Dunlop - UV1-SC UniVibe Stereo Chorus  [schematic]
Postby Tonetweaker » 06 Feb 2011, 03:57
Hey all...
loubou mentioned wanting to get a peek at the Dunlop UniVibe Stereo Chorus, so here it is...
In Soviet Russia, dirt box fucks YOU!! ~ Seiche
For this message the author Tonetweaker has received thanks:
modman (29 May 2015, 16:11)
Tonetweaker
Has thanked: 25 times
Have thanks: 59 times
Re: Dunlop UniVibe Stereo Chorus UV1SC (gutshots)
Postby Tonetweaker » 06 Feb 2011, 04:27
More...
I tried to take some close in shots, since the board is pretty tightly spaced. Please excuse the "jittery hand" quality though. :P
The board is pretty tightly held in by the pots, switch and jacks... The jacks had recessed threads, so that once you remove the retaining nut, there's no overlap with the chassis to worry about. As with most modern Dunlop products, they did a nice job of putting the unit together. I wouldn't be too nervous if this one got knocked onto the floor by mistake.
Of all my chorus/vibrato units, this one is my favorite. Good range and control.
As always, if more info or pics are needed, let me know. I'll keep it apart for a day or two to see if anyone has any requests or interest in reversing it.
Cheers...
Steve
For this message the author Tonetweaker has received thanks: 3
andersom (06 Feb 2011, 14:10), lolbou (06 Feb 2011, 11:09), modman (29 May 2015, 16:11)
Tonetweaker
Postby Tonetweaker » 06 Feb 2011, 04:32
Sorry about the stray shot at the end. It got separated from the herd somehow, and there's no edit function available in this section. :lol:
Tonetweaker
Postby lolbou » 06 Feb 2011, 11:16
No bulb/LDRs in this one. Opamp phase stages. I guess it's all around the TL074, on the right of the switch...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 351 times
Have thanks: 240 times
Postby blackbunny » 06 Feb 2011, 13:21
lolbou wrote:No bulb/LDRs in this one. Opamp phase stages. I guess it's all around the TL074, on the right of the switch...
By golly, I think you're right....no lamps or LDR's. Completely different design to our "vintage" UV-1's.
How does it make that nice lush stereo chorus that Tonetweaker likes so much, using op amps?
blackbunny
Has thanked: 266 times
Have thanks: 110 times
Postby lolbou » 06 Feb 2011, 14:10
blackbunny wrote:using op amps?
That's what I supposed mentionning the TL074... Hey Tonetweaker, can you tell us what are the transistors around that 074 chip? Are these FETs?
lolbou
Postby Tonetweaker » 06 Feb 2011, 20:00
In fairness, you guys may not like this thing nearly as much as I do... My experience is fairly limited when it comes to effects. I don't have a lot of knowledge on what a lot of vintage circuits sound like, and when I hear a lot of my favorite recordings, I don't always know which "magic boxes" were responsible for that sound.
That's part of the reason I'm here, BB... To learn from the guys that really know about this stuff. :mrgreen:
That said, I really do like the sound of this thing. I use it all the time.
Yep. JFETs. All four are Fairchild 2N5952.
Incidentally, anyone know what the little codes above the ID are for? Each one has a small code like "B419" or "D346"... Doesn't seem necessary for the ID. Perhaps a lot number or some kind of date code? All 4 are 2N5952, but each one has a different code above.
Cheers...
Steve
Dirk_Hendrik (06 Feb 2011, 21:47)
Tonetweaker
Postby lolbou » 06 Feb 2011, 20:10
Tonetweaker wrote:Yep. JFETs. All four are Fairchild 2N5952.
Expect something looking like the Phase 90 4-stage circuitry... :wink:
lolbou
Postby Tonetweaker » 06 Feb 2011, 20:59
That would certainly explain the swirly quality... :lol:
I'm nowhere near familiar enough with these circuits to recognize close parallels to other effects. I'll have to dig up a schematic of the Phase 90 to give it a closer look. I'm sure I have it here somewhere. :thumbsup
Tonetweaker
Postby Dirk_Hendrik » 06 Feb 2011, 21:50
As this "univibe" seems to be a standard 4 stage phase with FET's it would be interesting to see in which extend it is following the concept of a phase90 with altered coupling cap values. Which is more or less what people tend to call "univibing" when they rape a phase90 with altered caps and call it a "univibe".
