Pro Co - Juggernaut  [schematic]
Re: Pro Co - Juggernaut
Postby bajaman » 17 Jun 2008, 14:39
Here is the Juggernaut Overlay - 600 dots per inch resolution - scale is in tenths of an inch.
Please help identify the resistor values with question marks for values.
How is that schematic coming along AG?
members/bajaman/JUGGERNAUT/BAJA%20ProCo%20Juggernaut%20Overlay.png
NOTE: I left a resistor off the PCB drawing - refresh your browser and download the newly corrected version.
Has thanked: 475 times
Have thanks: 1687 times
Postby bajaman » 17 Jun 2008, 22:12
Edited the overlay - press F5 to refresh your browser - still waiting on some unknown resistor values - AG?????
:) bajaman
Postby bajaman » 17 Jun 2008, 22:22
Hello Dosmun
Can you help out with offboard wiring connections to sockets please :wink:
many thanks
Postby dosmun » 18 Jun 2008, 02:18
The Green wires are all ground The jacks from left to right are:
Out In Effect Out Effect In
dosmun
Postby dosmun » 18 Jun 2008, 02:50
A couple of corrections:
The 12K above the switch on the left is 22K
The 1.5K resistors are actually 1.6k if you want to be precise
The resistors under the 4 100uF caps are 47 ohm.
Now going pretty much from left to right:
Far left resistor = 1K
Resistor above and parallel to 1.6K = 1K
Resistor below Vol pot and 47K = 10K
Next 3 are 1K
Far right above 47uF cap = 220
dosmun
Postby dosmun » 18 Jun 2008, 02:57
On Bajamans layout the wires from left to right are:
Black wire = Instrument Output Jack
Yellow wire = Instrument Input Jack
Black wire = Outboard Effect In Jack
Yellow Wire = Outboard Effect Out Jack
dosmun
Postby bajaman » 18 Jun 2008, 03:41
Hey thanks Dosmun
corrections are on the way :wink:
Postby bajaman » 18 Jun 2008, 03:56
New values added to layout - please refresh your browser to view changes (f5)
Many thanks to Dosmun for his photos and measurements :D
Postby bajaman » 18 Jun 2008, 03:59
i assume you could just join the outboard effect in and out wires together if you did not want to add two extra jack sockets - a nice feature is the buffered output to external effects provided. :wink:
Postby bajaman » 18 Jun 2008, 13:46
Anyone want a label for this?? :wink:
members/bajaman/JUGGERNAUT/BAJA%20ProCo%20Juggernaut%20Label.png
1200 dpi - okay!!
Postby Bernardduur » 18 Jun 2008, 16:34
From that I made this schematic
Schematic
I think R2 is wrong and should be placed before R1, but I can't really check it on the pics
I left out the distortion switch but it should be placed between the distortion circuit and the FX send.
Bernardduur
Has thanked: 87 times
Have thanks: 506 times
Postby Bernardduur » 18 Jun 2008, 17:11
I checked the pics
R2 is moved beside R1
Bernardduur
Postby bajaman » 18 Jun 2008, 23:08
Thanks Bernardduur
I checked my PCB and layout pictures - there was an incorrect track placement for the 1M resistor connection at the input. I have amended the pictures - please refresh your browser and download the corrected pictures - hopefully this will be the last correction - on to something new now (make it fit in a 1590BB case :wink: )
Postby dosmun » 19 Jun 2008, 00:54
You guys are great. Quick and awesome schems and layouts.
:applause: :applause: :applause: :applause: :applause:
I guess it still won't hurt for Soulsonic to double check the info I gave, especially the pot values.
dosmun
Postby Stompmodder » 19 Jun 2008, 16:07
Bernardduur wrote:From that I made this schematic
Schematic
According to the schematic, the FX send/returns jacks are not connected together when no external fx are used. Look like you cannot use the distortion without a jumper between FX SEND/RETURN. I thing you can use a jacks with tip switch to fix the problem.
Stompmodder
Have thanks: 5 times
Postby Bernardduur » 19 Jun 2008, 16:58
Schematic
Sorry; I never bother with these things....... as I don't have the unit here :) I THINK they would have used such a design in the final product (I sure hope so :))
Bernardduur
Postby bajaman » 19 Jun 2008, 22:38
I am almost finished with drawing out a layout and PCB for a smaller version (you know how i like to miniaturise things :wink: ).
I will publish it as a DIY project in the next few days - It will fit in a Standard hammond case too. :D
Postby seniorLoco » 20 Jun 2008, 02:39
bajaman wrote: a layout and PCB for a smaller version (you know how i like to miniaturise things :wink: ).
ha ha same here :lol:
Great job guys !!
seniorLoco
Have thanks: 10 times
Re: Pro Co - Juggernaut  [schematic]
Postby analogguru » 20 Jun 2008, 12:25
Ok, here comes the birthday-present No. 1, the complete:
Pro Co - Juggernaut schematic
To be precise, on my monitor the LED-resistor near the Master-switch appears to be 1k5 and the other one near the Rat-switch appears to be a 1k6.
Please have a look at the (brown) ceramic capacitor between the tone-pot, the LED and the green capacitor (C 16 in my schematic). This capacitor must have a value between 3n3 (332) and 10n (103). Pleae confirm the value, so that I can add this value.
enjoy,
For this message the author analogguru has received thanks: 2
Blitz Krieg (26 May 2015, 07:07), Moonsun (25 May 2015, 16:15)
Have thanks: 117 times
Postby Bernardduur » 20 Jun 2008, 12:45
OK, your schematic is much nicer :D
What's the deal with that power supply? Does it need that filtering?
Bernardduur
Users browsing this forum: bandaache and 6 guests
