Carlboro - AD1 Echo / Analog Delay
Postby pknuits » 27 Sep 2012, 17:41
Faulting the unit and find C11 has been removed - No idea of uf value, anyone out there in the ether any ideas or do you even have a schematic of it :=D
pknuits
Re: Carlboro ECHO / Analog Delay AD 1
Postby Dirk_Hendrik » 27 Sep 2012, 18:35
Is that the big aluminum/green box?
Has thanked: 249 times
Have thanks: 988 times
Postby LaceSensor » 28 Sep 2012, 09:50
pknuits wrote:Faulting the unit and find C11 has been removed - No idea of uf value, anyone out there in the ether any ideas or do you even have a schematic of it :=D
my friends has one if its the big alu green box. maybe he can take some guts i can ask if you confirm
LaceSensor
Has thanked: 42 times
Have thanks: 245 times
Postby Dirk_Hendrik » 28 Sep 2012, 17:32
That's why I was asking ;-)
viewtopic.php?f=19&t=16304&p=182623&hilit=carlsbro+echo#p182623
Postby tube-exorcist » 28 Sep 2012, 23:40
I think that he was asking about a unit like this:
For this message the author tube-exorcist has received thanks:
modman (25 May 2015, 21:12)
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby pknuits » 29 Sep 2012, 11:51
Tube-Exorcist has hit the nail on the head :applause: - That is the exact one I have with the missing capacitor and no schematic - Thanks to all for assisting here. If only I could find the schematic all would be solved :slap:
pknuits
Postby Dirk_Hendrik » 29 Sep 2012, 20:31
OK, one nail hit.
Next step would be for you to post some pics of the innards of your AD1. This way it might be possible to determine if your AD1 might have some similarities to other Carlsbro effects. This in turn might a) solve your cap mystery or b) help you to find a way to fault-find your unit if that cap is not the problem.
or, in essence,
asking questions and showing up 2 days later without providing as much info as you can will not help you to speed up your repair ;) Start shooting!
Postby pknuits » 05 Oct 2012, 11:58
Sorry about not being able to reply instantly, but with other things going on around me things are taken in an orderly fashion. Iwill post the innards as suggested just as soon as my current workload ends, which should be in the next day or so. Keep the faith. I will post.
pknuits
Postby pknuits » 05 Oct 2012, 17:21
OKAY Guys & Gals - Here are the images that show the complete PCB (in two halves) plus a close-up of the missing capacitor
That should do it me-thinks :D
For this message the author pknuits has received thanks:
pknuits
Users browsing this forum: No registered users and 8 guests