Has thanked: 255 times
Have thanks: 1025 times
Postby lolbou » 06 Feb 2011, 21:57
Any idea why there are two 4016 in it? Is it just for stereo purposes? :scratch:
lolbou
Postby Tonetweaker » 07 Feb 2011, 00:25
Dirk_Hendrik wrote:As this "univibe" seems to be a standard 4 stage phase with FET's it would be interesting to see in which extend it is following the concept of a phase90 with altered coupling cap values. Which is more or less what people tend to call "univibing" when they rape a phase90 with altered caps and call it a "univibe".
Could very well be, Dirk. I'm certainly no expert on either effect. It could be nothing more than a stereo Phase 90... but it sure sounds nice. :P
This thing definitely provides a pretty nice range of sounds. More than my Phase 90 does, I'd say... not that there's anything wrong with that pedal either. I love the sound of a good swirly phase effect.
Somebody cue the psychedelic music... :lol:
lolbou wrote:Any idea why there are two 4016 in it? Is it just for stereo purposes? :scratch:
Good question. I was curious as well... but as I mentioned, I'm not much on just looking at the board and understanding the circuit configuration. I wish I was, actually. It would keep me out of trouble sometimes... :lol:
The outputs are labeled "Left/Chorus" and "Right/Vibrato" if that provides any clue...
The output jacks are right next to each other... The single one on the other side near the AC input is the input jack. The jack closer to the pot is the left channel. The one closer to the switch is the right.
Tonetweaker
Postby Mafra » 05 Dec 2011, 16:08
Does anybody have the schematics of this pedal (UV1SC)?
Mine has a problem when I turn it off: a noticeable shriek that modulates with the "vibe". Works perfectly when turned on.
Any help appreciated.
Mafra
Dunlop - UV-1SC UniVibe Stereo Chrorus - revision B  [schematic]
Postby apollomusicservice » 25 Jun 2012, 11:04
After several unsuccessful attempts to get the schematic for Uni Vibe stereo chorus,
I decided to draw my version.
This schematic is not official and I apologize if there is some mistake somewhere,
but it helped me to fix my Uni Vibe.
I hope it will be useful
Reason: Topic moved and renamed ;-)
For this message the author apollomusicservice has received thanks: 8
blackbunny (26 Jun 2012, 00:35), Dirk_Hendrik (26 Jun 2012, 21:11), grizzlytone (14 Jul 2012, 06:32), lolbou (25 Jun 2012, 12:20), okgb (17 May 2019, 22:23), phibes (15 Jul 2012, 18:18), rocklander (03 Mar 2013, 21:27), sinner (25 Jun 2012, 15:13)
apollomusicservice
Has thanked: 65 times
Have thanks: 776 times
Re: Dunlop- UniVibe Stereo Chrorus - UV-1SC (PCB RevB)
Postby apollomusicservice » 27 Jun 2012, 17:27
This is a little corrected drawings with some measuring points to facilitate inspection of individual parts.
The test signal is 8oo Hz and the pedal is activated.
alexradium (16 May 2016, 17:08), blackbunny (28 Jun 2012, 02:52), DJGlukBH (01 Nov 2014, 10:55), Fender3D (29 Jun 2012, 14:21), garygad (08 Dec 2013, 05:45), grizzlytone (14 Jul 2012, 06:33), lolbou (27 Jun 2012, 20:58), phibes (15 Jul 2012, 18:20)
apollomusicservice
Postby apollomusicservice » 13 Jul 2012, 17:56
...and components placement
For this message the author apollomusicservice has received thanks: 5
blackbunny (16 Jul 2012, 00:51), grizzlytone (14 Jul 2012, 06:34), modman (28 May 2015, 09:09), pamaz (11 Jun 2016, 12:51), phibes (15 Jul 2012, 18:20)
apollomusicservice
Re: Dunlop - UV1-SC UniVibe Stereo Chorus
Postby rna » 17 May 2019, 12:00
Hi, very useful thread this. I have one of these on the bench for repair. The owner said it was zapped with over voltage at a live gig from a dogy generator.
After finding the TLC2264AIN had blown as well as the tl074 I still have to find out why the bypass is not working.
This looks to be an older version and on this board R9 is a 1ohm resistor. Maybe they just replaced it with a trace.
This one has a resistor mod (300K) pin7 of the Hex-Channel Buffer to the RR54 / R49 junction.
Great sounding pedal though. I can't wait to hear it with 2 amps connected.
rna
Users browsing this forum: Google [Bot], strangeblooms and 7 guests
