that the original Tycobrahe transistors are MPSA18, 2x 2N6519?
4ab3c1b
Postby dv8r601 » 07 Jun 2018, 02:28
4ab3c1b wrote:Howdy folks, first post here. This thread is pretty old with a good bit of "link rot", but from the surviving gut shots it seems Q1 is reversed from some of the common schematics floating around the web (GGG and Fuzz Central), with emitter connected to the 220r and 220k etc. The Jeorge Tripps-drawn schematic I have backs that up.
I can confirm the q1 is MPSA18. I'm looking for pics of the others as we speak.
dv8r601
Has thanked: 400 times
Have thanks: 18 times
Postby jreeves47 » 07 Jun 2018, 03:08
For this message the author jreeves47 has received thanks:
dv8r601 (07 Jun 2018, 22:12)
jreeves47
Has thanked: 41 times
Have thanks: 20 times
Postby dv8r601 » 07 Jun 2018, 22:39
Here ya go you can clearly see they're MPSA18 and MPS6519
dv8r601
Postby The Rotagilla » 20 Jul 2018, 02:04
I got the GGG kit the other day and have been collecting schematics along the way. Some observations...
1) With the exception of the early hand drawn and Dunlop schematics, all the others seem to be the same. Am I missing some glaring discrepancies?
2) The completed GGG kit left me underwhelmed so I started digging around and checking things.
- MPSA18's have a gain range of 500-1500hfe (according to current datasheets). I built the negative ground version which uses a 2N5087 and has a gain range of 250-900hfe. I did not measure mine yet.
- MPS6519's have a gain range of 250-500hfe (according to current datasheets). The GGG kit uses 2N4401's and they have a gain range of 100-300hfe.
3) I kept the 2N5087 because I didn't have anything else on hand but swapped the 2N4401's for 2N5088's and noticed an improvement. The fuzz portion sounds closer to what it should.
4) I had read that the diodes need to have low forward voltage ratings and some people posted that they got better octave results if the diodes were matched. I did swap out the Ge diodes GGG sent with some low forward voltage ones I had and got a stronger octave.
5) I have a Chicago Iron Octavia coming in tomorrow, I'll dissect and report.
The Rotagilla
Have thanks: 57 times
Postby The Rotagilla » 22 Jul 2018, 20:17
Chicago Iron Octavia #20.
1) It is a 1:1 clone of the Tycobrahe.
2) One of the electrolytic caps was blacked out and I'm not sure why because it was the 100µF.
3) Q1 had the numbers scratched off but the hFE was 1039 per my Peak DCA55 and the emitter does go to the 220k/220r.
4) Q2 and Q3 were MPS6519's.
5) The diodes were matched.
6) My negative ground GGG build sounds exactly the same.
That's all.
For this message the author The Rotagilla has received thanks: 3
Bernardduur (31 Jul 2018, 09:49), bossman (13 Aug 2018, 15:11), jalmonsalmon (24 Oct 2018, 16:39)
The Rotagilla
Users browsing this forum: OnTheTundra, Roanacho and 1 guest
