BBE - Acoustimax  [schematic]
BBE - Acoustimax
Postby apollomusicservice » 03 Aug 2013, 17:18
For now here are some guts and for few days schematic.
For this message the author apollomusicservice has received thanks: 4
Fredenando (05 Aug 2013, 01:57), lohstah (08 Aug 2013, 12:41), modman (04 May 2015, 22:27), rcustoms (03 Aug 2013, 17:32)
apollomusicservice
Has thanked: 65 times
Have thanks: 768 times
Re: BBE Acoustimax guts
Postby rcustoms » 03 Aug 2013, 17:55
apollomusicservice wrote:For now here are some guts and for few days schematic.
count on me for pcb layout
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Has thanked: 346 times
Have thanks: 491 times
Postby ppluis0 » 03 Aug 2013, 18:15
Hi apollo,
This is the link to the datasheet of the 20 pins BBE custom chip: http://pdf1.alldatasheet.com/datasheet- ... 2153D.html
Hope the diagram in page 4 of that document helps you to trace this unit.
ppluis0
Has thanked: 42 times
Have thanks: 85 times
Postby apollomusicservice » 03 Aug 2013, 18:36
For drawing schematics I use Eagle Cad but I did not find library for NJM2153.
I will make my own simplified circuit for 2153 chip in dip 20-pin package.Tnx
apollomusicservice
Postby rcustoms » 04 Aug 2013, 17:15
apollomusicservice wrote:For drawing schematics I use Eagle Cad but I did not find library for NJM2153.
remember baja or bbe sonic maximizer is part of this new pedal,i thing :hmmm: :hmmm:
rcustoms
Re: BBE Acoustimax guts schematic  [schematic]
Postby apollomusicservice » 07 Aug 2013, 13:32
This morning somebody left this schematic at my front door. :)
For this message the author apollomusicservice has received thanks: 12
Bernardduur (07 Aug 2013, 20:59), coludo (05 Dec 2014, 01:31), Intripped (07 Aug 2013, 17:45), jazzmaster (12 Sep 2013, 22:57), lietuvis (08 Aug 2013, 19:59), lohstah (08 Aug 2013, 12:41), McKenzy (12 Aug 2013, 03:57), mister707 (09 Aug 2013, 00:45), rcustoms (07 Aug 2013, 19:36), x-tn (18 Aug 2013, 03:08) and 2 more users
apollomusicservice
Re: BBE - Acoustimax
Postby Lani » 30 Jul 2018, 14:22
Does anybody know whats going on with the switches on the schematic??? the pre/post switch, -12dB switch and phase switch have some strange numbering. Then there is the switch coming off the XLR jack that has no label. Any help would be greatly appreciated. Thanks in advance.
Lani
Lani
Postby plush » 30 Jul 2018, 14:40
Lani wrote:Does anybody know whats going on with the switches on the schematic??? the pre/post switch, -12dB switch and phase switch have some strange numbering. Then there is the switch coming off the XLR jack that has no label. Any help would be greatly appreciated. Thanks in advance.
Lani
Even though the switches have wrong pin group labeling, their purpose is pretty clear. It becomes even clearer after you review the user manual posted on BBE website.
No-named switch is a ground lift, others - pretty obvious.
For this message the author plush has received thanks:
Lani (30 Jul 2018, 18:44)
plush
Has thanked: 24 times
Have thanks: 38 times
Users browsing this forum: ananasie, eipeht and 8 guests
