Pete Cornish - NG-2
Re: Pete Cornish - NG-2
Postby JOHNO » 20 Jun 2011, 16:46
Oh FFS $1,750? Really?
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby silverface » 20 Jun 2011, 18:11
That's insane. By the way, that looks more like the G2 pcb that DirkH degooped for us. But it looks like silicons diodes in there, so it's likely a P1 or P2..
silverface
Have thanks: 8 times
Postby lolbou » 20 Jun 2011, 20:32
And no buffering in it?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 351 times
Have thanks: 240 times
Postby pervyinthepark » 21 Jul 2018, 08:31
Does anyone want to work on setting up a new tracers fund..?
In Lou Reeds memory?
I love the NG Fuzz sound he gets on Like A Possum. Its insane and kind of unique yet something that's always been there, ay?
pervyinthepark
Have thanks: 5 times
Postby palelight » 08 Nov 2018, 22:42
pervyinthepark wrote:Does anyone want to work on setting up a new tracers fund..?
Because I've been chasing that Like a Possum sound for so long, I'm willing to pledge $100 toward a tracer's fund to get this one moving. Anyone else?
palelight
Postby roseblood11 » 08 Nov 2018, 23:02
The description might give a hint that it's similar to a Tone Bender with an added output stage. Maybe similar to the mu amp stage in a Catalinbread Formula No. 5, which delivers a similar "dying amp" sound.
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby pervyinthepark » 08 Nov 2018, 23:09
Probably is, but it's hard to know what exactly we're looking at, let alone exact modifications made, without delving further. I vote we do it!
We have a pledge of $100, earlier in the thread there was at least $20 but that was years ago so lets forget it, and also Ivlark and the bois at tagboardeffects said they're willing to do degooping work and etc.
I will be making EagleCAD PCB designs and will give out ZIPs of the CAD files. My design is going to be board-mount potentiometers and wired switches and jacks, single PCB.
I would also donate some amount of money but am financially a little tied up at the moment so I'm holding my statement of fiscal contribution back until I know confidentially how much I can put forth.
For this message the author pervyinthepark has received thanks:
Visualdistortion (10 Nov 2018, 09:07)
pervyinthepark
Postby FeVeR2112 » 10 Nov 2018, 18:42
I just ordered the "Nugget Fuzz" board from Robert at Pedalpcb.com. It is based on the NG-2. No schematic up yet but...
https://www.pedalpcb.com/product/nugget/
For this message the author FeVeR2112 has received thanks:
palelight (10 Nov 2018, 23:51)
FeVeR2112
Has thanked: 20 times
Have thanks: 34 times
Postby palelight » 10 Nov 2018, 23:54
FeVeR2112 wrote:I just ordered the "Nugget Fuzz" board from Robert at Pedalpcb.com. It is based on the NG-2. No schematic up yet but...
Thanks for the heads up. Just snagged one, worth a shot anyway. I'd figured, given some of the ungooped gutshots posted earlier, that there'd be some germanium transistors in the final (speculated tonebender-ish) gain stage. Interesting. The schem on the build guide has some tonebender-isms going on. At least it's not a big muff...
palelight
Postby snofla1900 » 11 Nov 2018, 11:02
If you look below the info you'll see a "download build docs"- there's the info how to build it as welll as the schematic !
Alf
snofla1900
Has thanked: 91 times
Have thanks: 14 times
Postby roseblood11 » 11 Nov 2018, 20:26
Who will post the first vero layout? Should fit in a 1590B
roseblood11
Postby alltrax » 12 Nov 2018, 14:22
roseblood11 wrote:Who will post the first vero layout? Should fit in a 1590B
anders posted one at Guitar FX Layouts, not verified
http://guitar-fx-layouts.42897.x6.nabble.com/Cornish-NG-2-td44578.html
alltrax
Has thanked: 15 times
Have thanks: 16 times
Postby palelight » 13 Nov 2018, 02:25
Well, ignore what I said above about the big muff... should have looked at more than the final gain stages. Indeed a silicon FF goosed with BMP output and clipping stages as noted over at guitar-fx-layouts.
Any way of knowing if this is just someone's approximation of the circuit from the scant info in interviews over the years or did some covert degooping go down somewhere?
palelight
Postby palelight » 27 Nov 2018, 02:48
My PCB's stuck in the mail for the time being, anyone get one of these built up yet?
palelight
Postby Jim-Analog » 12 Dec 2018, 23:52
Greetings!
