Barcus-Berry Standard Pre-Amp Model 1330-1  [schematic]
Postby turbofeedus » 13 Sep 2019, 19:11
Hey all, picked up this preamp last week. Came to me with a pretty bad crackle/hiss. Haven't sorted that out yet, but I did up a schematic.
I verified the transistor pinouts and gain with a DCA55.
Diodes are 1N7xx, forward voltage is 0.78V.
Enjoy and feel free to ask questions.
More pics here.
For this message the author turbofeedus has received thanks: 4
287m (15 Sep 2019, 09:25), karul (13 Sep 2019, 20:18), Manfred (13 Sep 2019, 23:37), modman (17 Sep 2019, 08:52)
turbofeedus
Have thanks: 23 times
Re: Barcus-Berry Standard Pre-Amp Model 1330-1
Postby Axldeziak » 15 Sep 2019, 02:49
Are there any visible markings on the Bass pot inductor? (Is it painted over?) Measurement, perhaps?
Axldeziak
Have thanks: 10 times
Re: Barcus-Berry Standard Pre-Amp Model 1330-1  [schematic]
Postby turbofeedus » 15 Sep 2019, 17:07
Axldeziak wrote:Are there any visible markings on the Bass pot inductor? (Is it painted over?) Measurement, perhaps?
Unfortunately not, and as far as I know, measuring for inductance is complicated.
I'd probably just start with a 500mH like this, and go from there.
Updated schematic with a couple corrections.
Axldeziak (15 Sep 2019, 23:35), Ben N (22 Dec 2019, 11:06), modman (17 Sep 2019, 08:53), toneman (03 Jan 2020, 02:41)
turbofeedus
Postby Manfred » 15 Sep 2019, 23:21
Not realy using a LCR-meter.
Has thanked: 1074 times
Have thanks: 668 times
Postby Axldeziak » 16 Sep 2019, 03:15
I may have found a few clues as to what the ITS30326 is. Seems the style of JFet, round, white on the sides with a black top was produced by Siliconix in the mid 70's and was known as the E series.
From there I was able to find mention of E230 Siliconix fets being used in early Barcus Berry amps. The model number was later changed to J230. Looking in a copy of the 1986 Siliconix FET Databook the J230 is listed alongside the J231, and J232 as being N-Channel "Audio and Sub-Audio Amplifiers."
Axldeziak
Postby turbofeedus » 16 Sep 2019, 04:52
Don't have one of those unfortunately.
Axldeziak wrote:I may have found a few clues as to what the ITS30326 is. Seems the style of JFet, round, white on the sides with a black top was produced by Siliconix in the mid 70's and was known as the E series.
Nice, ultimately it doesn't matter much in this context. It's just being used as a buffer, so any modern NJFET should work ok; J113, 2N5484, etc.
turbofeedus
Postby Manfred » 16 Sep 2019, 15:09
I see, perhaps there is repair shop in your area you can aks for measurement.
Postby Manfred » 20 Dec 2019, 10:40
The treble and bass controls are in the feedback loop of the gain circuit.
I ran a simulation of the bass control where I have inserted the control circuit into the feedback loop of an inverting OP-Amp amplifier.
I have found the following center frequencies depending on the inductance of the coil.
I made a PCB-Copy for retracing the schematic.
The coil on the very right of the layout is not marked
Ready to print PDF-files:
BarcusBerryStdPreAmpPCB-ComponetSide.pdf
BarcusBerryStdPreAmpPCB_SolderSide.pdf
Sprint-Layout 6.0 - file:
BarcusBerryStdPreAmpModel1330-1.zip
For this message the author Manfred has received thanks: 4
Axldeziak (20 Dec 2019, 12:04), Mose Varty-Seppanen (03 Jan 2020, 22:58), ppluis0 (21 Dec 2019, 03:27), turbofeedus (21 Dec 2019, 02:38)
Postby turbofeedus » 21 Dec 2019, 02:52
Manfred wrote:The treble and bass controls are in the feedback loop of the gain circuit.
Awesome work Manfred! I did call around and no-one had an LCR meter. I'd loe to get my hand on one of these:
https://www.amazon.com/PEAK-Atlas-LCR45 ... 897&sr=1-5
turbofeedus
Postby ppluis0 » 21 Dec 2019, 03:31
Hi turbofeedus,
You (and all of us...)can build an inexpensive inductance meter presented in this link: http://electronics-diy.com/inductance-meter.php
ppluis0
Has thanked: 47 times
Have thanks: 100 times
Postby Manfred » 21 Dec 2019, 07:56
Hi turbofeedus,
I own the LCR45 and am very satisfied with it.
it also measures the impedance and shows real part, imaginary part, absolute value and phase angle. If you are familiar with these expressions of electrical engineering then I can recommend the device, if not then I would consider an LCR meter device with a lower price to be sufficient.
Postby turbofeedus » 22 Dec 2019, 03:32
ppluis0 wrote:Hi turbofeedus,
I'll check that out, thanks.
Manfred wrote:Hi turbofeedus,
They sound vaguely familiar :D I have the DCA55 and really like it, so I'm familiar with using Peak products.
turbofeedus
Postby Manfred » 22 Dec 2019, 07:29
Then the LCR45 is a good choice :thumbsup
Postby turbofeedus » 27 Dec 2019, 15:10
Couldn't swing the ~$120, so I ordered a cheap but well reviewed LCR meter off Amazon. Should be here tomorrow. Allegedly measures down to 200uH, so we'll see what happens.
turbofeedus
Postby turbofeedus » 28 Dec 2019, 23:09
Wasn't able to get a good reading with the LCR meter.
Important to remember, this unit started with problems, perhaps the inductor is part of those issues.
Regardless, either the inductor is more than 20H, seems unlikely, or something else is wrong.
turbofeedus
Postby Manfred » 29 Dec 2019, 10:55
Such a large inductance is not possible in this size.
Can you measure the DC resistance maybe you did not have good contact to the coil terminals?
Postby turbofeedus » 30 Dec 2019, 06:10
Manfred wrote:Such a large inductance is not possible in this size.
Duh, don't know why I didn't think to test that. Yep, it's open.
Only thing valuable about this now is the dimensions which are ~13mm long and ~7mm diameter.
turbofeedus
Postby VivMeLol » 30 Dec 2019, 13:19
What do those back to back diodes at input do?
VivMeLol
Postby plush » 30 Dec 2019, 15:04
VivMeLol wrote:What do those back to back diodes at input do?
They are present in case input voltage swing exceeds supply voltage (i.e. input overvoltage protection).
plush
Has thanked: 31 times
Have thanks: 85 times
Postby ppluis0 » 30 Dec 2019, 21:51
turbofeedus wrote:Duh, don't know why I didn't think to test that. Yep, it's open.
Perhaps it's time to make several speculations to guess what is the correct value of this inductor.
I'm not have luck using software simulators, so my best guess is that that coil must have a value of 1 to 2 mili henries. :roll:
ppluis0
Next
