Behringer RV600 Reverb Machine: Bad -> Great mods.
Postby briggs » 23 Feb 2009, 16:20
Taken from my blog:
I've been working on this for a few days now. I purchased one of these: http://www.behringer.com/EN/Products/RV600.aspx, a Behringer RV600 Reverb Machine for a couple of quid. It's supposed to be a replica of the Line 6 Verbzilla pedal (more info on that one here: http://line6.com/tonecore/verbzilla.html) and it does a pretty good job of emulating it too. There are ton of very useful reverb tones to be had here. However, there was also 3 major problems with the stock unit:
1) The case was plastic and definitely not up to being trodden on for long!
2) The stock switching was useless. If you had trails on and the mix set below about 80% there was serious tone suck, if the mix was 100% wet and you turned the thing off it didn't pass your signal at all!
3) There was a noticable noise increase while using the pedal.
OK, so simple. A rehouse was in desperate need! I also decided to build up my own switching and mixing system around the pedal instead of trying to adapt the stock unit to perform how I wanted (It's all SMD so not ideal to take a soldering iron too!).
The switching/mixing system I designed allows you to have trails on the switching but also to true bypass the unit. I added independent wet and dry level controls and a preGain control (I used a Zvex SHO as the preamp circuit) which controls the boost of the signal before it hits the front of the 'verb. The set up I produced, with the separate wet/dry level & preGain controls in combination with a few sneaky low pass filters, allows much lower noise operation than the stock single "mix" control present on the Behringer RV600. There is no distinct increase in noise between on and bypassed!
Below you can see what I eventually produced. Controls from left to right: PreGain, Wet Level, Dry Level, Tone, Decay, Delay, Mode.
Check out the neat custom Hammerite & Jackson Pollock paint job :-) On the left of the internal gutshot you can see my custom switching/mixing circuit. I'll be posting a schematic of my switching/mixing circuit soon so stay tuned if your going to be embarking upon any Behringer rehouses....
Next up the Behringer EM600 Echo Machine ;-)
P.S Thanks to SuperVelcroBoy for his heads up on things to look out for while rehousing Behringer stompboxes.
I am Klon.
briggs
Has thanked: 30 times
Have thanks: 124 times
Re: Behringer RV600 Reverb Machine: Bad -> Great mods.
Postby moltenmetalburn » 23 Feb 2009, 17:11
Nice workaround! :applause:
IMHO the yellow knobs are drawing too much attention away from your awesome paint job.
moltenmetalburn
Have thanks: 3 times
Postby briggs » 23 Feb 2009, 17:14
Cheers!
I've ordered some new knobs 8) Those ones on there are pretty terrible but it's all I have at the moment!
I am Klon.
briggs
Postby briggs » 24 Feb 2009, 14:20
I just added a Wet signal FX loop to this as well.
The schematic I'm drawing up will show how I added it. It's got an option to have stereo wet/dry outputs as well. I don't have two amps to run this though so I'm leaving mine mono 8)
I am Klon.
briggs
Postby Ripdivot » 24 Feb 2009, 16:09
"Next up the Behringer EM600 Echo Machine"
I am looking forward to seeing what you can do with the echo machine. I have one and it is not too bad but I find it noisy unless it is on its own power supply. I even shielded the inside of the plastic enclosure but it didn't help.
Ripdivot
Have thanks: 75 times
Postby briggs » 24 Feb 2009, 18:25
Ripdivot wrote:"Next up the Behringer EM600 Echo Machine"
Any features you'd especially like to see?
I am Klon.
briggs
Postby Ripdivot » 24 Feb 2009, 20:50
Just for it to work on the same pwr supply as the rest of my pedals. Sometimes it will work with a shared supply but it depends on the pedals before and after it. I have the Rotary Machine as well and it is also noisy. One thing that bothers me with the behringer line 6 knock offs is how the bypass works. You step on the pedal but it doesn't switch until you release your foot. I want them to switch when you step down on them like any other pedal (boss, ibanez etc...). As for the delay itself, it sounds pretty good.
Ripdivot
Postby chris_d » 25 Feb 2009, 08:40
I picked one of these up a while back. Definitely interested in your mods to it. It is a pretty decent pedal, but obviously with lots of room for improvement!
