Dunlop - Cry Baby GCB-95: how to improve it for cheap
Re: Dunlop - Cry Baby GCB-95: how to improve it for cheap
Postby CHEEZOR » 02 Jul 2013, 22:52
burninwordz wrote:Hi how can I cancel a pop when I turn my crybaby pedal on and off ,I modded the pedal to truebypass and now I get a pop, thanks
I believe this topic was discussed in this thread on the page 10. Check it out and post back if you have any questions. What you probably need is a "Pull Down Resistor"
CHEEZOR
Has thanked: 71 times
Have thanks: 90 times
Postby rocklander » 09 Dec 2013, 11:00
dredge..
I was given a GCB95 a few years ago from a bloke who as tired of replacing pots.. I finally got around to getting into it and was gonna try the anderton optical mod but before I can do that I need to get it working properly.. I tried it out and it does 'wah' okay, but the 3pdt is wired all up the shite.. it's been modded to hell, has an extra [volume?] pot, and 3 toggle switches and vaious wires soldered into strange places on the PCB .. whoever did it may not have had very good soldering gear cos it's pretty rough and has even removed some pads..
so I had a nosey through this thread and find heaps of info on modding, but I really want to get the original layout (incl 3pdt switching) so I can figure out what is where on this one in relation so I can work back..
if I ignore the crosses on this picture, is it accurate?
if not.. any idea where to look? I have to admit to a preference for layouts rather than schematics as I personally find them easier to follow.. tia.
rocklander
Has thanked: 1580 times
Have thanks: 289 times
Postby matt239 » 28 May 2014, 16:38
astrobass wrote: The mid-range mod has a clearly noticeable effect on the pedal back position, the vocal range mod mostly affects the pedal forward position, but is less pronounced.
Can you describe this? How does the mid-range mod affect the heel-down position?
Thanks! :)
matt239
Has thanked: 62 times
Have thanks: 5 times
Postby astrobass » 30 May 2014, 20:41
Thanks! :)
On the unit I tried it on it became thicker. Maybe a bit murkier sounding. This was also with a sweep cap selector, increased input/output caps, and a bass guitar. It might be less muddy of less pronounced with a guitar.
astrobass
Has thanked: 50 times
Have thanks: 73 times
Postby hitondrums » 27 Oct 2014, 20:29
Hey! where do you get the pcb layout for this exact model of the GCB95? I need to remake my board because when i was doing the mod I mess it up a little bit (the tracks.)
If you have it on any kind of file format can u PM me please, or upload it here!
Nice mod btw, the switch for the condesnsers its great idea, Greetings!
hitondrums
Postby Bammbammm » 11 Sep 2015, 23:21
Hey all, I am in the process of rehousing my GCB-95 and wanted to see if I am missing something.
I swapped everything into a Hammond 1590 enclosure but the jacks were too far away, so I swapped them for standard Switchcraft jacks. I do have a TRS on the input, however wanted to see if I overlooked something.
Looking at the traces, I was unsure if there is another circuit that needs to be closed for this to work.
Currently (no pun intended) it either bypasses or is dead when engaged.
I only soldered in the tip and ring to one side of the boards as the traces seemed to already bridge both sides of the old jacks.
IMAGE LINK
Any help is appreciated!
(and yes, I know the B+ lead is not connected, I have a puppy and she got to it when I was away.)
:roll:
Bammbamm
Bammbammm
Postby matt239 » 10 Oct 2015, 01:35
hitondrums wrote:Hey! where do you get the pcb layout for this exact model of the GCB95? I need to remake my board because when i was doing the mod I mess it up a little bit (the tracks.)
Do you really have to make a whole new board? you can't bridge the traces with some resistor-lead-wire?
- If you do need a board, Tonepad has a good one, & you can get the artwork there if you prefer to etch. - I think GGG does too.
matt239
Postby FloPoeKo » 23 Sep 2016, 20:31
Question on the inductor:
I have an Eleca Cup Core and I wanted to lower the inductance. Can this be done by sanding away material from the outside of the cup (the top preferably after removing the retainer clip)? It measures 620mH and I should get it as low as 550mH.
Sanding away from the center leg to increase the air gap doesn´t look like an option since simply because the core is glued very heavily.
Any thoughts or comments are certainly appreciated...
FloPoeKo
Has thanked: 25 times
Have thanks: 45 times
Postby rafamoraes82 » 20 Jul 2018, 14:23
I think I need some thoughts... Recently I´ve been trying some mods on my GCB95.
I tried to change the 0.01uF cap to 0.022uF (it got too bassy), and mechanicaly changed the range of the wah pot like... 1 or 2 notches, but eventually I reverted those changes to stock specs afterwards.
By now the changes running are:
1- 33k resistor (in parallel with the inductor) changed to 47k;
2- MPSA18 Transistors changed to BC109B (according to Fuzz Central website - http://fuzzcentral.ssguitar.com/axiswah.php - this mod is meant to give the pedal a more mellow wah response, along with more bass).
Problem is, although theese two mods gave me the tone I wanted when playing clean (a more "woh" effect rather than "weh", and less ear pearcing highs), when I´m using distortion along with the wah there is a drastic change when I rock the pedal from the up position to the down position. It seems that when the sweeping reaches a certain high frequency (near the foot down position), the wah effect suddenly makes a huge "roar" from then on.
Sorry if I did not make myself clear, and for my poor english...
So, what can I do to make the transition from bass to highs smoother? I just want to get rid of that subtle "roar" I´m getting when using wah+distortion...
I´m wondering if changing the midrange resistor (1.5k) could help to smooth out the sweeping? Or is it a drawnback of using the less gainny BC109s?
Thanks in advance
rafamoraes82
Postby Bside2234 » 21 Jul 2018, 00:17
rafamoraes82 wrote:I think I need some thoughts... Recently I´ve been trying some mods on my GCB95.
Thanks in advance
A quick thing to try is to move the distortion before the wah if it's after it or after the wah if it's before it. Sometimes this changes how the wah behaves.
Bside2234
Have thanks: 56 times
Postby rafamoraes82 » 23 Jul 2018, 11:49
Thanks in advance
Yeah, I did that. Actually I put the stock components back only to see if the stock pedal would behave the same way and... it did. So now I´m accepting that I can live with it as it is.
However, if someone knows another way to make the sweeping more even, any tips would be very appreciated.
rafamoraes82
Postby mojah63 » 24 Jul 2018, 12:57
Thanks in advance
The sweep is abrupt? Dump hot potz II if it's in there for a hot potz I or a gagan smooth pot. You can try and increase the .22uf cap off the wiper to .33or .47 ala Teese mod. The Teese way works a little bit. It smoothed out my crybaby but it's still not as smooth as my older Vox wah with a hot potz I...
mojah63
Have thanks: 18 times
Postby rafamoraes82 » 27 Jul 2018, 11:48
Thanks in advance
I will try the .33uF cap mod. Thanks again
rafamoraes82
Return to Pimp-My-Cheap-Pedal
