Electra MPC Module Schematics
Postby jsrfo » 09 Nov 2019, 14:37
Does anyone have schematics or traces of the old Electra Guitar MPC modules? Just picked up a nice MPC guitar, and would like to attempt to make a module board, but would like to first see the thought process behind them, as the guitar uses one 150K pot to control one parameter on the effect. Pretty simple, I'd assume.
Any help would be appreciated. I'd even buy a broken or functional module to work from.
For this message the author jsrfo has received thanks:
Nocentelli (10 Nov 2019, 17:55)
jsrfo
Re: Electra MPC Module Schematics
Postby Nocentelli » 10 Nov 2019, 17:56
Some superb (and possiblly trace-able) gutshots here:
http://www.rivercityamps.com/electra/modules.php
For this message the author Nocentelli has received thanks: 2
Desdog (11 Nov 2019, 12:22), jrod (19 Nov 2019, 22:27)
Nocentelli
Has thanked: 902 times
Have thanks: 857 times
Postby Axldeziak » 10 Nov 2019, 20:43
Looking through their forum it seems the phaser circuit was an original E-H Small Stone using CA3094 OTA.
For this message the author Axldeziak has received thanks:
Nocentelli (10 Nov 2019, 23:44)
Axldeziak
Have thanks: 7 times
Postby jrod » 19 Nov 2019, 22:33
Nocentelli wrote:Some superb (and possiblly trace-able) gutshots here:
The Overdrive looks to be basically the "Electra Distortion" schematic that's been floating around for years, but without the clipping diodes.
For the Dynamic Fuzz though the PCB trace side doesn't match up with the components.
For this message the author jrod has received thanks:
Nocentelli (less than a minute ago)
jrod
Has thanked: 335 times
Have thanks: 42 times
Postby Dr Tony Balls » Yesterday, 20:00
Dont have any schematics, per se, but I can chime in with some info. Awhile back a friend sent me two MPC modules in hopes that could get them working. The problem being that I dont have an MPC guitar to test them on. So I built a little pedal that could accept MPC cartridges for testing and use. Bought a 10 pin edge connector and just hooked it up outside a stompbox like so:
One cart was a distortion unit that I got working. The other was a phase shifter that I couldnt get to the bottom of so instead I set out to build a replacement circuit. You could print a PCB for this if you want, but I found that 0.15" pitch vero board was a close enough match for the edge connector. You just have to cut it to size and cut/file shoulders by the connector. Wound up putting a Magnavibe circuit on one:
[url=https://flic.kr/p/Xg3mcR]Image
For this message the author Dr Tony Balls has received thanks:
Dr Tony Balls
Have thanks: 154 times
