Barcus-Berry Standard Pre-Amp Model 1330-1  [schematic]
Re: Barcus-Berry Standard Pre-Amp Model 1330-1
Postby Manfred » 31 Dec 2019, 12:01
Only thing valuable about this now is the dimensions which are ~13mm long and ~7mm diameter.
Inductors with ferrite core in the millihenry range are available in this size.
ihd-239901.pdf
I'll be running a simulation over the next few days.
Manfred
Has thanked: 1080 times
Have thanks: 675 times
Postby soulsonic » 01 Jan 2020, 16:47
I recently bought a 1330 that isn't working and I conveniently have to dissect and repair. But mine is a different version than this which uses an opamp. Wonder if any of the circuit is similar? There are several deliberately obscured components.
Has thanked: 73 times
Have thanks: 296 times
Postby turbofeedus » 01 Jan 2020, 20:35
soulsonic wrote:I recently bought a 1330 that isn't working and I conveniently have to dissect and repair. But mine is a different version than this which uses an opamp. Wonder if any of the circuit is similar? There are several deliberately obscured components.
Yeah I've seen a couple schematics for Barcus-berry products, but none for this one (1330-1). Does yours have the inductor?
turbofeedus
Has thanked: 13 times
Have thanks: 25 times
Postby soulsonic » 01 Jan 2020, 20:59
Judging from your board pic, mine appears to have TWO! Need to dig in and see what the mystery parts are...
Postby soulsonic » 01 Jan 2020, 21:02
The schematic found HERE appears to match my unit. But, surprise, the values of the two inductors are "?" :lol:
Postby turbofeedus » 01 Jan 2020, 21:45
soulsonic wrote:The schematic found HERE appears to match my unit. But, surprise, the values of the two inductors are "?" :lol:
Figures :roll:
Is it possible to measure the inductor in yours?
turbofeedus
Postby soulsonic » 01 Jan 2020, 22:06
turbofeedus wrote:Is it possible to measure the inductor in yours?
Quite possible... :lol: :lol: :lol:
Postby turbofeedus » 01 Jan 2020, 23:48
Cool, hopefully yours is continuous, unlike mine :?
turbofeedus
Postby Manfred » 02 Jan 2020, 08:31
I ran a simulation but I cannot get expected results.
I have replaced the ITS30326 transistor with another JFET without knowing the data from this one, I could not find a datasheet anywhere.
Maybe a crazy idea, please measure the part with your RCL meter in the capacitance range, maybe it is a capacitor.
Manfred
Postby turbofeedus » 02 Jan 2020, 16:58
Manfred wrote:I ran a simulation but I cannot get expected results.
Measures around 20pf, surely that can't be it. Must be just some capacitance happening between the broken ends of the coil, or something residual in the meter.
turbofeedus
Postby Manfred » 02 Jan 2020, 20:44
Thanks for the measurement now it is clear that it is an inductance.
The circuitry of the low pass filter of Soulsonic's device is different but if we know the values, we can deduce the bass filter range.
Manfred
Postby Axldeziak » 02 Jan 2020, 21:33
Any of this info help?
For this message the author Axldeziak has received thanks: 2
Manfred (03 Jan 2020, 01:20), soulsonic (02 Jan 2020, 22:16)
Axldeziak
Have thanks: 10 times
Postby soulsonic » 02 Jan 2020, 23:55
Well, now that I'm looking closely at it, I can say that mine doesn't exactly match that schematic, though generally it's close...
should have it finished up later today.
Postby soulsonic » 03 Jan 2020, 01:35
Well... my Atlas LCR40 says they're 1.5K resistors... :lol:
Postby soulsonic » 03 Jan 2020, 01:42
And where the tone controls connect back to inverting input of the opamp, it's at the junction of the 1uF cap and the 10K to ground, making a parallel connection to that 10K; not connected directly to pin 2.
So do these being resistors make more sense now? Starting to make sense to me, especially the bass cut from it being fully counterclockwise, putting 1.5K to ground after that tiny output cap. :lol:
I have another meter around here somewhere that can read inductance directly without the LCR's brain trying to "guess" its an inductor. I'll try to dig that up and see if it gives any meaningful inductance reading.
Postby Manfred » 03 Jan 2020, 01:50
soulsonic wrote:Well... my Atlas LCR40 says they're 1.5K resistors... :lol:
Have you measured the coils incircuit?
I have the LCR45 I think it is similar to the LCR40,
sometimes does not recognize the component type correctly incircuit.
Manfred
Postby soulsonic » 03 Jan 2020, 02:04
They were desoldered out of circuit.
I tried the other meter, and it says they have a resistance of around 1.5K...and an inductance of over 4H! :lol:
My guess is they are maybe outside the range of what the LCR can guess? Anyway, it seems they are indeed inductors after all, and fairly high value. One measured around 4.5H, the other around 4.9H
Postby soulsonic » 03 Jan 2020, 02:39
Found another big discrepancy with that other schematic. All the pots are 100K linear taper. That's measured with them desoldered from the board.
The values in that other schematic are something like what you read if they're still on the board, depending how the controls are set. :lol:
Postby turbofeedus » 03 Jan 2020, 03:02
Like I said, I have that DCA55. Is there any info I can measure for you to help simulate?
turbofeedus
Postby turbofeedus » 07 Jan 2020, 16:54
Just found another 1330-1 on ebay and bought it, hopefully this one has a working inductor that I can measure.
I'd also like to measure the trimpot, hopefully it hasn't been messed with :hmmm:
For this message the author turbofeedus has received thanks:
soulsonic (07 Jan 2020, 21:29)
turbofeedus
Users browsing this forum: MSN [Bot] and 2 guests
