Emma - DB-1 ( DiscumBOBulator )
Re: Emma Electronic Discombobulator
Postby Mbas974 » 12 May 2013, 20:26
Wow, looks not really hard to build... :-)
but, what are the boxes called "1" (INV_XX).
I image it's a sort of logic port.
Any idea what could be the chip involved ?
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Emma Discumbobulator V2
Postby roseblood11 » 17 Nov 2017, 23:11
I just realized that there is a second version of this pedal, and I hope we'll get this traced.
The first version was based on the MXR envelope filter, with some mods, maybe with additional buffer(s). Clones of the MXR that had the mods described on tonepad sounded more or less identical.
https://m.youtube.com/watch?v=40cPxO1AzWQ
http://www.emmaelectronic.com/discumbobulator/
roseblood11
Has thanked: 352 times
Have thanks: 313 times
Re: Emma - DB-1 ( DiscumBOBulator )
Postby modman » 18 Nov 2017, 18:16
I merged all Emma - DiscumBOBulator post into one thread because all the schematics have dissapeared as well as all gutshots.
Please use the attachment function to preserve shit for posterity! thanks
Has thanked: 3223 times
Have thanks: 602 times
Postby POTL » 18 Nov 2017, 21:47
not verified!
For this message the author POTL has received thanks:
modman (Yesterday, 20:19)
POTL
Has thanked: 65 times
Have thanks: 61 times
Postby rs » 26 Apr 2018, 20:17
Here are some guts i've found a while ago.
I'm still trying to figure this one out.
Cheers.
For this message the author rs has received thanks:
modman (Yesterday, 20:10)
rs
Has thanked: 98 times
Have thanks: 7 times
Postby chicago_mike » 13 May 2018, 23:35
For the input and output caps in the Emma, I just used .022 Panasonics. sounds fine!
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 301 times
Postby rs » 15 May 2018, 08:20
Hi Mike, wich schematic did you use? Im getting strange noises. Have to check it latter. Thanks.
rs
Postby roseblood11 » 23 Sep 2018, 02:07
roseblood11
Postby roseblood11 » 14 Sep 2019, 01:54
Just ordered version 2. I will post photos and schematic next week
For this message the author roseblood11 has received thanks:
rs (16 Sep 2019, 20:28)
roseblood11
Postby roseblood11 » Yesterday, 17:39
Version 2 is all smd.
As my wife is in hospital, I won't have time to do the tracing myself but I will take some macro shots.
The pedal doesn't sound better than the old version, but it might have more headroom, as it can be used with bass or power humbuckers without any distortion.
The clean boost is a useful addition, but there should be an option to change its position in the signal path: Often, it would be more useful, if the boost was directly behind the output of the wah circuit, so that the wah's bypass switch would switch both effects at the same time.
For this message the author roseblood11 has received thanks: 2
Intripped (Yesterday, 23:07), modman (Yesterday, 20:10)
roseblood11
Users browsing this forum: Alsassius, Guava and 8 guests
