Diezel VH4 Pedal  [schematic]
Diezel VH4 Pedal
Postby kh602 » 29 Nov 2016, 23:53
Just got my VH4 pedal today. Pretty cool idea getting that CH3 VH4 tone from a pedal. Definitely a lot of chunk to say its solid state.
I use it in a preamp config blended with a boogie Tri-axis with custom 5 band eq i built into a boogie 2:90 power amp so vh4 is coming out
of one side of my cab and TA out of the other so its blended in stereo etc....
Not sure if its worth what it is from thomann. Yeah the sound is cool and works well to the power amp but the build quality isn't really there
in terms of material used for the case and things. Still need more time to mess with it as i only just got it and hooked it up.
Anyway i took some quick shots in case anyone is interested.
For this message the author kh602 has received thanks: 8
apollomusicservice (30 Nov 2016, 18:21), Dave37LP (29 Mar 2017, 07:19), kingplank (27 Jan 2018, 15:55), Manfred (08 Dec 2016, 18:41), mensur (04 Dec 2016, 17:36), ms691 (03 Sep 2017, 21:28), p.eat (30 Nov 2016, 15:37), zamguitar (30 Nov 2016, 13:29)
kh602
Have thanks: 30 times
Re: Diezel VH4 Pedal [Gut shots]
Postby askwho69 » 08 Dec 2016, 13:42
There is a Jfet version somewhere else here. I made it years ago and became my main pedal. It is a cool copy of Diezel amp's preamp.
askwho69
Postby kh602 » 09 Dec 2016, 19:27
Yeah I did the same with the diefet but it's far chunkier and has more depth to it than that. The diefet sounded a little fizzier to me. The pedal is cool. Still a lot of cash to splash out on a pedal but I suppose I have done worse.
I will pull it a part more at a later date and get shots of both sides of the Pcb and maybe someone can trace it up as I don't have the time to lately.
zamguitar (09 Dec 2016, 20:03)
kh602
Postby zamguitar » 09 Dec 2016, 20:04
kh602 wrote:Yeah I did the same with the diefet but it's far chunkier and has more depth to it than that. The diefet sounded a little fizzier to me. The pedal is cool. Still a lot of cash to splash out on a pedal but I suppose I have done worse.
Count me in!
zamguitar
Has thanked: 21 times
Have thanks: 15 times
Postby J0K3RX » 10 Dec 2016, 01:42
This will probably be an easy trace... all we would need is one or two good shots of the other side and consider it done! Too damn close not to do it now man 8) God, this pedal is silly expensive... :shock: Diezel must not want to move a lot of them at that price..!!?
For this message the author J0K3RX has received thanks:
orcl2 (10 Dec 2016, 04:04)
J0K3RX
Has thanked: 310 times
Have thanks: 481 times
Postby kh602 » 13 Dec 2016, 21:01
I have just taken more shots front and back tried to cover all angles and things but obviously uploading on here
is limited yet every pic is at least 1-3mb. Anywhere i can upload them maybe zip them up as 1 download
or something and still comply with forum rules?
kh602
Postby marmaliser » 14 Dec 2016, 11:05
You can get a free 2GB dropbox that will do the job
marmaliser
Has thanked: 53 times
Have thanks: 46 times
Postby J0K3RX » 17 Dec 2016, 04:15
Just upload them as attachements like you did with the other pics.. If the other side is like the back then there is no need for higher resolution than the other pics. Resize them if they are too big and get them down to around 800k each. That should be plenty good enough if they are clear and the lighting is good like the other pics. The traces on the back are mostly quite large and easy to follow, no reason the other side would not be the same. I see some hair line traces also leading to via's and up under components and stuff but pics of the other side should connect all of the pieces of the puzzle together. Sometimes I shine a bright LED flashlight through the board and I can see right through like an x ray..
