The great "I'd like to see the guts of" thread
Re: The great "I'd like to see the guts of" thread
Postby J0K3RX » 24 Dec 2018, 17:58
temol wrote:Another G4 review.
T.
I have to agree with Ola on Republican... I like the G3 better personally but the G4 is a close second. The gut shots look very easily traceable.. I wish that dude that took the pics would have gone a couple steps further and bent the pots up to see the board.. Oh well, at least we know it would be an easy trace if somebody happens to acquire one.
I have plenty of high gain preamps to work on already thanks to you and Val! Great work man!!
J0K3RX
Has thanked: 331 times
Have thanks: 516 times
Postby temol » 25 Dec 2018, 09:12
I like both G's, and Apex too. And I hope we'll see those pedals traced, some day.
I wonder what's the purpose of the two TL72s on G3 pcb. Input/output buffers, power supply, tone section? There is also Q6 visible. Is it a mixed circuit op-amps and transistors...?
:) thanks!
T.
temol
Has thanked: 13 times
Have thanks: 135 times
Postby J0K3RX » 26 Dec 2018, 15:01
I found this picture from pedal authority which gives a peak under the pots. I wonder how many other pics he took that didn't get posted in the review?
J0K3RX
Postby temol » 27 Dec 2018, 15:44
Even more ICs. I was expecting to see more transistors :)
G3vsG4
T.
temol
Postby J0K3RX » 27 Dec 2018, 16:30
temol wrote:Even more ICs. I was expecting to see more transistors :)
G3vsG4
T.
My guess is they are probably damn near the same circuit with some minor component value differences..
J0K3RX
Postby jinx1499 » 04 Jan 2019, 04:05
mirosol wrote:Anyone seen the guts of BBE Windowpane?
Here are some gutshots of the BBE Windowpane.
Since it's based on a Fuzz Face, I'd love to get this gut close to an Eric Johnson Fuzz. Any ideas?
jinx1499
Postby FloPoeKo » 24 Jan 2019, 11:47
Vermuram/Ibanez VTS808 anyone?
https://www.youtube.com/watch?v=UMOeGQ4i1S4
FloPoeKo
Has thanked: 25 times
Have thanks: 45 times
Postby Cub » 24 Jan 2019, 13:00
A Timmy with a single tone control?
What will they think of next! :wink:
Cub
Has thanked: 78 times
Have thanks: 89 times
Postby Cub » 24 Jan 2019, 13:07
Alright, that was disrespectful / unfunny / lame, take your pick. :(
I regret making the above post already, but there's no edit/remove button any more?
Cub
Postby FloPoeKo » 24 Jan 2019, 17:16
Cub wrote:Alright, that was disrespectful / unfunny / lame, take your pick. :(
No worries man, we all have that day... :horsey:
For this message the author FloPoeKo has received thanks: 2
Cub (24 Jan 2019, 17:21), deltafred (24 Jan 2019, 18:49)
FloPoeKo
Postby J0K3RX » 31 Jan 2019, 09:47
Lo and Behold... Asketh and The Bugg giveth unto the weary metal heads searching in vain :twisted:
https://www.pedalpcb.com/product/sanguinedistortion/
temol (31 Jan 2019, 10:06)
J0K3RX
Postby temol » 31 Jan 2019, 10:05
This I did not expect :)
There's also Fortin33, but no schematic at the moment.
T.
temol
Postby Cub » 31 Jan 2019, 11:04
Cub
Postby caspercody » 31 Jan 2019, 18:18
Pedal PCB also mentioned they were doing the Revv G3.
caspercody
Has thanked: 31 times
Have thanks: 49 times
Postby temol » 10 Feb 2019, 10:20
caspercody wrote:Pedal PCB also mentioned they were doing the Revv G3.
And here it is
T.
temol
Postby okgb » 11 Feb 2019, 22:41
Vermuram/Ibanez VTS808 , I thought it sounded pretty good! I'll search around and see if I can afford one!
okgb
Has thanked: 210 times
Have thanks: 43 times
Postby J0K3RX » 06 Mar 2019, 00:22
And here it is
T.
I noticed there are a couple FET in one of the gut shots for the G3. One is directly off the wiper of the volume pot and the other you can barely see under the gain pot. Maybe for muting?
J0K3RX
Postby Manfred » 06 Mar 2019, 12:00
Something must have gone wrong, the switch SW1.2 effect nothing.
Has thanked: 1048 times
Have thanks: 629 times
Postby temol » 06 Mar 2019, 12:18
It's a DPDT (SW1.1 and SW1.2) on/off/on switch. So in a middle position C7 is disconnected.
T.
temol
Postby bugg » 06 Mar 2019, 17:20
J0K3RX wrote:I noticed there are a couple FET in one of the gut shots for the G3. One is directly off the wiper of the volume pot and the other you can barely see under the gain pot. Maybe for muting?
Those are SOT23 dual diodes packs.
There is a BJT bypass mute circuit that wasn't included in the Tyrian or Sanguine circuits.
For this message the author bugg has received thanks:
J0K3RX (06 Mar 2019, 18:14)
bugg
Has thanked: 39 times
Have thanks: 237 times
PreviousNext
Users browsing this forum: cordobes and 82 guests
