Schaller - Fuzz (Germanium)  [schematic]
Re: 60`s Schaller Ge Fuzz Copper traces found
Postby Schoppo » 23 Feb 2019, 22:59
Hello Happy Fuzz Folks.
here some research update on the Schaller Fuzz:
After building one and testing the annoying sound of that didn´t remind me anything on that sound i remembered.
So something must be wrong. After switching on my head a little bit (sometimes it works ;-) and some more research, this is what i found out:
1. there are two versions differ significant from the other one we now with the 1k 470R on Q2 Collector, but this doesn`t even bias Q2 in the neighbourhood of
a useful sound. there must be a whole Generation gone wrong, by swapping the "Intensität" Pot. Checked it by putting in some 100 Ohm and...
the sound was there: this "Fuck the whole Tonebenders, Fuzz Faces, and whatever you ever liked on a Fuzz" this thing Fucks them all ( mmmmhhh :hmmm: a matter of taste, but you got to hear it-this sound i loved it till first time i heard :P :D just wonderful.
but:
2. there is another but very rare Version, that has the same 8k/470R Voltage divider on Q2 as a fuzz face, but with the 15K on Q1 Collector (never seen one)
So Folks as result
"Intensität" Pot is 100R not 1K
Byby
Schoppo
Have thanks: 7 times
Postby Schoppo » 23 Feb 2019, 23:02
oh and:
there are some versions that have 50K Volume Pot, but this just doesn`t make any difference (so 500k instead of 100k will)
Schoppo
Postby BQmusic » 17 Aug 2019, 10:10
Mine looks like this. AC151, 470R / 100R at the collector of Q2, 15k at the collector of Q1.
Lowering the 15k improves the sound dramatically so I added a bias trimpot parallel to that resistor.
BQmusic
Postby Manfred » 17 Aug 2019, 17:54
BQmusic wrote:Mine looks like this. AC151, 470R / 100R at the collector of Q2, 15k at the collector of Q1.
What is the value of the trimpot?
Has thanked: 1083 times
Have thanks: 687 times
Re: Schaller - Fuzz (Germanium)
Postby mictester » 29 Dec 2019, 05:23
Use a 10k fixed resistor in series with a 25k preset trimmer wired as a variable resistor. Start with the trimmer shorted out, so the resistance is 10k. Increase the trimmer resistance slowly while playing through the thing. You'll soon find the "sweet spot"!
One build I did recently for a friend of this kind of circuit had a 22k fixed resistor and two switchable trimmers (each 25k) to select between two quite differently sounding "sweet spots".
For this message the author mictester has received thanks: 2
fuzzbunny (29 Dec 2019, 07:36), Manfred (29 Dec 2019, 10:41)
mictester
Has thanked: 33 times
Have thanks: 825 times
