Capacitors in Mesa Boogie Dual Rectifier
Postby Ricotjuh » 12 Jan 2019, 23:54
Hey,
In a Dual Rectifier, 1uF capacitors are connected to the cathode. Via an LDR or resistor to GND.
But when I look at the PCB these are not ordinary electrolyte capacitors, but yellow capacitors that look very similar to the construction of a resistor. The + side seems to be a bit tapered. See image below. Picture is not from the DR, but from another Mesa. But it only concerns the type of capacitor.
Someone any idea what type of capacitor this is, and what the advantage is, compared to an electrolyte capacitor.
Ricotjuh
Re: Capacitors in Mesa Boogie Dual Rectifier
Postby temol » 13 Jan 2019, 00:05
Looks like tantalum axial capacitor.
T.
temol
Have thanks: 127 times
Postby Ricotjuh » 13 Jan 2019, 00:36
You mean something like this?:
https://goo.gl/images/YqVVNf
Ricotjuh
Postby temol » 13 Jan 2019, 09:39
Exactly. Check this - 1u tantalum axial cap.
T.
temol
Postby Ricotjuh » 13 Jan 2019, 09:45
Completely clear. Thanks for the quick response
Ricotjuh
Postby Optical » 14 Jan 2019, 02:28
Yeah Kemet tantalums
They last for a long time vs electrolydics, dirt cheap, fail obviously and are generally more compact - reasons why Mesa uses them.
They also fail shorted (an obvious giveaway vs a slowly wearing out electro cap) but seem to work well and last for a long time in Mesa amps regardless
Optical
Have thanks: 13 times
Postby Rocket Roll » 15 Jan 2019, 15:29
Actually, they have a higher failure rate than electrolytics, all of the data suggests.
One of the possible reasons for using them is distortion. When placed on signal path, they tend to introduce non-linearities, the sonic signature of which is very much respected in both pro-audio (Rupert Neve) and guitar-based audio (Tube Screamer, Rat).
Rocket Roll
Have thanks: 31 times
Return to Amplifiers
Users browsing this forum: JesseB and 1 guest
cron
