Voodoo Lab - Micro Vibe  [schematic]
Voodoo Lab - Micro Vibe - gutshots
Postby jrc4558 » 13 Apr 2009, 20:35
Hi! I've picked this one up used, and it's an older, not status LED model. Sounds decent, and a good range of speeds available. Anyone saw a schematic for it, or should we try and trace?
Cheers!
jrc4558
Re: VooDoo Lab Micro Vibe
Postby swt » 14 Apr 2009, 12:13
i think it would be nice to trace it, as it has a bulb, and i think an ic lfo to drive it. maybe we can make a good cross of the original audio path with a more stable ic lfo taken from this one.
swt
Have thanks: 8 times
Postby puppiesonacid » 14 Apr 2009, 15:27
swt wrote:i think it would be nice to trace it, as it has a bulb, and i think an ic lfo to drive it. maybe we can make a good cross of the original audio path with a more stable ic lfo taken from this one.
this whole thing is all IC, its a phaser modified to sound like a univibe ( and it sounds exactly like that) doesn't have that signature warble and the sweep distorts like a phase 90
puppiesonacid
Have thanks: 5 times
Postby jrc4558 » 14 Apr 2009, 15:42
Actually, the LFO is the same phase shift LFO as on the original UniVibe, maybe with some change in components and higher speeds due to lower operating voltage. It uses a dual potentiometer and, although I didn't trace it yet, looks like the original one. The phase shift stages are all IC, input buffer and mixer are IC too.
This is an older model, w/o the on-off LED. Maybe they changed the design for the newer issue...
jrc4558
Postby puppiesonacid » 14 Apr 2009, 16:04
yes, your absolutely right, I know. but what the ears interpret from this unit as opposed to the LDR based circuit are two completely different identities phase shifting. there was a good discussion about this in one of the univibe discussions..
puppiesonacid
puppiesonacid
Postby qwixzh » 09 Aug 2009, 00:17
just got one of this 2nd hand, want gut shots?
qwixzh
Postby Ripdivot » 09 Aug 2009, 05:10
No need to ask if we want gut shots, we always want gut shots. Go for it!
Ripdivot
Have thanks: 65 times
Postby qwixzh » 09 Aug 2009, 13:04
i shouldn't have asked. haha
I'll take some shots and post it later. :D
one thing i noticed, no light box for the LDR for this one. and seems purely opamp based.
qwixzh
Postby MWichni » 09 Aug 2009, 18:53
Interesting, so let us see the guts! :mrgreen:
MWichni
Have thanks: 56 times
Postby qwixzh » 10 Aug 2009, 05:41
here it is!
qwixzh
Postby qwixzh » 10 Aug 2009, 05:59
and more...
qwixzh
Postby qwixzh » 10 Aug 2009, 07:14
qwixzh wrote:and more...
cant edit my post above....
pic1
pic2
pic3
pic4
pic5
qwixzh
qwixzh
Postby jrc4558 » 10 Aug 2009, 15:54
Wow, this is sooo different.
I'll take some pictures of mine this week.
jrc4558
Postby MWichni » 10 Aug 2009, 19:11
Probably there is no light shield because it is housed in a box where is dark.
MWichni
Postby tcobretti » 12 Aug 2009, 02:50
I've had a Microvibe for a coupla years now, and I love it. It's easily my favorite modulator, and does a better imitation of the Univibe than any pedal I have heard that wasn't an actual Univibe. Well worth buying (or building if you are feeling ambitious).
tcobretti
Have thanks: 3 times
Postby GuitarManiac32 » 18 Aug 2009, 10:05
I think Micro Vibe sounds really great and is really well priced and has a nice size for a pedalboard. I have never had a chance to play a real univibe so I don´t know how accurate "univibe sound" Micro Vibe has. For my ears it´s definitely close enough for Hendrix stuff. Only thing I´d like to try is making it a bit brighter. It´s quite dark sounding (maybe real univibe is too...?). I have it always between my wah and fuzz/od pedals. After od pedals it does sound brighter but otherwise the sound gets worse. Does anyone have a solution to make it a bit brighter, some cap value change or something? I´d like to have it switchable too...
GuitarManiac32
Has thanked: 10 times
Postby pf_fan » 18 Aug 2009, 13:12
I saved this pic some time ago. PCB looks different...
pf_fan
Postby stonew » 26 Aug 2009, 16:15
:horsey: :horsey: :horsey: :horsey: good
stonew
Postby lolbou » 02 Aug 2011, 00:23
Hi all,
Here's the schematic... Traced from the unit I got second hand as birthday present! :D What's nicer than sharing you birthday present?! :wink:
My unit matches the one that can be seen in this post from a separate threads with guts from the Micro Vibe(s).
It is pretty well built and feels more reliable and strong than its Dunlop alike (especially the ribbon wire for the pots board). It shares the H11F3 fet-optocoupler with the Dunlop. It's used here as a FET switch that keep the signal away from the effect input (in the Dunlop it's used for the Vintage/Modern switch that disable/enable the input buffer). It might be a trick to try if you want to use DPDTs...
The LFO's classic, and the opamp phase stages are fairly close to the Danelectro Chicken Salad.
The driver circuit trimmer is factory set at 250 ohms. There is no protection resistor so mind your tweaking if you turn it down to 0!
Enjoy!
10/04/11 : update : change C4 to 470n.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
For this message the author lolbou has received thanks: 16
atreidesheir (04 Aug 2011, 00:15), candidate (05 Dec 2013, 11:48), Dirk_Hendrik (02 Aug 2011, 20:57), gena_p1 (08 Aug 2011, 01:12), Intripped (03 Apr 2014, 22:13), johnnyg (13 Jun 2013, 09:27), kymar (29 Aug 2011, 17:41), mictester (03 Aug 2011, 04:05), Nocentelli (02 Aug 2011, 08:55), reddo (02 Aug 2011, 03:45) and 6 more users
lolbou
Has thanked: 346 times
Have thanks: 234 times
Re: Voodoo Lab - Micro Vibe
Postby joeboo88 » 02 Aug 2011, 00:53
Is there something wrong with viewing the schematic or is it just me, Happy b day to you Lolbou! :mrgreen:
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
For this message the author joeboo88 has received thanks:
Dirk_Hendrik (02 Aug 2011, 21:15)
joeboo88
Has thanked: 276 times
Have thanks: 16 times
Next
Users browsing this forum: No registered users and 11 guests
