Guyatone - TD-1 Tube Distortion  [schematic]
Re: Guyatone - TD-1 Tube Distortion
Postby ppluis0 » 10 Jan 2019, 19:02
Manfred wrote:I traced the TD-1 a couple of years ago.
Now I found the images on my Database.
http://postimg.org/gallery/1ta9mcadg/
Hi Manfred, and best wishes for 2.019 !!!
Can you repost the schematic of this unit ? Look as the link it's no longer valid.
ppluis0
Has thanked: 43 times
Have thanks: 87 times
Postby karul » 10 Jan 2019, 20:15
schematic and gutshot
For this message the author karul has received thanks:
ppluis0 (10 Jan 2019, 20:48)
karul
Has thanked: 259 times
Have thanks: 160 times
Postby ppluis0 » 10 Jan 2019, 20:49
Thanks pal !!!!!! 8)
ppluis0
Postby Manfred » 11 Jan 2019, 00:39
Hi Manfred, and best wishes for 2019!!!
Hi Jose, best wishes for 2019 for you too.
The schematic above is not entirely correct, that's is my traced one.
My shots of it:
TD1 Shots.zip
I made a PCB copy as follows:
Ready to print files of the PCBs:
Guyatone TD-1 Component Side.pdf
Guyatone TD-1 Solder Side.pdf
Guyatone TD-1 Solder Side Mirrored.pdf
Guyatone TD-1 PSU Component Side.pdf
Guyatone TD-1 PSU Solder Side.pdf
Guyatone TD-1 PSU Solder Side Mirrored.pdf
SprintLayout6-Files:
karul (11 Jan 2019, 01:20), ppluis0 (11 Jan 2019, 05:22)
Has thanked: 1014 times
Have thanks: 606 times
Postby karul » 11 Jan 2019, 01:36
I might be wrong - the only significant difference I can spot is the cathode bypass capacitor 22u/25V at the input stage.
karul
Postby Manfred » 11 Jan 2019, 09:10
karul wrote:I might be wrong - the only significant difference I can spot is the cathode bypass capacitor 22u/25V at the input stage.
The connections of the gain pot are wrong too.
Postby karul » 11 Jan 2019, 09:53
Yes. The gain pot too, I was too tired yesterday. Thanks.
karul
Postby ppluis0 » 30 Jan 2019, 12:36
Hi folks,
Touring on the web I find a schematic related to this subject: Guyatone/Nady TO-2:
For this message the author ppluis0 has received thanks:
Manfred (30 Jan 2019, 15:18)
ppluis0
Users browsing this forum: paleojenn, radiogaga and 15 guests
