TA7135 VS TA7136 Boss CE-1
Postby Ricotjuh » 18 Mar 2018, 20:12
Hello does anybody have the datasheet of a TA7135? Or can anybody tell me the difference between the TA7135 and the TA7136? Because in the schematic of the Boss CE-1 I see written that IC1 and IC2 is a TA7135 but I have a CE-1 for repair and here it is a TA7136!?!
Ricotjuh
Re: TA7135 VS TA7136 Boss CE-1
Postby PokeyPete » 19 Mar 2018, 14:42
The schematic that I have seen shows IC1 and IC3 being TA7136P, and IC2 is MN3002
http://www.schematicsunlimited.com/b/bo ... -schematic
“No man is so foolish but he may sometimes give another
good counsel, and no man so wise that he may not easily err
if he takes no other counsel than his own. He that is taught
only by himself has a fool for a master.”
–Hunter S. Thompson
PokeyPete
Have thanks: 64 times
Postby Ricotjuh » 19 Mar 2018, 21:21
You are right about IC1 and IC3. But I saw these schematic. https://www.pdf-archive.com/2017/11/21/ ... rretboard/
And here the note on the left refers to IC1 and IC2. Probarly this is wrong. Also the type IC is written as TA7135. But I cant find a Manual of these IC. Perhaps its also wrong?!
But in one of the schematic in your link, its not a TA7136 but a TA7504S? What about that?
Ricotjuh
Postby Dirk_Hendrik » 13 May 2018, 09:44
When able, always use the factory schematic!
And now I'm sure that within time someone will show up stating that there's manufacturers that deliberately put errors in their schems. If so, please show me one with the proof that the error was put in there intended.
Has thanked: 253 times
Have thanks: 1014 times
Users browsing this forum: G.G. and 3 guests
