Barcus-Berry Standard Preamp Model 1330 (OPAMP VERSION)
Postby soulsonic » 03 Jan 2020, 04:36
Decided it would be best to start a new thread for this one, so as not to clutter up the thread for the earlier version of this preamp.
There is an unverified schematic of this already floating around the web. There are several differences from my trace, as well as missing values; let's assume that other one is wrong! :lol:
First, the schematic:
Now, some huge hi-res pics...
This circuit uses an interesting opamp that I haven't really seen in a guitar circuit before. Here's the datasheet:
MC3476P1.pdf
This was originally intended for use with the Barcus-Berry contact pickup. I haven't tried it with a contact pickup yet, but it works with usual magnetic guitar pickups as well. I suppose you could use it to drive an amp hard. It has a fairly high output. With a hot humbucker, it will distort easily if the Sensitivity is up, in a way that most people would not consider very "toneful". :lol:
Maybe useful as a retro recording preamp? Anyway, I'm keeping mine now that I've got it working. Well worth the $5 I paid for it. :lol:
For this message the author soulsonic has received thanks: 3
Intripped (03 Jan 2020, 15:34), Manfred (03 Jan 2020, 15:43), modman (03 Jan 2020, 12:42)
Has thanked: 73 times
Have thanks: 296 times
Re: Barcus-Berry Standard Preamp Model 1330 (OPAMP VERSION)
Postby Manfred » 03 Jan 2020, 15:48
Hi Soulsonic,
Thanks, that's great.
Please tell me the size of the board, I want to make a PCB clone.
Manfred
Has thanked: 1080 times
Have thanks: 675 times
Postby Ichabod_Crane » 03 Jan 2020, 17:50
Do somebody know with what we could replace that opamp, please?
Ichabod_Crane
Has thanked: 22 times
Have thanks: 12 times
Postby Axldeziak » 03 Jan 2020, 18:07
I was looking into low pass filters and realized that calculation for 5h, 100k is the same as .5h, 10k. Both have a cut-off frequency of 3183Hz. The rise fall time is the same for both as well at 0.000115.
I guess it would be possible to sub the bass pot with a 10K and the inductors with .5h(???) I hope so because the ONLY 5H inductors I can find are $15 a pop before shipping, 2 1/2 pound Hammonds.
Axldeziak
Have thanks: 10 times
Postby soulsonic » 03 Jan 2020, 18:15
Axldeziak wrote:I was looking into low pass filters and realized that calculation for 5h, 100k is the same as .5h, 10k. Both have a cut-off frequency of 3183Hz. The rise fall time is the same for both as well at 0.000115.
This could be a good solution. If someone wanted to get into mathy engineery stuff, they could redesign it using active gyrator circuits. I'm neither mathy nor engineery :lol:
What about those small Mouser transformers, like the "42TM018" and its siblings? Those have been used for a long time in the DIY community for compact inexpensive inductors. I think some of them measure up in the several Henries range. Anyone have a list of the different inductance values of that series?
Postby soulsonic » 03 Jan 2020, 18:55
Manfred wrote:Hi Soulsonic,
4" x 2,85"
Postby soulsonic » 03 Jan 2020, 18:58
Ichabod_Crane wrote:Do somebody know with what we could replace that opamp, please?
http://www.freestompboxes.org/viewtopic.php?f=13&t=431 :secret:
Postby Axldeziak » 03 Jan 2020, 20:21
Smallbear has the Mouser 42TM013 for $2.25. It's listed as 500mh and it's footprint is 22mmx15mm.
Axldeziak
Postby Axldeziak » 03 Jan 2020, 23:20
Maybe this will work for someone.
If it's crap let me know.
Axldeziak
Postby soulsonic » 04 Jan 2020, 21:24
I found a reference for a transformer that may work. The 42TM019 is used as part of Craig Anderton's "Passive Tone Control" project from Electronic Projects for Musicians. He says the primary should be around 5H when used as an inductor.
Postby soulsonic » 04 Jan 2020, 22:17
I just found a TM018 in a parts box. It measures about 4.7H across either the primary or secondary (the TM018 is a 1:1 transformer).
Postby Manfred » 05 Jan 2020, 00:02
i am still at odds with the inductors in my opinion it is impossible to bring such a high inductance into such a small size.
If LCR45 cannot measure a safe value, a question mark appears immediately before the displayed value.
Does the LCR40 behave in the same way?
I have done some simulations of the circuit with unclear results, so I will look at it in theory.
Manfred
Postby soulsonic » 05 Jan 2020, 00:31
Manfred wrote:i am still at odds with the inductors in my opinion it is impossible to bring such a high inductance into such a small size.
My LCR40 gives a result of it guessing it to be a resistor. But using another meter, it will give a resistance value nearly the same as what the LCR gives (around 1,68K), but will also give a value of around 4,5H when I measure inductance, which is way too high for any resistor to read.
The fact that it reads a fairly high resistance (assuming it is a coil of wire), suggests that it is wound with quite fine wire, which would certainly be necessary to get an inductor of this value in a small size. The small TM018 transformer is honestly not very much larger than this, and it contains TWO coils of such inductance, so it seems very possible to me that these are inductors; they must have been expensive.
I can't see how a 1.68K resistor would possibly have this much inductance, no matter what its composition.
Postby Manfred » 05 Jan 2020, 13:31
I understand, you are right, very fine winding wire with a large number of windings can realize such a high inductance.
Manfred
Postby Axldeziak » 05 Jan 2020, 18:42
The first layout I posted IS crap.
So I redrew it:
Axldeziak
Postby roseblood11 » 06 Jan 2020, 01:13
For this message the author roseblood11 has received thanks:
soulsonic (06 Jan 2020, 03:07)
roseblood11
Has thanked: 355 times
Have thanks: 325 times
Postby turbofeedus » 06 Jan 2020, 01:25
Axldeziak wrote:The first layout I posted IS crap.
So I redrew it:
Just a small thing, the model 1330 appears to be the opamp version, where 1330-1 is the discrete transistor version.
turbofeedus
Has thanked: 13 times
Have thanks: 25 times
Postby Axldeziak » 06 Jan 2020, 01:54
So I redrew it:
Figures... if only this site let ya edit your posts.
Axldeziak
Postby roseblood11 » 06 Jan 2020, 15:39
Is there really no better solution than using transformers as inductors?
4700uH inductors are avaliable on ebay.
soulsonic (06 Jan 2020, 19:09)
roseblood11
Postby soulsonic » 06 Jan 2020, 19:14
roseblood11 wrote:Is there really no better solution than using transformers as inductors?
Very good point! I found several listed at a good price very quickly.
But I cannot help but notice: looking at the DC resistance of them, they are all specified as having a resistance of a few hundred ohms or less, with most being less than 100 ohm. This makes me think that perhaps inside that package is an inductor with a resistor wired in series with it. :hmmm:
This makes the circuit make more sense to me, because I was pondering how it would be functioning correctly in the opamp feedback loop.
I now also wonder if having the resistor in series with it would throw off the inductance reading.
:hmmm:
Next
Users browsing this forum: Electric Warrior, Google [Bot] and 4 guests
