Hornby (Skewes, JHS) Selectatone T.B.2 (Treble/Bass Booster)
Postby Electric Warrior » 02 May 2011, 17:24
Gut shots can be found here: http://www.solidbodyguitar.com/Hornby.htm
For this message the author Electric Warrior has received thanks: 5
Drzeus (02 May 2011, 20:46), flatcrabs (02 May 2011, 17:57), stomper (31 Jul 2011, 15:51), vot (11 May 2011, 02:42), WeAre138 (03 May 2011, 02:24)
Electric Warrior
Has thanked: 21 times
Have thanks: 89 times
Transistors
Postby Drzeus » 02 May 2011, 20:52
I can play the aqualung lick,and some great shots EW! As the main JHS guy,are you going to be doing a schematic in the future? Thanks
Maybe the next 25 years won't go by so fast,when my soul is free at last
Drzeus
Has thanked: 18 times
Re: Hornby (Skewes, JHS) Selectatone T.B.2 (Treble/Bass Boos
Postby Electric Warrior » 02 May 2011, 21:49
I'll give it a shot but many details can't be seen in the pics..
Electric Warrior
Postby Electric Warrior » 02 May 2011, 23:05
Here's how I see it:
any objections?
Electric Warrior
Postby Electric Warrior » 03 May 2011, 00:42
a bit neater:
The resistor in the bass section must be 1k of course (like in the Hornby Skewes Bass Booster). I can make out the red band clearly and the other two are dark.
I believe the two missing capacitors are most likely 0.1µFs (right - like the Bass Boost :mrgreen: ). We can be pretty sure about the one on the collector. The Treble Booster has 0.001µF there. 0.1 and 0.001µF in series isn't that much lower than 0.001µF.
The input cap might be more debateable..
Electric Warrior
Transistors
Postby Drzeus » 03 May 2011, 00:46
Not from me EW!.I'll knock one up,see how it flys?.You're a star!
Drzeus
Postby Electric Warrior » 03 May 2011, 00:53
Well, it's just a Hornby Skewes Booster with switchable output section. :D
The bias resistors are different from the silicon version of course, but we already knew that from the germanium Treble Booster pic. The value that's new here is the the 100k from base to -9V. That one wasn't visible in the other pic.
Drzeus (03 May 2011, 03:22)
Electric Warrior
Transistors
Postby Drzeus » 03 May 2011, 03:20
That's the beauty EW.I've built a silicon booster with a 4061 in,and a switch for the debated input caps,but never a GE version.It's like you've given me a jigsaw piece i had missing!
Drzeus
Aldi
Postby Drzeus » 07 May 2011, 20:31
Is the 1k/0.1uf to ground,seperate to the treple switch,or joined to the 100k to ground?
Drzeus
Postby Electric Warrior » 07 May 2011, 20:41
good question.. it's hard wired to ground.. but the 10k/1k joint and the 0.001 probably aren't.. I'll update my schematic..
Electric Warrior
Postby Electric Warrior » 07 May 2011, 20:48
here you go:
what a stupid mistake.. :mrgreen:
For this message the author Electric Warrior has received thanks: 2
Drzeus (07 May 2011, 21:15), vot (11 May 2011, 02:57)
Electric Warrior
Aldi
Postby Drzeus » 07 May 2011, 21:20
Not a mistake,an update.Thanks EW
Drzeus
Postby Electric Warrior » 07 May 2011, 21:27
your post subjects are funny :mrgreen:
Aldi?
Electric Warrior
Aldi
Postby Drzeus » 08 May 2011, 18:25
Aldi number 1 dude!The quality of german sausage and other meats,also dutch like frikandellan,are much preferable to the mechanically seperated twine and cereal we get from sainsburys.Cheaper too.DPDT on the output network?
Drzeus
Postby Electric Warrior » 08 May 2011, 19:17
Funny how cheap Frikadellen are the one thing I wouldn't buy from Aldi :D
DPDT indeed :thumbsup
They used DPDT switches for on/off on the seperate Treble and Bass boosters, too, but didn't wire them up for true bypass.. same deal with the Rangemaster. Disconnecting the battery took priority...
Electric Warrior
Aldi
Postby Drzeus » 09 May 2011, 18:13
I lived in amsterdam an zwolle for a few years,and got a thing for those glass holders,u put a few guilders in an took a frikandelllan,them went in to get some frite saus
lekkerer!
Drzeus
Postby RnFR » 09 May 2011, 18:40
I think I spent 100 bucks in those things in 3 days. :lol:
nice work on this one. I'm gonna mark it solved. :thumbsup
Has thanked: 150 times
Have thanks: 175 times
Postby Electric Warrior » 09 May 2011, 19:21
well, nearly.. anybody know the guys at solidbodyguitar?
Electric Warrior
Aldi
Postby Drzeus » 10 May 2011, 02:33
It'd be good to get the worked up schematic to them?
Drzeus
Aldi
Postby Drzeus » 10 May 2011, 03:02
Sorry 'bout this.My edit function seems to go after a minute?.So EW,the cap off the collector but before the t/b network,is 0.1uf to your mind?.And the input cap the same?.Thanks again mr.jhs!
Drzeus
Next
Users browsing this forum: efirre and 5 guests
