BJFE-Baby Blue  [traced]
Re: BJFE-Baby Blue
Postby Jone the Bone » 01 Feb 2018, 09:37
Nick123 wrote:I think I have found an error in the last schematic.
Only the wiper of RV2 should be grounded.
There is no error. In this circuit it doesn't matter, it's only an another way to connect a potentiometer.
Jone the Bone
Have thanks: 2 times
Re: BJFE-Baby Blue
Postby momo lab » 18 Feb 2018, 15:48
Hi everyone, I'm back!Sorry for not coming so long, but our country has a “Great Wall firewall”,So I have to resort to some network tools to normal visit。
BBOD I have completed the test, 1N4XXX diode for the circuit sound will be bright and thin, so I had to modify the EQ part.Parallel into a 102 capacitor will sound almost exactly the same。
I wish you have fun, thank you.
momo lab
Have thanks: 30 times
Re: BJFE-Baby Blue
Postby Manfred » 01 Mar 2018, 12:32
Hi momo lab,
I would very much appreciate it if could you measure the drain and source voltages an give the read values to us.
Has thanked: 982 times
Have thanks: 531 times
Re: BJFE-Baby Blue
Postby momo lab » 04 Mar 2018, 11:52
Manfred wrote:Hi momo lab,
For this message the author momo lab has received thanks:
Manfred (04 Mar 2018, 15:54)
momo lab
Re: BJFE-Baby Blue
Postby Manfred » 04 Mar 2018, 16:01
Thanks for the hint, I checked the topic twice, but I have overlooked. :slap:
Re: BJFE-Baby Blue
Postby Manfred » 06 Mar 2018, 11:05
After the measurement, the first stage FET voltage is 4.62V and 1.72V, the second stage FET voltage is 4.72 / 1.68 and the third stage is 5.55 / 1.44.
I got a bunch of 2N3822 FETs, which are almost equal as the 2N5952 FET, except the maximum voltage and current values.
I ran a curve traces of it, to drawing in the resitor values in found characteristic curves graphic.
The graphical soultion gave values in the vicinity of the read values of momo lab's measurement,
therefore the 2N5252 seem to be the right choice.
Re: BJFE-Baby Blue
Postby ray86 » 08 Mar 2018, 14:11
Fairly straight forward JFET circuit with hard clipping in the 2nd stage
ray86
Re: BJFE-Baby Blue
Postby Dingleberry » 08 Aug 2018, 11:19
It looks to me that the diode is 2A / 1200V diode, most likely rectifier diode or schottky of some kind.
That's probably the obsolete part of that pedal because the production was stopped because of parts shortage (or at least that's what I have heard).
Simplify before you amplify.
Dingleberry
Have thanks: 37 times
Re: BJFE-Baby Blue
Postby Manfred » 08 Aug 2018, 18:23
Dingleberry wrote:It looks to me that the diode is 2A / 1200V diode, most likely rectifier diode or schottky of some kind.
Have a look at the post further up, mom lab measured the original diodes
The threshold for this diode is 0.536v and 0.523v
I traced an obsolete rectifier diode found in an old tube amplifier as a part of a HV brigde amplifier.
The case has a rectangular shape and no imprint.
The traced values are surprisingly close to the measured values.
I therefore believe that it is rather a rectifier diode than a schottky type.
By comparison, the interpolated curve of a BY133 diode.
Re: BJFE-Baby Blue
Postby Manfred » 09 Aug 2018, 16:53
Retrospectively, I have to say that the BY133 does not produce the desired value,
I am continuing to seek for the matching diode.
Re: BJFE-Baby Blue
Postby Dingleberry » 12 Aug 2018, 15:42
Found an inside-view picture of the new One Control Baby Blue from a japanese site.
Most likely those diodes in the One Control version are BY448V diodes. It's a 1500V 2A diode.
Kind of correlates to the 2A1200 of the original BJF unit. High voltage 2A rectifier diodes in both of them.
For this message the author Dingleberry has received thanks: 2
dv8r601 (17 Aug 2018, 04:15), Manfred (12 Aug 2018, 15:45)
Dingleberry
Re: BJFE-Baby Blue
Postby Manfred » 12 Aug 2018, 15:56
Thanks, it helps me, I will buy some and trace the curves.
Dingleberry (12 Aug 2018, 16:14)
Re: BJFE-Baby Blue
Postby Manfred » 20 Aug 2018, 18:09
Today, I received my ordered Diodes.
The BY448 Diodes were difficult to get and are very expensive,
that's why I bought a bunch of 40 BY458 diodes for a favourable price.
The diffrence between the both types is only the maxium reverse voltage.
The PN-junktion curve in the common data sheet is the same for both.
The measuring of all diodes results in a mean value for the threshold voltage of 0,608 Volts at 5 Milliamps,
with a deviation of 0.006 Volts.
The threshold voltage at ~0,9 Milliamps is.0,516 Volts, which is close to the measured original values of 0.536 and 0.523 Volts,
so the BY458 should be functioning well.
roseblood11 (20 Aug 2018, 22:13)
Users browsing this forum: EddieTavares and 15 guests