-chris
chris_d
Postby JiM » 25 Feb 2009, 23:38
Ripdivot wrote:Just for it to work on the same pwr supply as the rest of my pedals. Sometimes it will work with a shared supply but it depends on the pedals before and after it.
I heard that the original Line6 had this problem too ... they are very noisy when they share their power supply. If we find a solution for one, it should work for the other.
Ripdivot wrote:One thing that bothers me with the behringer line 6 knock offs is how the bypass works. You step on the pedal but it doesn't switch until you release your foot. I want them to switch when you step down on them like any other pedal (boss, ibanez etc...).
Isn't there some "hold" or tap tempo function using a long press on the footswitch ? This might explain this behaviour, as you don't want the effect to switch off when you begin tapping the tempo ... I guess it could be fixed in software :| or by adding some pulse-generating logic (the opposite of a latch) right after the switch :wink:
Btw, what is the DSP ? I can't read on the picture, but i guess there is also an Atmega16 for the knobs like in the other Behringer Boss-inspired digital pedals.
JiM
Has thanked: 31 times
Have thanks: 37 times
Postby briggs » 27 Feb 2009, 17:24
Here is a schematic detailing how I have done this, enjoy. There are so many other mods you could add that I've not put on the scheme. If I was really gonna go for it I would have a dedicated "wet" jack for faux stereo operation and I would buffer the FX loop.
I am Klon.
briggs
Postby jeannot » 27 Feb 2009, 21:03
Awesome looking mod. Im new here, but I was just wondering how much of a difference you think it would make to leave out the pre-amp circuit? Is there something you can point me to that would be a good substitute for the Zvex circuit? Thanks.
jeannot
Postby RonaldB » 12 Mar 2009, 11:08
Well i'm doing the Echomachine right now.
But i have a slight problem. When the switch cuts the input of the Echomachine there is a noise coming from the wet output.
any idea what this is?
RonaldB
Postby briggs » 12 Mar 2009, 11:26
Are you using the scheme I posted above? You can try grounding the input on switching. That may help.
Regarding a different preamp choice - you could use a standard op amp gain stage, configured to give gains from 1~10, it would work just as well 8) I chose the SHO circuit because I'd already run out of op amps in my quad and I like the sound of it :)
I am Klon.
briggs
Postby RonaldB » 16 Mar 2009, 09:07
Allready tried to do that (grounding the input) but no luck.
Iám using the your schematic now but i think i'll change the input buffer/pre gain circuit to an opamp stage as i like that more.
I will get back on this as i solved the problem.
RonaldB
Postby briggs » 16 Mar 2009, 10:53
Good to know. You can use any low output impedance preamp stage you'd like really, I just chose SHO as I like them 8)
I am Klon.
briggs
Postby ant1mat » 14 May 2009, 02:10
Hey Briggs! Hi all! :applause:
what about the layman in all this? I understand the switching/mixing schematic but I don't have the technical know-how to make something of it. Could anyone by any chance write a actual layout of the mod with the actual parts needed and brief run through of what goes where. Give the working musician a chance guys! I'm sure I'm not the only one looking for this! Don't let us down and spread the good word!!! :wink: ...please.... thanks!
ant1mat
Postby DWBH » 25 Sep 2009, 22:11
One thing I didn't understand is whether you eliminated/bypassed the original buffers of the pedal.
I mean, from what I read and from the schematic, you have the original pedal, unmodded, turned always on, with the mix pot all the way up, 100% wet - then you just added the aforesaid circuitry. Correct?
DWBH
Have thanks: 4 times
Postby DWBH » 27 Sep 2009, 23:31
bump :scratch:
DWBH
Postby briggs » 28 Sep 2009, 00:35
Correct yes. So only the wet signal ever goes through the Behringer. The dry signal goes through the buffers and mixer..
I am Klon.
briggs
Postby DWBH » 29 Sep 2009, 10:57
But the RV600 is nosiest when the mix pot is fully clockwise. Are those filters efficient?
DWBH
Next
Return to Pimp-My-Cheap-Pedal
Users browsing this forum: blarsen and 2 guests
