Has anyone modded their MXR Distortion + ?
Postby masthefool » 27 Oct 2018, 06:08
If so, was it worth modding or did it still sound thin and like a razor blade stabbing your ears ? Im thinking of modding mine and I have never tried modding a pedal so im curious if its worth doing
masthefool
Re: Has anyone modded their MXR Distortion + ?
Postby Intripped » 27 Oct 2018, 11:11
Here you can find a nice article from Brian Wampler (Wampler pedals, active member here also) with some interesting mods. Hopefully you can find the most useful for you.
https://www.premierguitar.com/articles/mxr-distortion-plus-mods-1
Ps: welcome!
Intripped
Has thanked: 588 times
Have thanks: 215 times
Postby Manfred » 27 Oct 2018, 13:40
I started this complete mods in the spring, but I stopped the work during the summer.
When it is getting cold outside, I start working again.
I applied two Russian GAY-63 diodes connected in series, as an approximation of the forward PN-junktion curve of an AA119 diode.
Has thanked: 998 times
Have thanks: 558 times
Postby masthefool » 27 Oct 2018, 18:58
Intripped wrote:Here you can find a nice article from Brian Wampler (Wampler pedals, active member here also) with some interesting mods. Hopefully you can find the most useful for you.
Ps: welcome!
Looking at the article, I have questions since I am new to this and cant read schematics. "Change C5 to a .0022uf and wired in series with a 1m audio taper pot" How do I wire a pot with a capacitor? Also how would i wire the spst switches ( do they replace the capacitor or resistor ? I am sorry if my questions make sense
masthefool
Postby Intripped » 27 Oct 2018, 21:25
If you are completely new to elctronics and diy, i think that this could be the right moment to start learning something:
How to read schematics for example, it's not difficult at all, you just have to learn the few symbols used for components.
Here is a table with many symbols. You don't need to learn them all.
The most important for pedals schematics are:
resistor, potentiometer, capacitor, diode and LED, operational amplifier (also called opamp), transistor.
Then you could try and read the schematic of the distortion plus.
I think that in a short time, with some little efforts of yours and some help from the people over here, you'll be able to make your first mod to your pedal!
Intripped
Postby alexradium » 28 Oct 2018, 09:23
In my experience when you think your pedal sounds bad,its most probably because its plugged in the wrong amp at low volume,with a lousy sounding guitar.
What is your setup?
alexradium
Has thanked: 53 times
Have thanks: 60 times
Postby roseblood11 » 28 Oct 2018, 12:26
This circuit is a very good startibg point to learn the basics. Interesting things to read about: opamp circuits, high- and low pass filters, diodes as clippers.
There are a lot of circuits with the same topology, but different parts values: DOD 250, Vox 1901 Distortion, Guyatone Zoom Box PS-102.
But maybe it's easier to build a pedal from scratch than to try all those modifications on the original pcb - it might get destroyed in the process...
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby idy » 28 Oct 2018, 16:21
DIstortion+ is a good choice for first experiments. One of my first. I doubled the diodes. Friends were impressed. I couldn't duplicate the great sound. Finally discovered I'd broken one of the (glass) diodes. So I found I like asymetric clipping...
Yes, the "best" path is to get a breadboard and a few dollars worth of parts and start experimenting.
idy
Has thanked: 31 times
Have thanks: 26 times
Return to Pimp-My-Cheap-Pedal