Ah, fellow Possum-tone hounds! I'd for sure contribute to this in Lou's memory and an attempt to get THAT tone. I've gotten close using series connected distortion boxes and some tube stuff that I've built, but not exact enough.
BTW, the live sound on that tour was unbelievable! Saw them at a fairly small, nice old venue of about 1000 seats. The rhythm section was like a freight train with Mike and Lou going back and forth on top. One of the best Lou shows ever (out of about 10 that I've seen).
Let's do this fuzz!
Regards, Jim
Jim-Analog
Postby HamishR » 13 Dec 2018, 09:06
Well I have built one using the Pedal PCB board and it is all very underwhelming. Lovely board, boring pedal. I like my Skreddy fuzzes a lot more. After the build up I am disappointed - but a lot of pedals are like that.
I'm off to see what the Lou Reed Possum sound is now. :shock:
HamishR
Have thanks: 19 times
Postby palelight » 13 Dec 2018, 10:19
Bummer you didn't like the fuzz. I think this pedal is one instance where it's crucial to have the Cornish buffer in front of the effect. I built mine using the Pedal PCB board as well and it was night and day adding the buffer inline. Without it the gain stages are not getting slammed enough to have the swell and bloom to the attack of the guitar. With the buffer you get that breathing effect on the notes you hear on Like a Possum, or even some heavier Neil Young tracks. Also have to make sure it's biased different than something like a fuzz-face or tone-bender, you want gating more than sustain, somewhere around 30k on the pot I'm guessing (I mounted my bias knob externally). I was very pleased with how mine turned out.
palelight
Postby HamishR » 13 Dec 2018, 16:04
I may try putting the buffer in front - thanks! Good idea. I have experimented with the bias as i imagine that the gating is part of the idea. Really, why isn't the bias an exterior control then?
I have also built Fuzzdog's Pitbull fuzz and that is one of my favourites for gated, "broken" sounding fuzz. It's wonderful! The Magnetic Effects Solar Bender is an updated Tonebender with tone and bias controls - it has a mix of silicon and germanium in it and it's awesome. In comparison the NG-2 has been rather pedestrian. But I will see if I can stick the Cornish buffer in there.
HamishR
Postby Jim-Analog » 13 Dec 2018, 20:57
Greetings,
I'm about to order one of the "Nugget" PCBs. Palelight, did you put buffers on both the input and output (typical PeteC) or just the input? Thought I saw someone offering empty "PeteC" buffer PCBs, but can't seem to find them.........anyone know? Thanks all! Figure it's worth a shot to try.
PS.........if I recall correctly, some of the closest Possum tones I got were using a tweeked FF a friend gave me (switchable Si or Ge front end, all 3 TXs on sockets; no idea what was in it at the time) and a Butler tube driver that I did a ton of messing around with in series. Sort of close but no cigar.
Regards, Jim
Jim-Analog
Postby palelight » 13 Dec 2018, 22:59
HamishR wrote:I may try putting the buffer in front - thanks! Good idea. I have experimented with the bias as i imagine that the gating is part of the idea. Really, why isn't the bias an exterior control then?
There's two versions of the pedal, Ng-2 with the bias on a trimpot and Ng-3 with it mounted externally. I'm guessing they used the internally mounted version for a cleaner more compact build. My guess anyway. And I wouldn't disagree with the pedestrian qualification, it's definitely more 'polite' compared to some of the very raucous gnarly fuzzes out there. I guess what makes it a little different to me is the eq, it still has a really full bass response and fairly natural treble, whenever I used something like a Fuzz Factory or the like it just devastated whatever low-end I had. I always thought of the NG's as closer to a really whacked out distortion than a crazy fuzz.
Jim-Analog wrote:Greetings,
Regards, Jim
Just the input. I know the info about output buffers is floating around on various forums but I've never seen a schem with one, at least on the stand-alone pedals (I'm sure the giant stage boards are a different can of worms). He does use two input buffers on the G2 (which seems mega anal but whatever). I don't think an output buffer would change the tone of the pedal much, perhaps a little more high-end clarity seeing as that's what the Cornish buffers emphasize? But the fuzz can get pretty trebly after 1:00 on the tone knob as is. Haven't seen a Pete C style buffer board for sale, just used perf for mine and the layout from TagboardFX.
Same experience as well. I used a klone in front of a dizzytone fuzz biased for heavy gating. Sounded actually pretty close but there was absolutely no control over the tone or amount of fuzz, and it was finicky about amp eq. Too much of a hassle.
palelight
PreviousNext
Users browsing this forum: Floods, storyboardist, tinkercreek, vtguedes, wokkel and 8 guests
