Joyo - JF-13 AC Tone  [schematic]
Re: Joyo - JF-13 AC Tone
Postby Mickyvai » 12 Mar 2016, 18:06
Hi everyone. I performed the speaker sim mod and thought that someone here could use a schematic of the mod that was previously explained, with all the details specified. ;-)
For this message the author Mickyvai has received thanks: 2
Heph333 (13 May 2018, 01:15), MACopeland90 (01 Apr 2016, 02:12)
Mickyvai
Have thanks: 2 times
Postby Mickyvai » 16 Mar 2016, 11:39
I have done a short demo of the mod:
[youtube]https://www.youtube.com/watch?v=KjLntLSirn0&feature=youtu.be[/youtube]
Mickyvai
Postby ericlaw02 » 20 Jul 2016, 11:45
Has anyone traced the full schematic of the Joyo circuit for differences against the Tech21 originals (http://www.freestompboxes.org/viewtopic.php?p=220001#p220001), other than the R4/E1/Cin/C2... components?
I replaced the components to create my own "VT Bass", the tone seems identical to YouTube videos with each setting, but it seems lacking in gain, and with noticeable increase in noise.
For example, an actual VT Bass unit can achieve unity gain when EQ is flat, drive at 10 o' clock, when level is set to 8-9 o' clock, yet on my modded Joyo, I have to turn to around 2-3 o' clock to achieve unity gain. So somewhere there's at least some difference between the two circuits.
For starters, I checked the circuit/component values after the final opamp output, and they seemed identical, so it's not that simple unfortunately :(
ericlaw02
Have thanks: 5 times
Postby ericlaw02 » 20 Jul 2016, 19:06
I think I may have answered my own question about the lack of gain.
On the original Tech21 schematic, with R19=10k and R20=100K, IC3a provides 10x voltage gain (20db gain). But on the Joyo, the corresponding components being R30=10k and R31=15k, it should only provide 1.5x voltage gain (~3.52dB gain).
I know nothing about electronics, but I suppose R31 is the culprit for the lack of gain, replacing it should allow me to match the original's levels. Though I don't really think that's going to help reduce the noise...?
Still, I'm interested if anyone found out any other differences between the two boxes...
ericlaw02
Postby Hanky- » 07 Aug 2016, 06:44
ericlaw02 wrote:I think I may have answered my own question about the lack of gain.
I found that R31 measured 22k on the actone while the california sound had 68k in that place.but the calif has added mic sim components which lower the overall volume so removing those to match the actone gave me significant increase in volume.
After trying out different values in R31, 47k sounded good to me without affecting the tone much or the dynamics. My guess with the noise in joyo is the buffer design might be the culprit since it isn't the same as the tech 21 or perhaps maybe it's the board quality in the joyo being sub par. I even replaced the ICs to match the tech 21 but it didn't lower the overall noise.
For this message the author Hanky- has received thanks: 2
ericlaw02 (08 Aug 2016, 06:43), HENK (07 Aug 2016, 08:35)
Hanky-
Have thanks: 4 times
Re: Joyo - AC Tone
Postby pjk » 01 Jun 2017, 22:29
Ripdivot wrote:Remove the part shown and add a jumper wire duplicating the switch in the down position.
Hi and thanks very much for doing this. If i am not wanting to add the switch, does the jumper wire go from pin 3 on the volume pot to R24 or is it to the point adjacent to the 0 ohm resistor please ?
pjk
Re: Joyo - AC Tone
Postby jswnhart » 30 Apr 2019, 19:12
jockie wrote:
Ripdivot wrote:I had some time so I sat down and figured out the speaker sim bypass on the newer PCB.
WARNING: be very careful with your soldering, the traces on the board are very fragile.
I used 26AWG wire for my connections. Start by removing the 0 ohm resistor shown. Solder a wire to each of the three places shown in red. Once your wires are in place put a small blob of hot glue over the connections to the board. I didn't do this to the wire soldered to pin 3 of the level control as it is plenty solid. solder the other end of the three wires to your switch and you are good to go. Works great!
Hi, thanks for that. I did it on my American Sound (Harley Benton, not a Joyo, but the pcb is the same). It works great.
But, to avoid the immense differences in volume in both positions of the switch, I took a DPDT-Switch. One area of the switch I soldered as you mentioned, the other area switches a resistor between the first and second lug of the volume pot (from left to right in your picture) when in SpeakerSim OFF position.
To get the right value of the resistor I soldered two lugs of a 10k-pot instead of a fixed resistor and turned it as long as I got nearly the same volume in both positions. Then I disoldered the 10k-pot again and measured the resistance between the affected two lugs. In my case it was around 3k3. So I soldered a fixed 3k3 resistor instead of the 10k-pot and it works great in all positions of the Volume-pot. Maybe values between 2k2 to 3k9 will work. Just have a try or do it with a potentiometer like I did.
Note, that this resistor is not affecting anything, when in SpeakerSim ON-position.
Thanks again for your work on the new pcb-layout - now it is a very versatile component of my pedal-board.
Music is the best
I did a similar approach, but used a 1M pot in series with the wire from R24 to the “off” side of the SPDT switch.
180K seemed to equalize the volume between the “on” and “off” positions.
Still have a big tonal difference between settings. Has anyone addressed this?
jswnhart
Postby Hanky- » 04 Mar 2020, 17:02
The value of R24 in the American Sound I have in hand is 39k instead of 33k as reported earlier, anyone else have one in hand that would like to crosscheck this?
It sounds like the ones in the demo vids I found online.
I tried 33k in there, I sounded less fendery sort of but could be dialed in to sound closer. I might try changing it later to the 47k as the tech21 to hear the difference cause I liked the 39k in there better.
Hanky-
Postby ChristianSosa » 24 Mar 2020, 03:25
Hello Guys!
Does any of you know the value of R24? I kinda lost mine... somehow...
ChristianSosa
Users browsing this forum: Gicawg, kh602 and 10 guests