J0K3RX
Postby J0K3RX » 17 Dec 2016, 20:38
You can sign up for an account here, 10gigs for free
https://www.box.com/pricing/individual
rbstep (31 Oct 2017, 22:30)
J0K3RX
Postby kh602 » 19 Dec 2016, 13:09
J0K3RX wrote:You can sign up for an account here, 10gigs for free
Here are all the pics front and back. https://app.box.com/s/eqpa1fe9nd8f6gbq8wfxkqw85lxax054
there is 48 in total from all different angles. hope this helps
For this message the author kh602 has received thanks: 6
J0K3RX (19 Dec 2016, 14:55), kingplank (27 Jan 2018, 15:56), Manfred (19 Dec 2016, 23:35), marmaliser (19 Dec 2016, 13:16), zamguitar (19 Dec 2016, 14:45), Zsozsóó (19 Dec 2016, 17:26)
kh602
Postby J0K3RX » 19 Dec 2016, 19:06
kh602, excelent pics! Hate to bother you further but, do those pots have any values on them that you can see without lifting them? I have a few pots like that so I am fairly sure the values are on the bottom facing the board.. We can probably guestimate what they should be in the tonestack since it looks like your average marshall type stack with standard values judging from the cap and resistor values.
J0K3RX
Postby kh602 » 20 Dec 2016, 19:52
J0K3RX wrote:kh602, excelent pics! Hate to bother you further but, do those pots have any values on them that you can see without lifting them? I have a few pots like that so I am fairly sure the values are on the bottom facing the board.. We can probably guestimate what they should be in the tonestack since it looks like your average marshall type stack with standard values judging from the cap and resistor values.
Measured values of the pots (most are in rheostat config, i assume master and treb are potential dividers at a glance).
Gain pot = 159.7k
Bass pot = 566k
Mid pot = 24.82k
Treb Pot = 262.3k
Master Pot = 10.93k
Pres Pot = 21.07k
Deep pot = 25.35k
Hope this helps
For this message the author kh602 has received thanks: 2
J0K3RX (20 Dec 2016, 22:46), zamguitar (20 Dec 2016, 20:05)
kh602
Postby zamguitar » 20 Dec 2016, 20:08
I'm pretty sure the pot values are the same as the Zerrer pedal.
For this message the author zamguitar has received thanks: 2
dv8r601 (23 Jun 2017, 22:19), J0K3RX (25 Dec 2016, 19:31)
zamguitar
Postby Manfred » 20 Dec 2016, 20:24
Gain pot = 159.7k
Bass pot = 566k
Mid pot = 24.82k
Treb Pot = 262.3k
Master Pot = 10.93k
Pres Pot = 21.07k
Deep pot = 25.35k
Thanks for sharing the pot values.
Could you please measure the pot values on the 12:00 position for to determine the pot curve type.
Please measure each values from tap to the ends.
Manfred
Has thanked: 920 times
Have thanks: 458 times
Postby kh602 » 20 Dec 2016, 20:45
Gain pot = 159.7k
Bass pot = 566k
Mid pot = 24.82k
Treb Pot = 262.3k
Master Pot = 10.93k
Pres Pot = 21.07k
Deep pot = 25.35k
all at 12 oclock
Gain pot = 32k
Bass pot = 105.5k
Mid pot = 12.64k
Treb Pot = 128k
Master Pot = 1.5k
Pres Pot = 1.1k
Deep pot = 2.85k
Manfred (20 Dec 2016, 22:49)
kh602
Postby zamguitar » 20 Dec 2016, 20:50
I'm having hard time figuring out the zener values D3, D4 and the gold cap next to the C28, this cap is responsible for the presence control, so it's value is critical.
I'm halfway done with the tracing.
When the pedal is in bypass mode, the "OUT TO POWER AMP" is muted, right?
zamguitar
Postby zamguitar » 20 Dec 2016, 20:55
The capacitor is C17
zamguitar
Postby kh602 » 20 Dec 2016, 21:00
zamguitar wrote:I'm having hard time figuring out the zener values D3, D4 and the gold cap next to the C28, this cap is responsible for the presence control, so it's value is critical.
I can't see the zeners unless i pull them off. it's 1N5 but no idea on the value underneath. c28 is 47uf 35v, c17 1uf 100v, c20 10uf 63v.
I dont use it in pedal mode but i assume so because when using the power amp output socket it's either on or off (the off state, there is no audio signal/true bypass using the power amp socket)
kh602
Postby zamguitar » 20 Dec 2016, 21:10
Thanks for the time you spent on this.
I can assume the zeners are there to prevent nasty opamp overload and throw a value just below the V+/V- or I can play with asymetrical clipping putting different zener voltages.
I think both ways would give interesting sounding results.
zamguitar
Postby kh602 » 21 Dec 2016, 22:33
No problem. anything else just let me know. i would be interested to see the schem.
zamguitar (22 Dec 2016, 02:35)
kh602
Next
Users browsing this forum: johncatoline13, rund, Steeler [Crawler] and 12 guests
